Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com
Old 03-10-2009, 14:23   #46 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
Thanks Meter: 82
I flashed an E71 with same problem with th E71 file, then when I try to flash Complete flash, I get this error
MCU = rm346_100.07.76_prd.c00
PPM = rm-346\rm346_100.07.76_prd.v14
CNT = rm346_100.07.76.01U
APE Variant file: NONE
Manual mode selected, version can't be checked!
Booting phone...
FAST PHONE detected!
CMT Boot Data:
Asic ID: 000000010000022600010006400C192101031103
Asic Mode ID: 00
Asic EM ID: 00000B22
Asic Public ID: 12A00117ABBE015829CE9E6C3A1DECFEE6B7233C
HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE00000000
ROM ID: 4B9B75103E691FF8
CMT Boot File: E:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: E:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg
Loader version: 01.23.00 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
Operation took 0 minutes 6 seconds...
Wrong file id 00
Failed inspecting flash file...
The Following User Says Thank You to dannyogolo For This Useful Post:
Old 03-11-2009, 03:14   #47 (permalink)
Member: 47532
Thanks Meter: 18
the E71 pmm file can use ,but E66 pmm filer cant use ,
Old 03-12-2009, 17:14   #48 (permalink)
Member: 512551
Sonork: 100.1626194
Thanks Meter: 66
mr jaf e71 is freeeeeeeeeeeee pls help me thant
Old 03-12-2009, 18:36   #49 (permalink)
Gubby_J's Avatar
Member: 131788
Thanks Meter: 69
Re
Originally Posted by askaralikp View Post
hello sir thanks agin fore this infoooo
but sir same problem in e66 plz uplode that pmm file plezzzzzzzzzzzz sir
You don't have software problem, your problem is damaged RAPIDO CPU, change it and make RPL, or change with set RAPIDO+Flash from other phone.
I tested in E66, and works perfect also 6120c and others RAPIDO-based models.
RAPIDO-Cpu is a very breakable CPU.
Thank's
Old 03-14-2009, 11:41   #50 (permalink)
Adil Mobiles's Avatar
Member: 228476
Sonork: 100.1575078
Thanks Meter: 114
Originally Posted by jafsupport.com View Post
Hi..,
This is the solution for the E71 which shows the following Symptoms...
Phone does not start up when pressing power key. When pressing the power key notification light and display backlight wake up. Vibra makes one jog. Phone will take 230 mA but nothing else happens. After 30 seconds phone will power off. You can update phone software but it doesn't help anything. Phone doesn't start to test mode...
Solution..
Flash the Phone using the attached PMM erase file...
Then Flash it with latest data pakage..
Thanx dear i have done this by flashing with this file. now my phone is ok.
Thanx again.
The Following User Says Thank You to Adil Mobiles For This Useful Post:
Old 03-17-2009, 04:21   #51 (permalink)
Member: 47532
Thanks Meter: 18
3 sets e66 done with e66pmm files,,great
The Following User Says Thank You to excelpass For This Useful Post:
Old 03-17-2009, 08:09   #52 (permalink)
Member: 23372
Thanks Meter: 18
how did you do that can u share coz have 1 wont power
Old 03-18-2009, 03:51   #53 (permalink)
Member: 47532
Thanks Meter: 18
flash the ppm e66pmm file in mcu then full flash with new version
Old 03-21-2009, 10:36   #54 (permalink)
raulka2003's Avatar
Member: 489331
Thanks Meter: 1,141
Failed! Aborting
JAF version 1.98.63
Detected PKEY: 900xxxxx
Card life counter: 97.32%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.8.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-346\
Searching for default location of ini...
Checking path: D:\DataPackage\Products\RM-346\
Scanning ini files...
MCU Flash file: D:\DataPackage\Products\RM-346\rm346_210.21.006_prd.c00
PPM Flash file: D:\DataPackage\Products\RM-346\rm346_210.21.006_prd.v01
CNT Flash file: D:\DataPackage\Products\RM-346\rm346_210.21.006.02U
APE Variant file: D:\DataPackage\Products\RM-346\E71_SW_040-063971_EuropeBeneluxNoLive_2G_1V0.fpsx
Changing flashing settings...
PPM Flash file: D:\DataPackage\Products\RM-346\rm346_210.21.006_prd.v14
APE Variant file: D:\DataPackage\Products\RM-346\E71_SW_040-065075_RussiaEurAsiaCV_2G_1V0.fpsx
Fast phone flashing selected.
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
Asic Public ID: 1FB00110F39601582BDD1B613A629F8C742C3298
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_2nd.fg
CMT Boot Ready
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAPIDOv11_algo.fg
CMT Loader Ready
Sending CNF Data...
Sending CRT data...
Erasing...
Operation took 0 minutes 2 seconds...
Writing...
Stage 1
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
Sending CMT PUB KEYS...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS*CORE
Sending CMT HASH for SOS+ROFS
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Sending CNF Data...
Sending CRT data...
Stage 1
FAST MODE finish!
Operation took 4 minutes 29 seconds...
Reseting phone...
PPM: D:\DataPackage\Products\RM-346\rm346_210.21.006_prd.v14
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Erasing...
Operation took 0 minutes 1 seconds...
Writing...
Stage 1
Sending CMT HASH for SOS+ROFX
Operation took 1 minutes 54 seconds...
Reseting phone...
CNT: D:\DataPackage\Products\RM-346\rm346_210.21.006.02U
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Erasing...
Writing...
Stage 1
Operation took 0 minutes 32 seconds...
Reseting phone...
Done!
Total time: 7 Minutes, 21 Seconds
DCT4/BB5 counter: 383
After flash processing...
Waiting for phone to boot...
Reading...
Failed! Aborting!...IMEI
Need Help . .
Old 03-26-2009, 18:39   #55 (permalink)
Member: 997657
Am new here. I was updating my e71 and it failed in between. Now its behaving like you mentioned below. I have downloaded the file below and unzipped it. What next? What to exactly mean by "flash the phone"
My laptop is not even recognizing the phone through usb cable now?
Hi..,
Solution..
Old 04-23-2009, 22:55   #56 (permalink)
Member: 389862
Sonork: guy_askali
Thanks Meter: 54
my n75 blue lcd same like e71 how to repar it plz help
Old 04-24-2009, 12:08   #57 (permalink)
rajeshbahri's Avatar
Member: 108747
Sonork: 100.108643
Thanks Meter: 655
Hi..,
Solution..
thx sir, really this is good solution , i repair my 2pc e71 with this.
lot of thx.
b.r
bahri
Old 04-25-2009, 19:52   #58 (permalink)
Member: 1012711
Thanks Meter: 2
need the pmm for n78/n79 sir
thanks
Old 04-26-2009, 04:19   #59 (permalink)
jafsupport.com's Avatar
Member: 125
Sonork: 100.100000
Thanks Meter: 1,305
Arrow
thanks
Not really have it... but try search if there is something for those models...
Thanks!
Old 04-26-2009, 08:38   #60 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
thanks
Here you go-
N78 (rm-235) v20.149 ppm only- PPM
N79 (rm-348) v11.049- PPM
For more Nokia flash files with mcu,ppm & cnt look here- http://forum.gsmhosting.com/vbb/showthread.php?t=541464
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Solution For E51 phone does not start up... jafsupport.com J.A.F. By Jafsupport.com 106 12-22-2012 19:05
E71 phone does not start up szozda2 Nokia Hardware & Hardware Repair 10 12-17-2009 03:19
my n78 phone does not start up... help! yx724 J.A.F. By Jafsupport.com 7 06-10-2009 04:25
my n78 phone does not start up... help! yx724 Nokia Base Band 5 ( BB-5 ) 3 05-08-2009 20:09
Page generated in 0.34647 seconds with 10 queries
