GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
![]() | #1876 (permalink) | |
Junior Member ![]() Join Date: Oct 2007
Member: 621148 Status: Offline Thanks Meter: 0 | Quote:
![]() Can you try if it works? Thanks for all the help | |
![]() | #1877 (permalink) |
Junior Member Join Date: Nov 2007
Member: 630511 Status: Offline Thanks Meter: 0 | Route66 7.3.545 Problems Hi all I have Route66 7.3.545 installed on my n95 but evytime I statr it up ,it goes to the register screen to activate over internet and the it crashes."Mobile 7"Memory full:Close some applications and try again" PS Some help would be appreciated Thanks again |
![]() | #1878 (permalink) |
Member: 629306 Status: Offline Thanks Meter: 0 | I had encrption error when I tried to sign my sis file. I just renamed the file 356996013445944.cer to 356996013445944.cer.rar I request if someone could sign my cer file. Please remove the extension .rar and add then create the certified file by adding the extension. I guess this compressing to a rar file and the de-compressing maybe source of the error. Many thanks. |
![]() | #1879 (permalink) |
Member: 630652 Status: Offline Thanks Meter: 0 | activation failed Hi, I`ve installed Route66.Mobile.v7.3.545 with britain.prm but when i open it I am asked to activate. I choose via internet and enter a 16 digit no. I then get activation has failed. Could someone please help? thanks |
![]() | #1880 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: UK
Member: 503346 Status: Offline Thanks Meter: 2,582 | cert problem Quote:
![]() | #1883 (permalink) | |
Member: 503346 Status: Offline Thanks Meter: 2,582 | new certificate here Quote:
here is your new certificate made with the sultan.key - pass key 0123456 this one is tried and tested by myself too have fun..............! | |
![]() | #1885 (permalink) | |
Member: 503346 Status: Offline Thanks Meter: 2,582 | factory reset Quote:
due to a corrupt file on your phones memory then route 66 icon will appear after you re-install it again.....! | |
![]() | #1888 (permalink) |
Member: 629306 Status: Offline Thanks Meter: 0 | encryption error, not an RSA certificate. Hello BuMobiles, I still get the following error: "Could not verify signature with known algorithm, exiting. encryption error, not an RSA certificate." As you tested yourself, there must be something different on my PC. I copied the certificate file (you posted), sultan.key, route66*sis file, and signsis.exe into a directory and then try the following command: signsis Route66.Mobile.v7.3.545.cracked.unsigned.sis Route66.Mobile.v7.3.545.cracked.signed.sis 356996013445944.cer sultan.key 0123456 from the command line in DOS. I also tried using your tool Sign Your Apps v1.0.exe. But somehow I dont get the signed file. Is it possible that the signed file you created can be sent. Many many thanks for your help. |
![]() | #1890 (permalink) | |
Junior Member ![]() Join Date: Nov 2007
Member: 629941 Status: Offline Thanks Meter: 0 | Quote:
I have the very same problem here! Tried all here too... Please help us out here.... I have the following too Here's a cert for you, download BuMobiles signing tools and you will be good. made with sultan key password 0123456 Attached Files ![]() OK, i am having major problems. Tried signing apps 1.0, and 2.0 also. I am quite sure i did everything right. Can someone please check the following for me? -Wich version of route66 should i use for my e90? (v7.3.486 or v7.3.545) -Is it correct that the zip Titan provided me holds a file without extension? and if so, how to handle that file so i can use it with the sign app. -Is the zip ok? -Can i do anything else wrong ? Thanx in advance! Lee | |
Need crack for route 66 mobile 7 for n95 and australia maps. | carulli | Nokia Multimedia | 3 | 04-04-2009 11:14 |
MDictionary v6.7 S60v3 SymbianOS9.x Signed ML and Dictionaries (Update:15.03.09) | aapkae | Nokia Multimedia | 0 | 03-16-2009 10:01 |
Route 66 Wms Latest Uk Maps ??? | markcoopz | GPS devices , Navigators & Maps | 0 | 03-18-2007 13:34 |
Denmark map for TT 5.2 or Route 66 mobile 7 | lordb24 | Nokia Multimedia | 0 | 01-15-2006 21:12 |
Route 66 Mobile 2005 and GPS BT Receiver | fido59 | Nokia Multimedia | 1 | 10-11-2005 07:34 |
