GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
11-12-2007, 20:57 | #1862 (permalink) | |
No Life Poster Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks Meter: 2,582 | need to download v2.0 Quote:
=============================== http://rapidshare.com/files/67796108...6_7.3.545_.rar | |
11-12-2007, 21:01 | #1863 (permalink) | |
Junior Member Join Date: Oct 2007
Member: 621148 Status: Offline Thanks Meter: 0 | Quote:
11-12-2007, 21:06 | #1864 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Over Here
Member: 613875 Status: Offline Thanks Meter: 61 | Quote:
http://rapidshare.com/files/48685380...d.unsigned.sis | |
11-12-2007, 21:12 | #1865 (permalink) | |
11-12-2007, 21:49 | #1867 (permalink) |
Junior Member Join Date: Dec 2005
Member: 215258 Status: Offline Thanks Meter: 0 | Heres my .csr file http://rapidshare.com/files/69278072/SEAN.rar.html for N95 hope this makes things easier for one of you guys to help. IMEI: 356996017854893 Thanks again Sean |
11-12-2007, 21:58 | #1868 (permalink) | |
Member: 503346 Status: Offline Thanks Meter: 2,582 | problem found Quote:
so right mouse click on it, extract here then you'll have a proper certificate that can sign your apps with.............! | |
11-12-2007, 22:06 | #1869 (permalink) |
Junior Member Join Date: Nov 2007
Member: 629306 Status: Offline Thanks Meter: 0 | Thanks Titan05. I downloaded the file boiren.rar and extracted the file broiren(without extension) using winrar. But when I run signsis on it, I get the error: encryption error, can not read boiren. Could you please try again to post it. My IMEI is 396996013445944. Thanks very much again. |
11-12-2007, 22:21 | #1870 (permalink) | |
Let me try to make one now, it's made with sultan key password 0123456 any file you sign you must use sultan key | |
11-13-2007, 01:34 | #1875 (permalink) | |
Member: 629941 Status: Offline Thanks Meter: 0 | Quote:
Hello, I am a complete newbie on symbian. Worked with windows mobile for ages. Tired of phone problems with that so went to the nokia e90. Only thing i want to have installed is route 66. Went into jungle of signing problems. Landed here.... Is this (Route66.Mobile7.v7.3.545.Multilanguage.S60v3.N95. SymbianOS9.1.Unsigned.Cracked.Read.NFO-BiNPDA.sis) the right file to install? I allready have the signing tools from BU mobiles. Can someone verify if this is the right file to signe? Can someone please be so kind to signe the file for me if it is the right one? After that i try to make the sis myself Thanx in advance My imei is 353659012350225 Here's a cert for you, download BuMobiles signing tools and you will be good. made with sultan key password 0123456 Attached Files353659012350225_leex70.zip (3.7 KB, 9 views) OK, i am having major problems. Tried signing apps 1.0, and 2.0 also. I am quite sure i did everything right. Can someone please check the following for me? -Wich version of route66 should i use for my e90? (v7.3.486 or v7.3.545) -Is it correct that the zip Titan provided me holds a file without extension? and if so, how to handle that file so i can use it with the sign app. -Is the zip ok? -Can i do anything else wrong ? Thanx in advance! Lee I am sorry guys, i really messed up the layout of this post. but hope someone can help me.. | |
Need crack for route 66 mobile 7 for n95 and australia maps. | carulli | Nokia Multimedia | 3 | 04-04-2009 11:14 |
MDictionary v6.7 S60v3 SymbianOS9.x Signed ML and Dictionaries (Update:15.03.09) | aapkae | Nokia Multimedia | 0 | 03-16-2009 10:01 |
Route 66 Wms Latest Uk Maps ??? | markcoopz | GPS devices , Navigators & Maps | 0 | 03-18-2007 13:34 |
Denmark map for TT 5.2 or Route 66 mobile 7 | lordb24 | Nokia Multimedia | 0 | 01-15-2006 21:12 |
Route 66 Mobile 2005 and GPS BT Receiver | fido59 | Nokia Multimedia | 1 | 10-11-2005 07:34 |
