Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > All Siemens and Benq Manufactured Phones > S-Gold Based Phones
S-Gold Based Phones This is the section for all S-Gold based phones like: C65,C72,C75,C81,CF75,CX65,CX70,CX75,M65,M75,ME75, S65,S68,S75,S81,S82,S88,SK65,SP65,SL65,SL75 All about Papua Utils and x65 Flashers you can get it from here.
Old 05-19-2005, 16:24   #1 (permalink)
japunlock's Avatar
Member: 87396
Thanks Meter: 64
cx65==>cx70 how to
plz can someone tell me h¡ow to make the conversion???
Old 05-19-2005, 17:07   #2 (permalink)
Member: 107261
Copy a FF from CX70 to CX65 and unlock
Old 05-19-2005, 19:01   #3 (permalink)
Member: 25693
Use x65 Flasher 1060, generate boot password and use "Advanced" > "Change phone model"
Afterwards you'll be able to update and map with CX70 Firmware and mappings
Old 05-19-2005, 19:18   #4 (permalink)
Crazy Poster
Member: 114945
so, you need to downgrade your cx65 to fw25, generate bootpassword, change phone model, update with cx70's firmware, make a ffsinit and a map? only?
please show me what's a map! i'd glad for this, please!
Old 05-20-2005, 11:01   #5 (permalink)
Member: 111424
is the PTT and 3D will work?
Old 05-20-2005, 12:24   #6 (permalink)
Member: 25693
PTT won't work for your provider until you map your mobile...
maps are provider dependent preferences you transmit via mapr65 or Acid mrp's map65.
the latest mappings for your softwareversion (the jounger the better ) can be found on http://allsiemens.com/flash/
map65 you'll find on http://www.gsmdev.de
So first of all
1. change phone model on your x65 with SWV <36
2. perform FFSInit for the desired phone model before you update (to avoid problems with your filesystem)
3. update with winswup update of the desired phone model (answer the "phone-model-change-dialog" with yes)
4. map your mobile with map65 by Acid[mrp] (write Standard map first and then write your provider's map to your phone)
5. if you want to change phone model in status-monitor do the following (*#06# > More: "Product")
Read your phone's flash with the following preferences (x65 flasher)
from 80000 size 20000 (128kb)
go to adress FD04 of your readed flashblock and reverse the folowing three bytes in order to get an firmwareaddress. For example you get 88 FD 09 (88 is address FD04). Reverse the bytes (always two digits): 09 FD 88 > this is the firmwareaddress where product is stored so we edit our read flashblock and rewrite it to the phone (cause 09 FD 88 is in our flashblock... otherwise you'll have to repeate read-process with new firmwareadresses and size)
so we go to 01 FD 88 of our Flashblock (09FD88 - 80000 = 01 FD 88) with our hexeditor.. some addresses before you'll find your Product (example CX65.1.0 or CX6V.4.0 or like that) so we change this to the desired phone model and flash the modified flashblock back to our phone (in our example from 80000 with size 20000... of course! If you are not sure, create a fullbackup before you write anything wrong to your phone!!)
Now *#06# > More > Product is changed, too
Old 05-20-2005, 14:09   #7 (permalink)
PYCON's Avatar
Member: 26267
What are the advantages of this conversion?
Old 05-20-2005, 21:44   #8 (permalink)
Member: 25693
Push and Talk (walkie talkie) function
Old 05-21-2005, 16:50   #9 (permalink)
japunlock's Avatar
Member: 87396
Thanks Meter: 64
So first of all
in english please
just kidding can you plz explain a little further especially the part of product change
Old 05-21-2005, 17:15   #10 (permalink)
Member: 25693
Where are your problems? Don't know how or where to explain it more explicitly
Old 05-22-2005, 10:23   #11 (permalink)
Member: 88588
hello need a little more help on converting my cx65 my sw version is 14 at the min has any1 got a good online russian web page translator many many thx
Old 05-22-2005, 10:42   #12 (permalink)
Sigma's Avatar
Member: 38980
Sonork: 100.84054
Thanks Meter: 124
and what about c70 to c65? is it also possible?
Old 05-22-2005, 16:33   #13 (permalink)
Member: 25693
I don't think, that conversion from c70 to c65 is possible... except you have a softwareversion <36
Old 05-22-2005, 16:53   #14 (permalink)
Member: 88588
cant see why u would to go from cx70 to a cx65 as i thought the reason from goin from cx65 to cx70 is just to get the ptt function ?????
Old 05-22-2005, 17:09   #15 (permalink)
Member: 25693
@tccat1
What is your Problem with my tut.. maybe i can help you with some details
cx65 dead, how to reflash? ddhorn SIEM Service Tools 1 01-17-2006 20:28
dead cx65 after bad unlock how to repair shahzad.akram Siemens-Benq RingTones and WallPapers 3 12-24-2004 12:58
cx65 HOW TO UNLOCK niki85 S-Gold Based Phones 4 11-03-2004 11:01
How to unlock siemens cx65 scientist S-Gold Based Phones 1 07-09-2004 13:19
Page generated in 0.28649 seconds with 9 queries
