Nokia Repair Guide and FAQ Common Nokia Hardware Problems and Tutorials, EXE packages and Schematics |
04-01-2005, 22:27 | #363 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 45
Member: 92067 Status: Offline Thanks Meter: 10 | I have 8250,2100 total no network I put good IC from normal phone to bad phone (PA,hagar,cobba,ccont,ant switch,VCO,13Mhz crystal clock,GSM Tx filter,Z600-Z601 RX filter) but still no network |
04-02-2005, 08:25 | #364 (permalink) |
No Life Poster Join Date: May 2004 Location: gsm-land Age: 45
Member: 67419 Status: Offline Thanks Meter: 237 | if you have total no nerwork...you will see again : 1-hagar 2- switch 3 -flash ic ..if you stiil have no network ..? you will see test litle components ... regards keany |
04-02-2005, 10:31 | #365 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: HELLAS-makedonia Age: 40
Member: 93568 Status: Offline Thanks Meter: 44 | Quote:
04-02-2005, 12:34 | #366 (permalink) | |
Junior Member Join Date: Mar 2005 Age: 45
Member: 129826 Status: Offline Thanks Meter: 0 | Quote:
04-02-2005, 12:39 | #368 (permalink) | |
04-02-2005, 12:42 | #369 (permalink) | |
04-02-2005, 19:33 | #372 (permalink) | |
Member: 92067 Status: Offline Thanks Meter: 10 | Quote:
Thanks | |
04-03-2005, 00:31 | #373 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | NO NETWORK ,,,, you have to measure all uplink and downlink path with all "VR-x" supply ! and all control TXP by MCU to Hager, TXC by COBBA/UEM to Hager , and VCO LOOP! also ANT switch control by Hager !! do not try to make more damage from test and replace parts !! Willy |
04-04-2005, 08:15 | #375 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | I was trying to upload ringtone for RH19 3100, it failed after that start to select battery, if you put another battery it doesn't switch on, Bad luck the battery become empty I tried to charge it but do not respond and now the phone is dead and the battery is dead, Itested about 5 battery with no luck, |
1220 NO signal solutions | mrfixit | Various CDMA/TDMA Cell Phones | 2 | 03-16-2017 04:26 |
Nokia 1600 no signal solution required | azam_gsm1 | Nokia Hardware & Hardware Repair | 9 | 02-23-2009 11:03 |
3100 No signal solution | irfaN_vu | Nokia Hardware & Hardware Repair | 31 | 05-22-2008 03:54 |
For new beginners. here Nokia code's | pazeth™ | Nokia Hardware & Hardware Repair | 0 | 06-26-2005 15:20 |
lg 8110 no signal solution | ihsanali | LG | 5 | 03-03-2005 11:51 |
