Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 09-10-2013, 07:05   #61 (permalink)
Crazy Poster
Member: 1668006
Sonork: 100.1623478
Thanks Meter: 23
Originally Posted by anwer89 View Post
hi , my bb 9900 has very weak wifi signal
when i enter another room my wifi disconnect while my family still connecting
i have changed the antenna but without any benefits
any solution guys ??
some one told me to repair IC PA ,, any idea ??
thanks in advance
Bro,try to repair ic PA and also check in software
Old 09-10-2013, 16:08   #62 (permalink)
Member: 1538948
Sonork: wantole
Thanks Meter: 52
Originally Posted by newaz1991 View Post
first erase your bb and reload firmware with app loader
its 100% HARDWARE ...
Old 09-18-2013, 12:53   #63 (permalink)
Member: 1711176
Sonork: y0zz
how to change imei and pin bb 8520?
Old 09-19-2013, 10:12   #64 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
are sure bro??????????????
Old 09-20-2013, 19:49   #65 (permalink)
wawan tato's Avatar
Member: 1774307
Thanks Meter: 224
yes
ndoro menir ..
Old 09-20-2013, 20:16   #66 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 738
bb 9900 .hang on black berry ,,,,,already erased,,wiped,,,and flashed,,with different ,even with fast instaler,,but same,,also checked,hardware,changed power ic,,same,,
any other solution,,tested,,thx
Old 09-21-2013, 03:08   #67 (permalink)
wawan tato's Avatar
Member: 1774307
Thanks Meter: 224
try with this blackberry repair stuck 75% - Download - 4shared - wawan tato
Old 09-24-2013, 21:21   #68 (permalink)
wawan tato's Avatar
Member: 1774307
Thanks Meter: 224
look at this
The Following User Says Thank You to wawan tato For This Useful Post:
Old 09-25-2013, 19:36   #69 (permalink)
Member: 1737264
i have a blackberry 9860 and its working perfectly not until it started booting 75% and flashed it after that the phone is not detecting BIS since then
Old 09-26-2013, 02:07   #70 (permalink)
wawan tato's Avatar
Member: 1774307
Thanks Meter: 224
try again with bb acces tool ...
may be that is One of many solution ..
Old 09-26-2013, 09:03   #71 (permalink)
EAA
Member: 291355
Thanks Meter: 4
- If you already did nuke, wipe, and then success rapido, meaning corrupt internal memory only.
- But if you have done the above but it still does not work, .. significant damage to the nand flash ..
there are two options to solve it:
1. replace nand flash
2. skip / disable internal memory storage using a file that has been modified.
ps.
nothing one tool that can disable / skip internal memory
if anyone says this tool and it can be .. I think you'll waste a lot of money for things that are uncertain.
if this problem can use finished the tool is , everything is just as corrupt on the issue of internal storage memory .. and do not need tools to solve such problems. enough nuke, wipe and rapido ... all will succeed.
Old 10-01-2013, 09:14   #72 (permalink)
Member: 339335
Blackberry 9810 LCD Issue
Hi Friends
i have an issue with blackberry torch 9810
1. its not getting switch on if i slide it up.
2. after sliding down i need to put battery again it red light ups and its booting normally.
3. now if i use it for while there is no problem. but even in any case the lcd turns off (e.g. lock, time out etc.) it will not turn on again. the lcd light glows but display wont work.
4. now we need to restart if want the display.
Please help me...Its urgent
Thanks
Manish Sharma
Old 12-05-2013, 06:32   #73 (permalink)
Crazy Poster
Member: 1668006
Sonork: 100.1623478
Thanks Meter: 23
Originally Posted by smartguyforever View Post
Hi Friends
Thanks
Manish Sharma
bro,change your flex cable
Old 12-16-2013, 15:52   #74 (permalink)
Member: 1681183
Sonork: 100.1637594
Thanks Meter: 65
Red face blackberry 9900 going to red light and giving error
hi
brother need urgen help
i have 9900 it restart problam
i flash with downgrade version giving reconnect jvm error during
flashing and set going red light blinking
plz any one guide me thanks in advance
Old 12-16-2013, 19:16   #75 (permalink)
Member: 1499477
Sonork: varun
bb 9780, wlan radio mac is 00:00:00:00:00:00, it wont turn on either, i messed up settings in e screen, any help is appreciated.
Page generated in 0.26091 seconds with 9 queries
