Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
03-15-2005, 15:08 | #61 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | Tools:Flux,Straight fine tpped tweezer and Hot air Station 1:Heat Uem very hot,aplying flux while heating 2:Gently lift Uem while heating using the tweezer(the UEM should peel off,if using enough flux you would reduce the chances of damage to the pcb.There should be quite a bit of resin left on pcb,This i remove with alot of concentration and focus in so that i do not damage any tracks) 3:add flux to pcb(UEM AREA) 4:while heating gently chip away access resin from pcb (not alot of pressure needed."LIKE GOLF",letthe tools do the work! 5:This process takes about 15-20 minutes,but well worth the time spent. Hope this helps. Best Regards! thank you for your co operation i only want to add the doctor knief and the solder wick to the tools why? becuse when you remove the uem you have to clean the pcb 1- use solder wick to remove all the solder balls left in the pcb 2-after you have a little glue left 3-use the doctor knief to remove all the glue from pcb 4-you must use small air and middle heat and small nozzel when you clean pcb only to avoid heat image reach any around the area you clean thank you best regards. raheeeb |
03-15-2005, 16:54 | #63 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Cyprus Age: 42
Member: 15149 Status: Offline Thanks Meter: 61 | i try my solution with drill uem when i see the balls i stop i start with hot air i clean and haft hour i have clean mainboard and ready to put the new uem |
03-16-2005, 10:49 | #64 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | @ Raheeeeb I normally grind off the UEM until Its just the balls and underfill then put a small square piece of cloth soaked in BGA adhesive remover then leave in a sealed packet till the following morning then the underfill can be peeled off then you remove the solder balls the normal way with desolder wick/mop Regards D. |
03-21-2005, 12:37 | #65 (permalink) | |
Member: 7062 Status: Offline Thanks Meter: 126 | Quote:
br., | |
03-21-2005, 23:35 | #66 (permalink) |
Freak Poster Join Date: Feb 2005 Location: West Africa Age: 48
Member: 113414 Status: Offline Thanks Meter: 44 | i`ve tried to remove the uem from 1100 ,but after a while from heating it the cpu rebolled the solder. i spoiled 5 phones in this method it can`t stand heat. |
03-22-2005, 09:40 | #67 (permalink) | |
phones ll work again br., | |
03-30-2005, 15:52 | #69 (permalink) |
Member: 12660 Status: Offline Thanks Meter: 7 | @ Raheeeb Try www.tele-way.com it will direct you to one-stop factory shop (not sure of the url) Regards D. |
04-16-2005, 20:33 | #71 (permalink) |
Freak Poster Join Date: Mar 2005 Location: LONDON TOWN
Member: 129507 Status: Offline Thanks Meter: 10 | Can somebody explain the process of re-balling i.c and the method for putting i.c. back into pcb pls. This is my process 1. after removed ccont i clean the i.c up with solder wick 2. clean pcb with care and remove all old solder 3. I get my solder balls in the stencil in the right place 4. i apply the solder paste to the ccont i.cso the underside is all covered 5. I get ccont i.c and now place into postion over the stencil and drop it into place making sure the chip is in the right place. 6. after leaving for a few minutes for the paste to dry a bit i pull the i.c from the stencil, the ccont i.c now is reballed the solder paste is holding the new balls to the i.c. ok this is now where i get problems 7. I put the ccont i.c. into place on the board, but when i apply heat to it with hot air machine on the lowest setting the balls under the i.c go every where and do not stick please, please can somebody help me and tell me where i am going wrong ? maybe i am re-balling the i.c in the wrong way ???? thanks |
04-17-2005, 01:28 | #72 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | 1- you must heat the solder cream befor you remove teh stencil off the ic 2- you must heat the balles after you make it and remove teh stencil once again thanks .. br., |
04-19-2005, 07:07 | #74 (permalink) |
Member: 7062 Status: Offline Thanks Meter: 126 | 6. after leaving for a few minutes for the paste to dry a bit i pull the i.c from the stencil, the ccont i.c now is reballed the solder paste is holding the new balls to the i.c. thats what you said... no you must heat the cream befor you puul the ic up till yu have riged balls under ic. 7. I put the ccont i.c. into place on the board, but when i apply heat to it with hot air machine on the lowest setting the balls under the i.c go every where and do not stick thats also what you said...and you must never apply ic with solder cream to teh board becuse if the service centers do becuse they use heat oven theroy so the balls become reged befor any contacts with pins on board also but not scen.. |
..::i need video guide how to remove glued chip like omap, rap3g, combo flash,uem::.. | HUM | Nokia Hardware & Hardware Repair | 30 | 01-03-2010 18:33 |
Tutorial of Remove Glued rap and flash chip by Jovy RE 7500 | Raheeeeb | RE-7500 Reworking System & iSolder | 39 | 02-26-2009 11:33 |
removal of glued ics | akfrm | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 03-20-2005 17:29 |
