Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 10-22-2007, 14:29   #1 (permalink)
Member: 341849
Thanks Meter: 3
After unlock 8600 no 3,6,9 button
Just unlocked 8600 and now the 3,6 and 9 buttons do not work. I have checked connedctor and ribbon, and all are ok...Can anyone advise of what to look for please...Regards
Old 10-22-2007, 14:32   #2 (permalink)
delchoni's Avatar
Member: 239176
Sonork: 100.1602815
Thanks Meter: 851
im think before unlock phone this keys is noth worked !
you tested phone before unlock ?
Br.
Old 10-22-2007, 14:43   #3 (permalink)
Member: 341849
Thanks Meter: 3
Yes, it was ok becauwse # not working either and this was used to check software version b4 unlocking!!
Have check ribbon and connector and all seem to be ok with no damage!
Regards
Old 10-22-2007, 14:44   #4 (permalink)
Member: 341849
Thanks Meter: 3
Yes, it was ok because # not working either and this was used to check software version b4 unlocking!!
Regards
Old 10-22-2007, 16:41   #5 (permalink)
Member: 177834
Thanks Meter: 1,800
mate u might damaged the keypad ic !!
Old 10-22-2007, 17:19   #6 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
this is hardware problem
Old 10-22-2007, 18:09   #7 (permalink)
Member: 91438
yes hardware 1000000000000000%
Old 10-22-2007, 18:55   #8 (permalink)
Member: 341849
Thanks Meter: 3
so do think it has anything to do with unlock?
I have done x6 8600 unlock since this one and all them are ok...
Think it may just be coincidence
Old 10-22-2007, 21:59   #9 (permalink)
mobymaster's Avatar
Member: 13975
Thanks Meter: 7
Open th ephone back up, check you didnt leave any fingerprints on the ics, intenral shieldings/flex connectors, and rebuild it. Send too the nearest repair centre and hopefully they will fix it.
Old 10-23-2007, 09:01   #10 (permalink)
Cheater -Don't Deal with him-
.:GSM International:.'s Avatar
Member: 8879
Sonork: 100.84016
Thanks Meter: 327
same problem, but mine were 1, 4, 7 and #, 100% flex problem!
Nokia E71 keypad problem.. Buttons 3,6,9 and menu is not working desi0067 Nokia Hardware & Hardware Repair 8 10-20-2013 14:39
Water damage W200 where the button 3,6,9 have other function then it should solution. reactos Sony Ericsson Hardware Repair 1 04-16-2008 22:16
8310 Key 3,6,9,# not work NuengEve Nokia Hardware & Hardware Repair 7 04-27-2005 10:05
a52-3,6,9 keys problem TELE-MEDIA E-Gold Based Phones 3 01-16-2005 22:14
sagem 3026 keys 3,6,9,# blocked soft? george gsm Infineon C16X M51 & ARM7 M52 BASED 0 08-14-2002 21:22
Page generated in 0.24484 seconds with 9 queries
