01-09-2008, 11:10 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: West Jerusalem
Member: 280342 Status: Offline Thanks Meter: 73 | BB5_v031 nokia 6300 PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2382000000000000 Block 1: CLOSED Type 5 Data: 23820F Block 2: CLOSED Type 5 Data: 23830F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail.:conf used: Reading again SP Locks ... ERROR: 11160001 ERROR: 30020091 |
01-09-2008, 14:41 | #5 (permalink) |
Member: 280342 Status: Offline Thanks Meter: 73 | SP LOCK status: Config Key: 2382000000000000 Block 1: OPEN Type 5 Data: 23820F Block 2: OPEN Type 5 Data: 23830F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull problem cable thank all shadigsm |
01-09-2008, 14:46 | #6 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Palestine Age: 40
Member: 26041 Status: Offline Thanks Meter: 160 | Quote:
Gongratulation MR.SHADI Good Work as Usuall . Best Regards. | |
01-10-2008, 00:52 | #9 (permalink) | |
Freak Poster Join Date: Nov 2007
Member: 627885 Status: Offline Thanks Meter: 27 | Quote:
01-10-2008, 20:27 | #11 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 290637 Status: Offline Thanks Meter: 24 | |
6300 mic dead nokia 6300 after removing fascia-L2104 seems damaged | dnalevy | Nokia Hardware & Hardware Repair | 6 | 02-24-2009 15:49 |
Trouble Unlocking 6300 With BB5 Box - Nokia 6300 Using Test Point Jig- Please Help :) | dave.cullen | BB5BOX | 7 | 02-04-2008 09:23 |
nokia 6300 and nokia 6131 unlock succefuly | dindou78 | BB5BOX | 0 | 11-14-2007 20:14 |
@Saras Plz Add New Nokia BB5 Phones Flashing Like Nokia 6300,5700,E62,N93,N93i etc. | NadeemShahzad | HWK | 25 | 08-03-2007 13:26 |
Nokia Nokia 6300 service cable working for ufs3,Jaf...and NSPro Zxxx Adapter | Tele-way | Main Sales Section | 0 | 03-17-2007 09:34 |
