Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
03-28-2005, 13:01 | #346 (permalink) | |
Junior Member Join Date: Mar 2005 Age: 45
Member: 129826 Status: Offline Thanks Meter: 0 | Quote:
if still can not post me a reply.. | |
03-28-2005, 18:51 | #348 (permalink) |
Junior Member Join Date: Nov 2004 Age: 47
Member: 94615 Status: Offline Thanks Meter: 2 | i got two (2) 3310 phones with signal problem one (1) signal appears when u put it on and disappear after 10 seconds, two (2) signal did not appear at all when put on. please let any expert send solution i have tried anttena sw Pa and most software. pls let any body sure and with a tested solution give me a reply on [email protected] |
03-29-2005, 13:08 | #353 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Spain
Member: 9489 Status: Offline Thanks Meter: 35 | I have some 6310i with network problems. Most of them find network and work fine under 900Mhz. But canīt find any network on 1800Mhz. Should I change Ant. Swicth? What else could be? Also, I have some that doesn't find network at all. I have heated Hagar. What else could I do? Thank you Best regards |
03-29-2005, 13:35 | #354 (permalink) | |
No Life Poster Join Date: May 2004 Location: gsm-land Age: 45
Member: 67419 Status: Offline Thanks Meter: 237 | 6310i Quote:
RESPO0NSABIL FOR 1800 MHZ RECIEVER ITS HAGAR YOU MUST CHANGE IT (OR SEE WITH ATENTION THE PINS UNDER ) IF YOU HAVE NOT SUCESS ....THERE ARE SOME LITLE COMPONENTS I WILL TELL YOU AFTER YOU HAVE CHANGE HAGAR BEST REGARDS KEANY | |
03-30-2005, 10:41 | #357 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | I have meet with the stranger problem one Nokia 2650 RH53, was working proper but after shut down and power it I got the message of insert sim card while the sim card is inside, please any solution, |
03-31-2005, 19:37 | #359 (permalink) |
Junior Member Join Date: Aug 2004 Age: 50
Member: 79891 Status: Offline Thanks Meter: 0 | I have a nokia 3310 that is water damaged. It shows contact service when put on. I then used the ultra sonic cleaner and the hot air. when i tried putting it on again, it showed light and vibrated at thesame time and went off. Since then phone has remained dead. what do i do? Please i need ur advice. |
04-01-2005, 08:30 | #360 (permalink) |
Member: 67419 Status: Offline Thanks Meter: 237 | @valley-side as i see you have damage mcu or flash-ic you must move and clean inside your flash ic or change it and try to switch on your phone regards keany |
1220 NO signal solutions | mrfixit | Various CDMA/TDMA Cell Phones | 2 | 03-16-2017 04:26 |
Nokia 1600 no signal solution required | azam_gsm1 | Nokia Hardware & Hardware Repair | 9 | 02-23-2009 11:03 |
3100 No signal solution | irfaN_vu | Nokia Hardware & Hardware Repair | 31 | 05-22-2008 03:54 |
For new beginners. here Nokia code's | pazeth | Nokia Hardware & Hardware Repair | 0 | 06-26-2005 15:20 |
lg 8110 no signal solution | ihsanali | LG | 5 | 03-03-2005 11:51 |
