HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
01-11-2015, 04:56 | #61 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,132 | Plug in to otg cable ( pen drive) Boot in to recovery Select install Click path and and select otg or sd card And click the zip file installation will begin and follow the instructions |
The Following User Says Thank You to Mr.3. For This Useful Post: |
01-11-2015, 18:26 | #63 (permalink) |
Junior Member Join Date: Jan 2015
Member: 2325729 Status: Offline Thanks Meter: 0 | My HTC will not read any flash pen via USB ,i did try on another pen and the same,phones are no reading flash pens,and from recovery i don't know why i can't see the SD card to flash custom rom.,i can only flash via fastboot as adb will not see the device |
01-11-2015, 20:18 | #64 (permalink) |
Member: 2325729 Status: Offline Thanks Meter: 0 | I mange to install a custom recovery and make it read sd card , but i need a android version that is stable i have try cm but it's restarting and it's not reading my sim card. Thank you for your help. |
01-11-2015, 21:12 | #65 (permalink) | |
Member: 2325729 Status: Offline Thanks Meter: 0 | Quote:
Installed Sense 6 and it's booting into system and when i unlock the phone i can only see a white screen with HTC then after some time the phone is restarting and it's not working.. | |
01-12-2015, 22:23 | #66 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,346 | Quote:
BR allumts | |
01-13-2015, 16:47 | #67 (permalink) |
Major Poster Join Date: Aug 2014 Location: surat Age: 34
Member: 2235420 Status: Offline Thanks Meter: 9 | i have htc one htl-22 bootloder 1.57 its japan kaddi cariier how cn i unlock this i try some hint on xda developer but not solve show ereor Gaining root access (thanks to Dan's motochopper)...[-] Failed to o er device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. [-] Failed to open framebuffer device. 251|shell@m7wlj:/data/local/tmp $ adb shell adb shell * daemon not running. starting it now on port 5038 * * daemon started successfully * |
01-13-2015, 17:13 | #68 (permalink) | |
BR allumts | |
01-13-2015, 21:05 | #69 (permalink) | |
I have the same device,do you have a working android on it to help me please,i need a copy of the android as i can't find a working version for it. | |
01-14-2015, 12:12 | #71 (permalink) | |
BR allumts | |
01-21-2015, 12:36 | #72 (permalink) |
Member: 2325729 Status: Offline Thanks Meter: 0 | I have try to take it to the repair store but they say they can't fix it,they don't know how to install the android,can somebody please help me out with a working version for this device please? (bootloader) version: 0.5 (bootloader) version-bootloader: 1.57.0000 (bootloader) version-baseband: 1.24.11.0617 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 3.13.970.12 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: HT36TS902032 (bootloader) imei: 990002912422688 (bootloader) meid: 99000291242268 (bootloader) product: m7_wlj (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN0740000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 4169mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-660ef031 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! Can i change the product: m7_wlj with another version to install a europe version on it? |
01-23-2015, 14:23 | #73 (permalink) | |
All CDMA device work in different mode from a GSM/UMTS device, also here you not are in Right section anymore, is been done an exception answering all your question HERE in Non CDMA section. From now, please post you issue in HTC CDMA section, sure you searching can find many more info for you device here: http://forum.gsmhosting.com/vbb/f842/ BR allumts | |
The Following User Says Thank You to allumts For This Useful Post: |
01-26-2015, 18:32 | #74 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Need Help for Unlock HTC One Sprint m7_wls HBOOT 1.57 4.4.2 . S-ON (Rooted+Bootloader Unlocked) I tried with firewater but not working... is there any way or any Box Supported to do S-OFF ?? LOG: E:\>adb reboot E:\>adb devices List of devices attached FA345S904003 device E:\>adb wait-for-device push firewater /data/local/tmp 2004 KB/s (4522136 bytes in 2.203s) E:\>adb shell root@m7wls:/ # su su root@m7wls:/ # chmod 755 /data/local/tmp/firewater chmod 755 /data/local/tmp/firewater root@m7wls:/ # /data/local/tmp/firewater /data/local/tmp/firewater root@m7wls:/ # /data/local/tmp/firewater /data/local/tmp/firewater tmp-mksh: /data/local/tmp/firewater: not found 127|root@m7wls:/ # E:\>fastboot getvar all (bootloader) version: 0.5 (bootloader) version-bootloader: 1.57.0000 (bootloader) version-baseband: 1.01.20.0515 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 5.03.651.3 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: FA345S904003 (bootloader) imei: 990001465329332 (bootloader) meid: 99000146532933 (bootloader) product: m7_wls (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN0720000 (bootloader) cidnum: SPCS_001 (bootloader) battery-status: good (bootloader) battery-voltage: 3924mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-1f512bb6 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.063s is there any way to do S-off for Unlock???? |
01-26-2015, 19:11 | #75 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,346 | @razib143, here you are in Wrong section, this is SPRINT Htc , CDMA device and More, "Firewater" is Down not work anymore for S-OFF M7. Post in right thread, here: http://forum.gsmhosting.com/vbb/f842/ BR allumts |
