09-26-2007, 16:51 | #1 (permalink) |
Freak Poster Join Date: Jul 2004 Location: JATT LABLE Age: 43
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | can not unlock 6300 with bb5 ............ log befor unlocking Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.70_24-01-07_RM-217_(c)_Nokia. IMEI: 35xxxxxxxxxxx SP LOCK status: Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries after pressing unlock n tuching tp points Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.70_24-01-07_RM-217_(c)_Nokia. IMEI: 358xxxxxxxxxx SP LOCK status: Block 1: CLOSED Type 5 Data: 23430F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-217_358052011334884_Locked_Keycnt_0_Fbuscnt_0__V_0 4.70_24-01-07_RM-217_(c)_Nokia..bin already exist Checking if model/version is supported for unlock ... Set Full Factory Defaults ... Full Factory Defaults set OK Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. done that so many times |
09-26-2007, 18:53 | #2 (permalink) |
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | 6300 .........what to do now hmmmmmmmmmm chip set up not supported hi i have most phones with chip "SEC 728 SF75 K5G5629 ATD" cant unlock |
Can not unlock 6300?????? | joer | JAF No Tp Unlocker by Cinek | 5 | 10-15-2009 08:39 |
successfully unlock 6300 with bb5+ king crack | MOBIL CLINIC | BB5KING | 2 | 04-07-2009 05:19 |
Trouble Unlocking 6300 With BB5 Box - Nokia 6300 Using Test Point Jig- Please Help :) | dave.cullen | BB5BOX | 7 | 02-04-2008 09:23 |
can not unlock 6300 v4.71 SEC 740 SF75 | div_raj | J.A.F. V-SPEC | 1 | 01-23-2008 13:23 |
