12-03-2007, 07:01 | #16 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Quito Ecuador
Member: 50969 Status: Offline Thanks Meter: 56 | Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v38.1_19-01-07_RM-133_(c)_Nokia. IMEI: 352758010580782 SP LOCK status: Config Key: 7400000053632980 Block 1: CLOSED Type 5 Data: 74000F Block 2: CLOSED Type 5 Data: 732123 Block 3: CLOSED Type 5 Data: 71606F Block 4: CLOSED Type 5 Data: 73002F Block 5: CLOSED Type 5 Data: 72207F Block 6: CLOSED Type 5 Data: 74807F Block 7: CLOSED Type 5 Data: 21407F Block 8: CLOSED Type 5 Data: 21402F Block 9: CLOSED Type 5 Data: 33403F Block 10: CLOSED Type 5 Data: 71402F Block 11: CLOSED Type 5 Data: 70403F Block 12: CLOSED Type 5 Data: 70604F Block 13: CLOSED Type 5 Data: 71030F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Reset phone in TEST mode ... Full Factory Defaults set OK Skip autobackup of PM 308 Autobackup file: RM-133_352758010580782_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v38.1_19-01-07_RM-133_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-133_352758010580782_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v38.1_19-01-07_RM-133_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 7400000053632980 Block 1: CLOSED Type 5 Data: 74000F Block 2: CLOSED Type 5 Data: 732123 Block 3: CLOSED Type 5 Data: 71606F Block 4: CLOSED Type 5 Data: 73002F Block 5: CLOSED Type 5 Data: 72207F Block 6: CLOSED Type 5 Data: 74807F Block 7: CLOSED Type 5 Data: 21407F Block 8: CLOSED Type 5 Data: 21402F Block 9: CLOSED Type 5 Data: 33403F Block 10: CLOSED Type 5 Data: 71402F Block 11: CLOSED Type 5 Data: 70403F Block 12: CLOSED Type 5 Data: 70604F Block 13: CLOSED Type 5 Data: 71030F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 7400000053632980 Block 1: OPEN Type 5 Data: 74000F Block 2: OPEN Type 5 Data: 732123 Block 3: OPEN Type 5 Data: 71606F Block 4: OPEN Type 5 Data: 73002F Block 5: OPEN Type 5 Data: 72207F Block 6: OPEN Type 5 Data: 74807F Block 7: OPEN Type 5 Data: 21407F Block 8: OPEN Type 5 Data: 21402F Block 9: OPEN Type 5 Data: 33403F Block 10: OPEN Type 5 Data: 71402F Block 11: OPEN Type 5 Data: 70403F Block 12: OPEN Type 5 Data: 70604F Block 13: OPEN Type 5 Data: 71030F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull Nokia127 |
12-04-2007, 06:11 | #19 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: I N D I A
Member: 413644 Status: Offline Thanks Meter: 10 | Quote:
I had done already 4 pice of 6233 & 3 pice of 6280 without microscope . actually anyone can do N73 & N80,in our institute trainees are doing the same. It's not a big thing, if you can............, try 6233 without microscope and post the result........................ | |
12-05-2007, 07:36 | #23 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Brazil
Member: 232960 Status: Offline Thanks Meter: 419 | I win... Quote:
I can do it in first try w/o microscope, with 3 eyes closed, 5 arm behind my back, singing and dancing French camcam, while I disassemble another !! Well....I started to do this after swimed 15 minutes in the river thames here in london..... | |
12-11-2007, 14:42 | #28 (permalink) | |
Insane Poster Join Date: Jun 2005
Member: 151965 Status: Offline Thanks Meter: 4 | Quote:
I can unlock BB5 without computer or electricity I use hydrogen fuel cells with an old abacus and instead of using my eyes I have a goat & a chicken they then use telepathic waves to tell me when to press the data switch oh I can do this whilst having a shower | |
12-11-2007, 19:33 | #29 (permalink) | |
No Life Poster Join Date: Apr 2004 Age: 43
Member: 61557 Status: Offline Thanks Meter: 130 | Quote:
my friend do you have different test point? can you pls post it here it will b a great help for all of us | |
i can unlock n73 without microscope | daos2007 | BB5BOX | 18 | 01-03-2008 05:48 |
N73 unlocked Sucessfully Without Micro here !! | .:Shorbagy Team:. | BB5BOX | 2 | 12-29-2007 00:59 |
More 2 N73 Unlocked W/o Microscope for a new User | kades | J.A.F. V-SPEC | 1 | 11-23-2007 16:17 |
N73 Successfully Unlocked without MicroScope ! | .:RoMeO:. | BB5BOX | 16 | 11-11-2007 02:02 |
6151 Unlock Successfull Without Microscope | shahzaadbutt | MT-BOX | 7 | 10-17-2007 12:18 |
