05-11-2007, 20:05 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: USA
Member: 479106 Status: Offline Thanks Meter: 44 | i607 phone pin |
05-12-2007, 03:21 | #2 (permalink) |
Member: 479106 Status: Offline Thanks Meter: 44 | now when i put in a cingular sim card i get this message: "this phone can only be used with a specific sim. enter the unlock code or insert an approved sim." ust finds the phone no probem and unlocks the phone no problem wtfo? |
05-12-2007, 16:25 | #4 (permalink) |
Member: 479106 Status: Offline Thanks Meter: 44 | Thank-you for your response. I do not see an option for flashing in your interface when i607 model is selected. Also now that I installed ust 5.01 today when I select the “read code” option…ust closes down……………although the direct unlock function seems to continue to go through its paces…. |
05-12-2007, 19:25 | #5 (permalink) |
Insane Poster Join Date: Jan 2005 Age: 48
Member: 110856 Status: Offline Thanks Meter: 5 | me 2 have the same problem . after upgrade new i607 rom from samsung now the phone won't read the sim , and i want to downgrade the rom but couldn't find in the support for I607 |
05-13-2007, 18:47 | #9 (permalink) |
Member: 479106 Status: Offline Thanks Meter: 44 | Also have another? to add. #1 I don’t have a d800 usb cable-just the one with the rj45 end for ust- however the phone is recognized ok when hooked up with my v804ss cable using the usb half hooked directly to pc- will this cable work for this operation? Also if it helps- here is the phones info: h/w version: rev0.0 eboot version i607UCFJE -thanks |
05-18-2007, 20:54 | #14 (permalink) |
Member: 479106 Status: Offline Thanks Meter: 44 | Still waiting on that flash file- I do not see it anywhere on the site. Here is where I am now: I have flashed the phone with AT&T’s newest firmware and unlocked the phone with direct unlock but still get message; so I tried flashing to the i600 flash on your support site- the flash was successful however now I am unable to unlock or even recognize the phone. Ust does not recognize, pc does not recognize but the phone boots up just fine what could be problem? -thanks |
i607 phone off mode | c_ahmad79 | UST Pro II | 16 | 01-14-2012 16:34 |
i607 PHONE CODE??? | ROUGHNECK | Easy-Unlocker | 0 | 09-12-2008 04:44 |
I607 Phone Pin | baomobile | Easy-Unlocker | 5 | 12-20-2007 11:30 |
i607 .. phone not found | tical | UST Pro II | 4 | 09-11-2007 13:49 |
Can Fighter clear a phone PIN lockout on an R290 Satellite | anlog | Cruiser Suite | 0 | 05-11-2004 16:59 |
