Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
02-20-2005, 14:58 | #301 (permalink) | |
Junior Member Join Date: Feb 2005
Member: 119000 Status: Offline Thanks Meter: 0 | Quote:
Actually I don't have any equipment, I'm not a pro like you, just one guy with a faulty phone that isn't worth much so there is no point in paying too much to fix it: if it is something simple ok, otherwise I'll just throw the phone away or sell the bits that work on ebay. Thanks! P.S.: Ignorant's question: why would the phone work at 900MHz but not at 1800MHz? Last edited by old_butch; 02-20-2005 at 16:58. | |
02-20-2005, 17:53 | #302 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | 6210 fixed with changing COBBA. Now full network all is working corectly. (it was 0 0 0 0 in netmonitor) have here another 6210 with network problem. Sometimes have full signal but never on startup. if have signal not everytime can make call. if i make call it interupts in speaker (but signal was full) HAGAR is changed . PA is new As is new 26mhz also changed. Any idea ? Pali |
02-20-2005, 22:04 | #303 (permalink) |
Junior Member Join Date: Feb 2005 Age: 56
Member: 114536 Status: Offline Thanks Meter: 1 | 8310 signal fault??? hi,first let me say im a beginer so please dont get to techical,i have a 8310 which if you look at the signal bar on the display is fine but i know its not,what could be the cause,any ideas? thanks jamie |
02-21-2005, 03:34 | #304 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 71603 Status: Offline Thanks Meter: 31 | Quote:
I tryed write PM by Griffin, PA & ant switck is OK (i tryed PA & ant. switch by good phone). But it is still!!! vanhh. | |
02-23-2005, 15:04 | #305 (permalink) |
Junior Member Join Date: Jan 2005
Member: 107978 Status: Offline Thanks Meter: 0 | I have some problem in NOKIA 8250 1. NETWORK : - No network at all - Cannot detect all network provider at may area (for example there are 3 network provider at my area, but only 1 network provider detected in my phone.) 2. POWER : - No Power at all - Low power (when i switch on, led indicator doesn't light on, but ****** with multitester the voltage less than 2.8V) 3. CHARGING : - Cannot charging at all - Continous charging (battery indicator always sign on charging although I switch off my charge) 4. BLANK LCD (NO DISPLAY) WHAT SHOULD I DO STEP BY SYEP...??? CAUSE I'M A BEGINNER...PLEASE HELP ME...!!! |
02-23-2005, 15:05 | #306 (permalink) |
Member: 107978 Status: Offline Thanks Meter: 0 | I have some problem in NOKIA 3310 1. NETWORK : - No network at all - Cannot detect all network provider at may area (for example there are 3 network provider at my area, but only 1 network provider detected in my phone.) 2. POWER : - No Power at all - Low power (when i switch on, led indicator doesn't light on, but ****** with multitester the voltage less than 2.8V) 3. CHARGING : - Cannot charging at all - Continous charging (battery indicator always sign on charging although I switch off my charge) 4. BLANK LCD (NO DISPLAY) WHAT SHOULD I DO STEP BY STEP...??? CAUSE I'M A BEGINNER...PLEASE HELP ME...!!! |
02-28-2005, 11:28 | #307 (permalink) | |
Junior Member Join Date: Feb 2005 Age: 44
Member: 121267 Status: Offline Thanks Meter: 0 | signal problem in 3310 Quote:
i have nokia 3310 , b4 few days i charged it , after then i felt than signals and becoming day by day , and no signals are in these days, plz solve my problem , what advise me about it. thanks regards | |
03-06-2005, 15:18 | #309 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Spinning on my OWN Orbit
Member: 5358 Status: Offline Thanks Meter: 211 | signal just learn by experience and advice cause signal sometimes lines are the cause. check the lines for tx and rx check cobba hagar and pa even the small components besides. |
03-07-2005, 04:17 | #310 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 44
Member: 68672 Status: Offline Thanks Meter: 6 | Any solution for st55 siemens it hangs up on T-Mobile when start. Please send me link for St55 flsher or mail me solution at [email protected] helpppppppppppppppppppppppppppppppppppp |
03-08-2005, 00:45 | #311 (permalink) |
Product Supporter Join Date: Sep 2004 Location: PHILIPPINES Age: 47
Member: 81952 Status: Offline Sonork: 1597268 Thanks Meter: 2,364 | Test 01 1)AGCH--->CCCH--->AGCH--->CCCH = no tx a. 51XX/61XX= P. A. then RX/TX Combiner then Cobba. b. 3210 = Z504 then P.A. then TX Filters then Cobba. c. 33XX = Antenna Switch then P.A. then C109 then Cobba then Hagar. d. Others = Antenna Switch then P.A. then Cobba then Hagar. 2)SEAR--->BCCH--->AGCH--->SDCC--->Restart = MSID problem. a. All = Update FAID then repair eeprom then Cobba. 3)SEAR-------------------------------------->Restart = Cobba Problem. a. All = Rework or Replace Cobba. 4)SEAR--->XXXX---->NSPS--->SEAR--->so on = RX Problem. a. 51XX/61XX = 13 MHz Filter then IF Filter then IF IC. b. 3210 = IF Filter then 13 Mhz Filter then RX Filters then IF IC then Duplexer. c. Others = RX Filters then HAGAR. 5)SEAR--------------------------------------->SEAR = Cobba Problem. a. All= Rework or Replace Cobba. 6)SEAR--->BCCH--->SEAR--->BCCH = Antenna Problem. a. All = Check Antenna. |
1220 NO signal solutions | mrfixit | Various CDMA/TDMA Cell Phones | 2 | 03-16-2017 04:26 |
Nokia 1600 no signal solution required | azam_gsm1 | Nokia Hardware & Hardware Repair | 9 | 02-23-2009 11:03 |
3100 No signal solution | irfaN_vu | Nokia Hardware & Hardware Repair | 31 | 05-22-2008 03:54 |
For new beginners. here Nokia code's | pazeth™ | Nokia Hardware & Hardware Repair | 0 | 06-26-2005 15:20 |
lg 8110 no signal solution | ihsanali | LG | 5 | 03-03-2005 11:51 |
