x1x to x45/x50 All Siemens mobile starting from S6, S10, ... up to C45, S45, ME45, SL42, SL45(i), A50, CL50, M50, MT50. |
07-18-2002, 04:40 | #1 (permalink) |
Junior Member Join Date: Jul 2002
Member: 13872 Status: Offline Thanks Meter: 0 | Siemens SL45 WRONG SOFTWARE So i put the V.49 software back again and phone switches on but says "WRONG SOFTWARE" . Can i do anything to fix this? I would be gratefull for any help on this subject, Also on any guidance in which software to use. Thanx in advance. Mark |
07-18-2002, 05:15 | #3 (permalink) |
Member: 13872 Status: Offline Thanks Meter: 0 | i've just been reading some posts i have to get the log software that should'nt take to long, But i think i have put the SLIK software into the phone . Is this the end for that phone. |
07-19-2002, 00:13 | #7 (permalink) |
Member: 13872 Status: Offline Thanks Meter: 0 | Thanks everybody for the help so far, & this great forum with ton's of information. Right i have been playing around with this phone for hours now, Last night when i finished the phone was at a point where it would not turn on at all. I have flashed all versions of software into it but no luck no display at all. i realised a few hours ago that the Eeprom was damaged so i searched for new Eeprom file, Found that & SL45_lcu to upload Eeprom to the phone after a couple of hours worked out how to ammend the hex so the file could be flashed into the phone. I have re flashed the Eeprom data & now the phone switches on but still say's "Wrong Software". At the moment i have used winswup to put Slik4301 version software on to the phone. I've used Siemens A3x All Doer V3.00 to create a map file Which look's okay (not that i know what it should look like) Then i use logger V4.2. I open map file which seem's to open okay then i choose write imei, The logger starts to send the file then say's "Eeprom damaged" I at the moment am a bit confussed about the diffrence between log's & map's as in some post's people are asking for log's and others are asking for map's it seem's to me that to make a map you need a the log first? And are their diffrent types of map like (repair map, unlocking map) |
SL45 wrong software, map please | cpu486 | Phone Unlocking Codes & Maps | 1 | 11-02-2002 14:54 |
SL45 wrong software, map please | cpu486 | Phone Unlocking Codes & Maps | 1 | 10-31-2002 19:16 |
SL45 wrong software. Please calculate my log! | kevin03 | Phone Unlocking Codes & Maps | 2 | 10-15-2002 13:27 |
sl45 wrong software | muller | Phone Unlocking Codes & Maps | 2 | 09-25-2002 13:57 |
SL45 Wrong software, please calc a map | cgavryusov | Phone Unlocking Codes & Maps | 3 | 08-15-2002 16:52 |
