08-20-2010, 06:46 | #16 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1263932 Status: Offline Thanks Meter: 181 | |
08-20-2010, 14:58 | #17 (permalink) | |
Junior Member Join Date: Jun 2010
Member: 1328735 Status: Offline Thanks Meter: 15 | Quote:
I also solved the problem with the unlock of firmware 4.02. Many thanks!!! | |
08-23-2010, 03:04 | #19 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1375278 Status: Offline Thanks Meter: 3 | Followed steps from these threads: http://forum.gsmhosting.com/vbb/f456...-02-a-1078191/ http://forum.gsmhosting.com/vbb/f456...0-1-a-1078190/ So thanks to partapmobile, and MPhoneClinic. 1 - I downloaded TinyUmbrella (google it, you'll find a link) 2- Run TinyUmbrella. Click Advanced Option. Select 3Gs 4.01. Select Cydia. Save SHSH. 3 - Same steps as above but Select 3Gs 4.0.2 (cant be too safe) 4 - Edited Local host to say following: 74.208.105.171 gs.apple.com 5 - Rebooted iPhone into Recovery Mode, chose 4.0.1 IPSW And voila, it worked. I know i'm probably not creditable because this is my 4th post, but I had a 3Gs with no SHSH saved ever. Followed these steps and officially downgraded to 4.0.1. |
08-23-2010, 06:32 | #20 (permalink) | |
Member: 1263932 Status: Offline Thanks Meter: 181 | Quote:
08-23-2010, 10:04 | #24 (permalink) | |
Product Manager Join Date: Aug 2008 Location: Under Dark Moon
Member: 849979 Status: Offline Sonork: 100.1603463 Thanks Meter: 923 | Quote:
08-23-2010, 10:50 | #26 (permalink) |
Junior Member Join Date: Sep 2006
Member: 350554 Status: Offline Thanks Meter: 0 | 3gs 4.0.2 unlock is possbl by dwngrdng No bro its possible...if u r 3gs is 4.0.2 just put u r phone in dfu mode and restore u r phone with 4.0.1.the go to jailbreakme.com jailbreak it and unlock with redsn0w...Enjoyy |
08-23-2010, 19:38 | #29 (permalink) |
Member: 1263932 Status: Offline Thanks Meter: 181 | No, that's not possible. Without shsh you cannot downgrade a 3GS anymore after Aug 19. I assume you (or a tool) changed your hosts file and shsh backup was on Cydia. Please look into your hosts file: If you find a line with gs.apple.com, you are using Cydia shsh. And in Cydia on the top it reads what shsh versions are backed up. It probably reads 4.0.1 there. Please check and tell this to the other users to not mislead others. Thanks! |
08-23-2010, 19:40 | #30 (permalink) |
Insane Poster Join Date: Dec 2009
Member: 1181806 Status: Offline Thanks Meter: 5 | Yes..I did and many members did same.. 8/22/2010 20:33:03.703 Asking CYDIA for SHSH blobs for iPhone3GS 4.0.1 (8A306)... 08/22/2010 20:33:15.109 SHSH SUCCESSFULLY saved! [Click Here to Open] 08/22/2010 20:33:15.125 You have saved your SHSH locally and the request was sent to CYDIA. This means that CYDIA DOES have your SHSH. Do NOT bug semaphore about the Cydia home page showing this version. 08/22/2010 20:33:15.140 Caching shsh files... 08/22/2010 20:33:15.156 Found [1] shsh files to cache... 08/22/2010 20:33:15.218 Cached [1] shsh files 08/22/2010 20:33:19.625 Starting TSS service on port 80 08/22/2010 20:33:19.625 TSS Accepting connections... 08/22/2010 20:33:19.640 TSS Server Started! |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
