Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 06-25-2009, 16:58   #16 (permalink)
Member: 1034070
thanks you ......................adel gsm
Old 06-27-2009, 18:45   #17 (permalink)
djkiddrick's Avatar
Member: 645603
Thanks Meter: 89
im having problem to detect the phone with usb and rj45.please help
Old 07-01-2009, 22:40   #18 (permalink)
Member: 966375
Thanks Meter: 7
w395 unlocked ok.
hi, i was having trouble unlocking this phone,i kept getting 'power on button shortly' message but se tools would not go any further.
do not identify first(this what i had been doing) of course its a w395
go to settings
'signed mode' and 'perform full unlock instead of'
use your correct com port and rj cable instead of the dcu cable.
THEN if you wish press identify,then press unlock.
here is my log, please note the 'proceedure was stopped by user' part was because i had the wrong com port assigned !!!!
v0.915038/UNI
CARD SERIAL: 000886XX
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER)
CFG:100000100000000
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS "POWER ON" BUTTON SHORTLY...
PROCEDURE WAS STOPPED BY USER
supported phone was not detected
Can't load ID loader !
Elapsed: 168 secs.
CFG:100000100000000
FAILED TO SETUP PHONE
Elapsed: 56 secs.
CFG:100000100000000
EROM "R7A024" CID: 0001
SOFTWARE CID: 0001
SIMLOCK STATE: "NOT_TAMPERED"
LOADER AID: 0002
LOADER VERSION: "R3A009"
PHONE IMEI:35236203154749
MODEL (from GDFS): W395
FACTORY CXC: 1207-7713 R7A024
CURRENT CXC: 12175563_R1CB009
CURRENT CDA: 1223-4226_R4A
CURRENT FS: 12182023_FS_WESTERN-EUROPE_HS_YO_R1CB009
LANGUAGE: AL
Elapsed: 22 secs.
CFG:100000100000000
SOFTWARE CID: 0001
LOADER AID: 0002
PHONE IMEI:352362031547XX
MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS"
Checking for EROM signature...
Waiting for calculation process...
RESPONSE: "SUCCESS" (2331)
GOT SEED:55D5CE97DAE3D0A6F4F429F2
P96 AUTH PASSED
Unlock DONE
Elapsed: 39 secs.
hope this helps, steve.
Old 07-03-2009, 14:29   #19 (permalink)
OLYMPIOS's Avatar
Member: 93568
Thanks Meter: 44
we must have gredits first thats right ?
Old 07-03-2009, 15:39   #20 (permalink)
Member: 966375
Thanks Meter: 7
credits
yes, this will cost 2 credits per phone.
Old 08-17-2009, 21:08   #21 (permalink)
Member: 220317
Thanks Meter: 2
is it Normal that the remote dongle is not available until 5 days?
i try to unlock a w395 and i always have this message?
17/08/2009 16:06:26 SERVER CREDITS LEFT/USED: 49/11
17/08/2009 16:06:28 CARD COUNTERS: FLASH 101, UNLOCK 110
17/08/2009 16:06:28 Elapsed: 3 secs.
17/08/2009 16:07:09 SIGNED MODE (USING SERVER)
17/08/2009 16:07:09 CFG:10000010000000
17/08/2009 16:07:11 PLEASE ATTACH TURNED OFF PHONE NOW
17/08/2009 16:07:11 PRESS "POWER ON" BUTTON SHORTLY...
17/08/2009 16:07:17
17/08/2009 16:07:17 EROM "R7A024" AID: 0001
17/08/2009 16:07:17 SOFTWARE AID: 0001
17/08/2009 16:07:17 SIMLOCK STATE: "NOT_TAMPERED"
17/08/2009 16:07:18 LOADER AID: 0002
17/08/2009 16:07:23 LOADER VERSION: "R3A011"
17/08/2009 16:07:23
17/08/2009 16:07:23 PHONE IMEI:35236203422095
17/08/2009 16:07:23 MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS"
17/08/2009 16:07:23 Checking for signature...
17/08/2009 16:07:24 Waiting for calculation process...
17/08/2009 16:07:24 remote dongle not available
17/08/2009 16:07:25 signature calculation not done,err: 144
17/08/2009 16:07:27 Elapsed: 18 secs.
Old 10-22-2009, 16:40   #22 (permalink)
Member: 837432
Thanks Meter: 19
w395 unock
Originally Posted by imdad-ia View Post
bro u need setting use
1...segned mode< use serever for bypass/csca
2... enable al ternative secuirty bypass
3.... enable preloader secuirty bypass
than prass unlock button
WORKS 100000%%% thank you
Old 10-23-2009, 11:13   #23 (permalink)
Member: 600628
Thanks Meter: 54
How to unlock w395
You need only 1 credit to unlock this phone.Just Check this setting.
1)Signed mode(
2)Enable alternative security bypass
Thats all you dont need anything again no server down,it works 24 hours
Old 10-31-2009, 15:07   #24 (permalink)
Member: 541724
Sonork: 100.1604043
Thanks Meter: 73
unlock with crusier s1 unlocker 100% working tested by me
Old 11-07-2009, 21:00   #25 (permalink)
Member: 209953
Thanks Meter: 2
Smile tanks
woks for me to 100% try
Old 11-07-2009, 21:41   #26 (permalink)
Member: 288521
Thanks Meter: 685
07/11/2009 13:48:43 v0.915053/UNI
07/11/2009 13:48:43 CARD SERIAL: 0
07/11/2009 13:48:43 Loaded 51 flash descriptors
07/11/2009 13:48:59 SIGNED MODE (USING SERVER)
07/11/2009 13:48:59 CFG:100000000000
07/11/2009 13:48:59 No server found.
07/11/2009 13:49:01 CARD COUNTERS: FLASH 510, UNLOCK 420
07/11/2009 13:49:01 Elapsed: 2 secs.
07/11/2009 13:49:02 SIGNED MODE (USING SERVER)
07/11/2009 13:49:02 CFG:100000000000
07/11/2009 13:49:02 SERVER CREDITS LEFT/USED: 19/11
07/11/2009 13:49:04 CARD COUNTERS: FLASH 510, UNLOCK 420
07/11/2009 13:49:04 Elapsed: 2 secs.
07/11/2009 13:49:51 SIGNED MODE (USING SERVER)
07/11/2009 13:49:51 ALTERNATIVE SECURITY BYPASS ENABLED
07/11/2009 13:49:51 CFG:110000000000
07/11/2009 13:49:51 PLEASE ATTACH TURNED OFF PHONE NOW
07/11/2009 13:49:51 PRESS AND HOLD "C" BUTTON...
07/11/2009 13:50:05
07/11/2009 13:50:05 EROM "R7A024" AID: 0001
07/11/2009 13:50:05 SOFTWARE AID: 0001
07/11/2009 13:50:05 SIMLOCK STATE: "NOT_TAMPERED"
07/11/2009 13:50:05 LOADER AID: 0002
07/11/2009 13:50:09 FLASH ID: "0001/307E"
07/11/2009 13:50:09 LOADER VERSION: "R3A011"
07/11/2009 13:50:09
07/11/2009 13:50:09 PHONE IMEI:
07/11/2009 13:50:10 GOT SEED:8456FFBB89024007267F28F8
07/11/2009 13:50:11 P96 AUTH PASSED
07/11/2009 13:50:11 Searching...
07/11/2009 13:50:13 SIMLOCK CHECK FOUND
07/11/2009 13:50:13 Writing...
07/11/2009 13:50:14 Unlock DONE
07/11/2009 13:50:14 Elapsed: 22 secs.
nice and easy
Old 12-30-2009, 10:02   #27 (permalink)
romeoluv56's Avatar
Member: 1170910
Thanks Meter: 76
Sucessfully Unlocked W395
12/30/2009 3:45:17 PM SIGNED MODE (USING SERVER)
12/30/2009 3:45:17 PM CFG:100001000000
12/30/2009 3:45:19 PM PLEASE ATTACH TURNED OFF PHONE NOW
12/30/2009 3:45:19 PM PRESS "POWER ON" BUTTON SHORTLY...
12/30/2009 3:45:45 PM
12/30/2009 3:45:45 PM EROM "R7A024" AID: 0001
12/30/2009 3:45:45 PM SOFTWARE AID: 0001
12/30/2009 3:45:45 PM SIMLOCK STATE: "NOT_TAMPERED"
12/30/2009 3:45:45 PM LOADER AID: 0002
12/30/2009 3:45:50 PM FLASH ID: "00EC/220C"
12/30/2009 3:45:50 PM LOADER VERSION: "R3A011"
12/30/2009 3:45:50 PM PHONE IMEI:35876xxxxxxxxxx
12/30/2009 3:45:50 PM MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS"
12/30/2009 3:45:50 PM Checking for signature...
12/30/2009 3:45:53 PM Waiting for calculation process...
12/30/2009 3:46:05 PM RESPONSE: "SUCCESS" [2331]
12/30/2009 3:46:09 PM GOT SEED:A69AB30A8F01402A268C98F0
12/30/2009 3:46:11 PM P96 AUTH PASSED
12/30/2009 3:46:11 PM Unlock DONE
12/30/2009 3:46:13 PM Elapsed: 55 secs.
Old 02-09-2010, 11:26   #28 (permalink)
Registered User
Member: 115596
Thanks Meter: 1,127
2 credits ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 02-11-2010, 16:22   #29 (permalink)
Member: 23661
Thanks Meter: 29
I just tryd new w395, and cant be done coz LOADER ID its 0004
SOFTWARE AID: 0001
LOADER AID: 0004
phone AID not supported (0004)
Old 03-03-2010, 08:48   #30 (permalink)
noman shakir's Avatar
Member: 812648
Thanks Meter: 80
CFG:110000000000
SOFTWARE AID: 0001
LOADER AID: 0002
PHONE IMEI:35633603******
GOT SEED:4CA643A98B00C024268B00A1
P96 AUTH PASSED
Searching...
SIMLOCK CHECK FOUND
Writing...
Unlock DONE
Elapsed: 45 secs.
successfully unlocked in 1 credit
HOW TO UNLOCK J220i WITH SETOOLS mbond Old Ericsson Phones & Sony Phones 5 02-27-2009 07:42
How to unlock K800i with SETool? fonefingz2003 SETool2 7 12-14-2007 20:58
How To Unlock Db2020 With Setool smkazim Sony Ericsson 3 05-24-2007 01:53
How To Unlock U8110 With Setool SixthSence LG 3 08-03-2005 15:21
Page generated in 0.27138 seconds with 10 queries
