10-10-2007, 17:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | Problem To Unlock Atd And Spnssion Chips On 6300 I AM HAVING PROBLEMS TO UNLOCK 6300 V 4.71 AND V5.00 WITH SPANSSION CHIP AND V 5.00 ON ATD CHIP ATB CHIPS R UNLOCKING FINE Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.00_27-04-07_RM-217_(c)_Nokia. IMEI: 3XXXXXXXXX SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-217_XXXXXXXXXZX_Locked_Keycnt_0_Fbuscnt_10__V_05.0 0_27-04-07_RM-217_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-217_XXXXXXXXX_Locked_Keycnt_0_Fbuscnt_0__V_05.00_2 7-04-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 5000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. WHILE ATB CHIP Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.71_28-02-07_RM-217_(c)_Nokia. IMEI: XXXXXXXXX SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_XXXXXXXXX_Locked_Keycnt_0_Fbuscnt_0__V_04.71_2 8-02-07_RM-217_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-217_XXXXXXXXXX_Locked_Keycnt_0_Fbuscnt_0__V_04.71_ 28-02-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 5000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull |
10-11-2007, 08:44 | #2 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | it s very strange i had 11 6300s 2 of them with ATD chipset v5.00 ONE OF THEM UNLOCKED BUT ONE OF THEM FAILED 1 of them with SPANSION V4.71 FAILED ALSO UPGRADED TO V5.00 BUT FAILED, TRIED BY SELECTING ALL 3 CHIPS BUT FAILED 8 of them with ATB chipset 7 of them unlocked without any problem but one of them(v4.71) just giving errors Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.71_28-02-07_RM-217_(c)_Nokia. IMEI: 356401016779225 SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 10 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_xxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_10__V_04.71 _28-02-07_RM-217_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-217_3xxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_04.71 _28-02-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. @BB5 BOX TEAM COULD U LOOK INTO THAT PLEASE COZ UPTO V22 I UNLOCKED EVERY SINGLE ONE OF THEM BR |
10-11-2007, 08:57 | #3 (permalink) |
Product Manager Join Date: Sep 2007
Member: 588059 Status: Offline Thanks Meter: 47 | 1. There was not any changes on unlocking part of software from v22 2. You STILL can use older software even with updated box firmware, just new models added will not work and report not supported. 3. I supose there is some hardware/pcb problems with this 6300 who not worked. Try to solder some pads over testpoints pcb, or try to inspect with an microscope testpoints areas befor any soldering on this for any damages on pcb on this areas. |
10-11-2007, 09:35 | #4 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | continuing having problems with spansion chipset here s another 6300 with spansion chip and tried by selecting all 3 chips but failed tried delaying and non delaying method, nothing s working Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.71_28-02-07_RM-217_(c)_Nokia. IMEI: xxxxxxxxxxxxxxx SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 5 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-217_xxxxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_5__V _04.71_28-02-07_RM-217_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-217_xxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_0 4.71_28-02-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 5000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. |
10-11-2007, 09:40 | #5 (permalink) | |
Member: 588059 Status: Offline Thanks Meter: 47 | Did you read my post??? Quote:
10-11-2007, 09:44 | #6 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | ONE WITH ATB CHIP V4.71 IT FAILED EARLIER SO I UPGRADED TO V5.00 AND IS UNLOCKED IN FIRST TRY Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_04.71_28-02-07_RM-217_(c)_Nokia. IMEI: xxxxxxxxxxxxxxx SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 5 wrong tries from max. 10 tries Skip autobackup of PM 308 Autobackup file: RM-217_xxxxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_5__V _04.71_28-02-07_RM-217_(c)_Nokia..bin already exist Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-217_xxxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_0__V_0 4.71_28-02-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 5000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number: 3 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 4 Sending SP code: #pw+012345678901234+7# Response byte: 14 Try number: 5 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 6 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 7 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 8 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 9 Sending SP code: #pw+012345678901234+7# Response byte: 08 Try number: 10 Sending SP code: #pw+012345678901234+7# Response byte: 08 Unlock fail. Please try again. AFTER UPGRADING Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-217 Version: V_05.00_27-04-07_RM-217_(c)_Nokia. IMEI: xxxxxxxxxxxxxxx SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 3 wrong tries from max. 10 tries Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-217_xxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_3__V_05.0 0_27-04-07_RM-217_(c)_Nokia..bin Auto Write PM 308 procedure started Searching for backup file with lowest FBUS count ... Finded backup file: RM-217_xxxxxxxxxxxxxx_Locked_Keycnt_0_Fbuscnt_3__V_05 .00_27-04-07_RM-217_(c)_Nokia..bin Writting PM Field 308 Subfield 1 with length 8192 bytes Reset phone ... PM Field 308 Subfield 1 written OK Reading SP Locks after Auto Write PM 308 ... SP LOCK status: Config Key: 2343300000000000 Block 1: CLOSED Type 5 Data: 23433F Block 2: CLOSED Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 3 wrong tries from max. 10 tries Reset phone in TEST mode ... Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Delaying unlock procedure with 5000 miliseconds Try number: 1 Sending SP code: #pw+012345678901234+7# Response byte: 00 Reading again SP Locks ... SP LOCK status: Config Key: 2343300000000000 Block 1: OPEN Type 5 Data: 23433F Block 2: OPEN Type 5 Data: 23486F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Phone unlocked succesfull SORRY TO BE PAIN BR |
10-11-2007, 09:51 | #7 (permalink) |
Member: 588059 Status: Offline Thanks Meter: 47 | 1. You have disabled Full factory settings, that's why this phone worked only after flash upgrade!!! 2. If you said v022 have no problems, USE THIS SOFTWARE and check if problems is from software or from hardware/testpoints !!! |
10-11-2007, 10:17 | #8 (permalink) | |
Member: 91102 Status: Offline Thanks Meter: 34 | Quote:
THANKS I'LL TRY THAT AND POST RESULTS BR | |
10-11-2007, 10:22 | #9 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | SORRY FAILING TO USE OLDER VERSION SOON AS PRESS UNLOCK THIS IS WHAT I GET "Box Firmware 6 required! Please update your box!" UNLESS I DISCONNECT FROM INTERNET PLEASE ADVICE BR |
how to unlock "htc g-1 anroide?on mxkey? | rashidbinu | MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker | 1 | 03-29-2010 16:08 |
Problem to unlock kp215 and LG KP210 | guibra74 | HWK | 1 | 11-05-2009 20:43 |
trying to unlock N95 and 6300 | mainpagul | BB5BOX | 6 | 02-02-2008 20:55 |
How we can tell the difference between ATD and ATB chips in 6300 | wadalhag | BB5BOX | 1 | 09-28-2007 10:11 |
Best place to buy pa and cobba chip | gsmtechnique | Nokia Hardware & Hardware Repair | 0 | 08-13-2002 18:00 |
