Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
02-18-2005, 16:46 | #286 (permalink) | |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | Quote:
Can u show me how you do that (DC/AC) method to me? I am interested. | |
02-18-2005, 18:37 | #288 (permalink) |
Freak Poster Join Date: Nov 2003
Member: 44625 Status: Offline Thanks Meter: 36 | @ Edwins C, Why the huge text size? I know akingsm was asking here. I was trying to encourage proper habits by not replying to his query in this thread which is for network problems. I request you not to use such huge fonts as we are not blind and its a waste of a page as with such huge fonts only a few posts will be seen. @Gabsi, Please start a new thread if u can't find the reply to ur query in old posts. This thread is for network problems only. |
02-18-2005, 19:32 | #289 (permalink) | |
Freak Poster Join Date: Dec 2002 Age: 51
Member: 19190 Status: Offline Thanks Meter: 28 | Quote:
pm me n i show u some experiences. | |
02-19-2005, 00:45 | #291 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | i have here 6210 with signal problem. phone was dead /contact service. I reflowed ram and flash ic, phone stay on but with CS , so i reballed COBBA , then INSERT SIM . but no signal. so i changed HAGAR but still same. in netmonitor 0 0 0 0 0 no rx no tx .. any idea ? in manual search no network found. tired also to change AS and FDK still same. can any1 help me with this please? of course fullflash was aplied too.. Pali |
02-19-2005, 08:12 | #292 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 71603 Status: Offline Thanks Meter: 31 | @keany I've a 7250 no signal, can U help me? history of it: water in side so it died, i'm replace CPU & UEM it work again, but when i turn on it signal full before the light off signal empty, I was replace anten switch, PA and Helga but no have good result, i thing main board was broken... help me pls! |
02-19-2005, 19:56 | #293 (permalink) |
Junior Member Join Date: Feb 2005 Age: 52
Member: 118884 Status: Offline Thanks Meter: 0 | 5140 signal down at 30 deg. celsius!!!!!!!!!!! Hi all; I have nokia 5140 that makes a strange thing; when the temperature is 30-31 deg. celsius; its signal down; but if the temp is higher or lower it works please any ideas? I post in many forums but no one know the reason or give me solution. Thanks |
02-20-2005, 07:50 | #294 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 42
Member: 108629 Status: Offline Thanks Meter: 16 | I have found the solution for using volte meter to measure TX/Rx without Tx/Rx measuring points. To use voltemeter, fix the ground and touch +ve point at all Tx/Rx measuring points. you will find different values of ampare at different points,which can be noted with ok kit. Enjoyeee... |
02-20-2005, 10:03 | #296 (permalink) | |
Freak Poster Join Date: Jan 2005 Location: Nainital, India Age: 44
Member: 108114 Status: Offline Thanks Meter: 3 | Quote:
02-20-2005, 10:39 | #297 (permalink) | |
Insane Poster Join Date: Aug 2002 Location: Bucuresti, Romania
Member: 14940 Status: Offline Thanks Meter: 16 | Quote:
02-20-2005, 12:48 | #298 (permalink) | |
Have got the solution. network has been recovered. | |
02-20-2005, 14:35 | #299 (permalink) |
Member: 119000 Status: Offline Thanks Meter: 0 | Hi all, I have a 3510, originally from TIM (Italy), unlocked, and I'm trying to use it on Orange UK (1800MHz). Once yesterday I saw good signal, but normally I get no network at all(zero signal, "no network coverage" when trying to make a call). Yesterday I tried some friends' SIM cards: it didn't work on T-Mobile (also 1800MHz), and it was ok with strong signal on Vodafone and O2 (both 900MHz). Trying to select network manually with Orange SIM, it sees all 4 networks, normally hangs for ages trying to connect to Orange but immediately says "no access" trying Vodafone or O2. Not always so, however: sometimes Orange responds faster or Vodafone takes ages. Very intermittent behaviour... Any ideas how to troubleshoot and fix this? Thanks! P.S.: The phone was dropped on ice+snow, probably got wet; changed cracked LCD, but everything else looks fine inside. |
02-20-2005, 14:49 | #300 (permalink) |
No Life Poster Join Date: Jun 2003 Location: somewhere Age: 40
Member: 31028 Status: Offline Thanks Meter: 56 | it could be ant.switch or PA, vanhh, after all that did u tryed to write a new pm file and unlock phone? checeked PA and ant.switch??? Pali also check PA, And ant.switch, did u write after reaball cobba, write a virgin eeprom, and the fullflash, after that set faid... regards |
1220 NO signal solutions | mrfixit | Various CDMA/TDMA Cell Phones | 2 | 03-16-2017 04:26 |
Nokia 1600 no signal solution required | azam_gsm1 | Nokia Hardware & Hardware Repair | 9 | 02-23-2009 11:03 |
3100 No signal solution | irfaN_vu | Nokia Hardware & Hardware Repair | 31 | 05-22-2008 03:54 |
For new beginners. here Nokia code's | pazeth™ | Nokia Hardware & Hardware Repair | 0 | 06-26-2005 15:20 |
lg 8110 no signal solution | ihsanali | LG | 5 | 03-03-2005 11:51 |
