10-17-2007, 01:05 | #91 (permalink) |
No Life Poster Join Date: Sep 2005 Location: manchester, uk
Member: 177730 Status: Offline Thanks Meter: 11 | |
10-17-2007, 14:43 | #92 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Portugal
Member: 352591 Status: Offline Thanks Meter: 23 | I have this same error first "dipu" and what i only did was updating the driver with box conected. i also have setool/polar/scard etc, and dinīt uninstall them. and my BB5 works perfect too. But maybe it depends on the pc . B.R. |
10-17-2007, 15:01 | #94 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Quote:
YOU'RE 100% WRONG. DRIVER CONFLICT ? = 100% YOU'RE WRONG NEW COMPUTER ? = YOU MEAN EVERY BOX WITH 1 COMPUTER ? = 100% YOU'RE WRONG MEAN = YOU DON'T KNOW HOW TO SOLVE PROBLEM WITH ALL DRIVER FOR EVERY BOX ON 1 COMPUTER 100% - I DON'T TRUST YOUR SOLUTION. br RNC_EBM DO IT FOR THE FIRST TIME, FAILURE IS NOT AN OPTION | |
10-17-2007, 15:57 | #95 (permalink) |
Insane Poster Join Date: Apr 2006 Location: Brazil
Member: 253798 Status: Offline Thanks Meter: 2 | Help... I have a problem with Smartcard I have a problem with Smartcard > ERROR : cannot connect to BB5 Box Smartcard Subsystem . i am change the usb cable many times,whats problem ? Tiago |
10-17-2007, 17:14 | #96 (permalink) |
Member: 177730 Status: Offline Thanks Meter: 11 | i do know how to manage all driver in 1 computer, but bb5 doesnt suit into my computer with other drivers. Cable is not a fact for that error, certainly!! i use seperate computer with same cable that works. Not only with mine but with friends too so cable solution is not a good solution. My solution is for newbie like me. You may be a maestro into GSM unlocking but cable solution is not a correct solution. just ask urself why the same cable work fine with a computer wich not contain any other smartcard driver Driver do conflict each other as you know the case of USTpro2 driver. It must install after all other driver installed...so driver is a fact not the cable. |
10-17-2007, 17:28 | #97 (permalink) | |
MEAN = YOU DON'T KNOW HOW TO SOLVE PROBLEM WITH ALL DRIVER FOR EVERY BOX ON 1 COMPUTER & 1 OPERATING SYSTEM & 1 PARTITION br RNC_EBM | |
10-17-2007, 17:45 | #98 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Copenhagen, Denmark Age: 59
Member: 51434 Status: Offline Thanks Meter: 16 | ERROR: Cannot Connect to BB5 Box SmartCard SubSystem Hi, I also have this problem. Computer do not ask for USB Smart Card Reader - driver..?? why not ? I have try to install the box on 2 diff. computeres, but it's same problem. br Henrik |
10-17-2007, 19:43 | #99 (permalink) | |
Member: 253798 Status: Offline Thanks Meter: 2 | Quote:
It was worth our friend's clue Karyn, it worked 100% Tiago | |
10-17-2007, 19:51 | #100 (permalink) | |
Freak Poster Join Date: May 2006
Member: 279120 Status: Offline Thanks Meter: 14 | Quote:
10-18-2007, 23:11 | #101 (permalink) |
Junior Member Join Date: Oct 2007
Member: 612450 Status: Offline Thanks Meter: 0 | i have the same problem "Cannot Connect to BB5 Box SmartCard SubSystem" 1. i have 4 usb cables 2. i have a clean computer just win xp and some music ang games 3. i have instal and reinstall sw and tun off comp and nothing when te bb5box is connected has 2 red light than botton blue and upper green pleas can anybody help me |
10-19-2007, 10:11 | #102 (permalink) |
Junior Member Join Date: Mar 2006
Member: 252211 Status: Offline Thanks Meter: 1 | SAME problem for me..! 11 usb cable..in 6 FREE PC'S ,hundred time install drivers,it's impossible! i was open the box,i change sim into the box,i controll at microscope but nothing.in my PC i have a usb BB5Box hors controller and one NO recognized device whitout driver and NO aggionable! maybe box is damaged! |
10-19-2007, 16:01 | #103 (permalink) |
Member: 612450 Status: Offline Thanks Meter: 0 | Ok now the box works!!! My friend has the bb5box to and it works on hic comp, than we connect my bb5box on his cable on his comp end the error was still here. than we try his box on my comp and his box again works we just change bb5box not usb cable or drivers !! than we oppen my bb5box and clean it with alcohol and we remove and clean smart card than put it back put all together now it works on all 4 comp and 3 of them has setool ust pro jaf ... and the one (mine) is clean just bb5box we didnt put new driwers on comp we just connect the box maybe u can try with that br zan |
10-20-2007, 20:38 | #104 (permalink) |
Freak Poster Join Date: Feb 2003 Location: England,Birmingham Age: 36
Member: 23511 Status: Offline Thanks Meter: 10 | correct solution solution is simple all you have to do is open the box up take out smart card clean it and make sure it is in properly then put box back together it will work 100% ,this is normally the case as in travel of the box the smart cards gets loose from its cage enjoy |
10-21-2007, 01:47 | #105 (permalink) |
Member: 177730 Status: Offline Thanks Meter: 11 | JUST use latest driver, by choosing manually when computer search driver. then use Use Disk, then choose the inf. file from Smart card ftdi driver then Update smart card driver by choosing same manuel method of choosing driver works like charm With ANY USB cable, With Any smart card driver previously installed. enjoy!! |
error can not connect to bb5 box fbus subsystem solution | bart simms | BB5BOX | 4 | 11-01-2008 21:34 |
nokia 6300 Connecting to BB5 Box | simlock | BB5BOX | 8 | 01-15-2008 21:26 |
ERROR: 200100002 -- ERROR: Cannot connect to BB5 Box FBUS Filesystem | loki07 | BB5BOX | 7 | 12-06-2007 04:19 |
Box Usage 100% = "Cannot Connect to BB5 Box SmartCard SubSystem"??!! | equinoks | BB5BOX | 8 | 11-30-2007 01:56 |
Cannot connect to BB5 box Fbus Subsystem | Mobilab | BB5BOX | 0 | 09-27-2007 17:31 |
