Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Panasonic
Panasonic Panasonic-News...
Old 10-04-2004, 10:12   #1 (permalink)
Crazy Poster
Member: 51960
Panasonic X70 Dead During Flashing
I Was Trying To Flash The X70 To The Latest Firmware When The Power Went Down I Was Somewhere At 80 %
I Have Tried To Repeat The Process But I Get Error Message
I Am Using Winmodo For X70
Can Anyone Help Me Find A Solution?
I Am Desparate Please Help Me
Old 10-04-2004, 10:17   #2 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
If you Plug the Battery Out when the Phone is in Boot Mode,
You'll LOST the boot of ur Phone
same thing happen as GD87
Only Solution is Jtag
Old 10-05-2004, 14:40   #3 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
only jtag because combo flash is glued
are you from greece??contact me
Old 10-15-2004, 19:47   #4 (permalink)
Member: 74084
Thanks Meter: 8
Excuse me friends, but to flash a X70 wtih winmodo what cable I must use? USB? Because I don't find a serial cable!
Pls explain me how I can flash It! Thanks at all
Old 10-15-2004, 23:36   #5 (permalink)
xavien's Avatar
Member: 3127
Sonork: 100-76993
Thanks Meter: 9
Correct cable!!
Panasonic use serial powered cable,,and usb cable,,but you can flash the phone with not original usb cable...you have to install the right drivers....but all drivers is the same,,(you find in the cd with usb cable)your pc call..." prolific usb com port" if i remember well...and you can easly change the com port number(if you use XP)...and flash the phone...the battery must be full charge....is better...
I have the original serial cable,,but i use without prob.usb not original one.
Regards
Xavien
Old 10-17-2004, 02:24   #6 (permalink)
Member: 74084
Thanks Meter: 8
But flashing X70 I've need to download all files that show me from winmodo:
.rff , .lpk, and customize file? Or I can use only .rff and .lpk files?
P.S. What is the code to know the version of firmware present in X70 before flash?
Thanks in advance!
Old 10-17-2004, 03:06   #7 (permalink)
xavien's Avatar
Member: 3127
Sonork: 100-76993
Thanks Meter: 9
X70
You can use rff and lpk file only...sure....and to know the version power on phone with sim inside,,before that the phone get the net,press *à#9999#,waith a few second and you can see in the display all info that you need,the first line is software version
regards
Xavien
Old 10-17-2004, 03:07   #8 (permalink)
xavien's Avatar
Member: 3127
Sonork: 100-76993
Thanks Meter: 9
X70
sorry.... *#9999#
BS
Xavien
Old 10-18-2004, 02:21   #9 (permalink)
Member: 74084
Thanks Meter: 8
Originally Posted by xavien
sorry.... *#9999#
BS
Xavien
But rff and lpk have games to install in the phone?
Bye
Old 10-18-2004, 11:44   #10 (permalink)
Member: 74084
Thanks Meter: 8
I've try to flash X70 with winmodo but when appear "Signalling" and I push red power button, nothing!!!
What I do?
Old 10-18-2004, 11:57   #11 (permalink)
webiso's Avatar
Member: 10580
Thanks Meter: 43
hı may be x70 repair easy
use winmodo but not normall mod gang mod
and you need normal workıng x 70
please contact me msn
[email protected]
Old 10-18-2004, 12:37   #12 (permalink)
Member: 74084
Thanks Meter: 8
[email protected]
I want only to flash my X70! it work fine and has got version A30! I want download in A36!
Cable that I have is USB only, maybe I need to change with any drivers in serial/usb cable!?!?!
Help
Old 10-18-2004, 19:16   #13 (permalink)
Member: 74084
Thanks Meter: 8
I've try all solutions to flash X70 with winmodo and Usb Cable, but nothing!Also in Gang Mode!
Winmodo says all time: "Signalling" but when I push on Power red button not happen nothing!
What I do?
Old 10-18-2004, 19:45   #14 (permalink)
Platijet's Avatar
Member: 26279
Thanks Meter: 274
@maurone:
go to:my computer-(right button on your mouse)-properties-hardware-device manager and check what com is your USB cable-use same com port to downloader (winmodo) for X70
Old 10-18-2004, 19:48   #15 (permalink)
Member: 74084
Thanks Meter: 8
Yes, I know this procedure! I've selected COM3 and same port for winmodo for X70 but nothing! Download don't start!
panasonic x100 dead during flashing ataiwaris Infinity-Box 8 11-16-2008 10:03
X70 dead during unlock Irfangk786 Infinity-Box 18 02-13-2008 14:02
X70 dead during unlock. Mr GsM Infinity-Box 2 06-17-2006 11:56
X70 Dead during unlocking Gr8SightMan Infinity-Box 12 09-12-2005 09:12
Panasonic GD87 dead during flashing????? .::Zafar Communication::. Panasonic 9 06-18-2005 00:13
Page generated in 0.27875 seconds with 9 queries
