BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
09-20-2013, 20:16 | #66 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | bb 9900 .hang on black berry ,,,,,already erased,,wiped,,,and flashed,,with different ,even with fast instaler,,but same,,also checked,hardware,changed power ic,,same,, any other solution,,tested,,thx |
09-26-2013, 09:03 | #71 (permalink) | |
Junior Member Join Date: Jun 2006
Member: 291355 Status: Offline Thanks Meter: 4 | Quote:
- But if you have done the above but it still does not work, .. significant damage to the nand flash .. there are two options to solve it: 1. replace nand flash 2. skip / disable internal memory storage using a file that has been modified. ps. nothing one tool that can disable / skip internal memory if anyone says this tool and it can be .. I think you'll waste a lot of money for things that are uncertain. if this problem can use finished the tool is , everything is just as corrupt on the issue of internal storage memory .. and do not need tools to solve such problems. enough nuke, wipe and rapido ... all will succeed. | |
10-01-2013, 09:14 | #72 (permalink) |
Junior Member Join Date: Aug 2006
Member: 339335 Status: Offline Thanks Meter: 0 | Blackberry 9810 LCD Issue Hi Friends i have an issue with blackberry torch 9810 1. its not getting switch on if i slide it up. 2. after sliding down i need to put battery again it red light ups and its booting normally. 3. now if i use it for while there is no problem. but even in any case the lcd turns off (e.g. lock, time out etc.) it will not turn on again. the lcd light glows but display wont work. 4. now we need to restart if want the display. Please help me...Its urgent Thanks Manish Sharma |
12-05-2013, 06:32 | #73 (permalink) | |
Crazy Poster Join Date: Oct 2011 Location: abudhabi
Member: 1668006 Status: Offline Sonork: 100.1623478 Thanks Meter: 23 | Quote:
12-16-2013, 15:52 | #74 (permalink) |
Banned Join Date: Oct 2011
Member: 1681183 Status: Offline Sonork: 100.1637594 Thanks Meter: 65 | blackberry 9900 going to red light and giving error hi brother need urgen help i have 9900 it restart problam i flash with downgrade version giving reconnect jvm error during flashing and set going red light blinking plz any one guide me thanks in advance |
