Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 07-31-2009, 14:03   #1 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
Box is Not IN Needed Mod.How To Solve?
Little Guide For new User.
Download Links to latest installer
http://www.**********/CycloneBoxInstaller.exe
Multiupload.com - upload your files to multiple file hosting sites!
Pls remember to have installed latest installer (http://www.**********/CycloneBoxInstaller.exe), then Auto update module will do the job.
Conect your Box It will ask you For Driver
Install these Driver
After this now open cyclone Box From desktop Shortcut
Click DCT4/WD2/BB5
After this you need to Install Cyclone Box Driver
Other wise You Will See
After instaling These Driver
After These Steps You Can Use Your Box As Normal
If you Still Facing Any Problem The Cyclone Team And Other Expert Member Are Always Here For Your Help
Regards
Nadeem Gondal
The Following 71 Users Say Thank You to NADEEM GONDAL For This Useful Post:
Old 07-31-2009, 16:00   #2 (permalink)
Registered User
Member: 1026187
Sonork: 1585394
Thanks Meter: 46
very very nice info tnx alot
br
shahab sadi
The Following User Says Thank You to Muneer_killer For This Useful Post:
Old 07-31-2009, 18:39   #3 (permalink)
AY29!4LYF's Avatar
Member: 914747
Thanks Meter: 22
thanks alot using from 1st release dnt hav problem
anyway thanks alot
br
Old 08-01-2009, 14:38   #4 (permalink)
Member: 670113
Sonork: 100:1615871
Thanks Meter: 44
Thanks NAD33M Bha! F0R Th!s Us3ful P0st T0 H3lP N3w Us3R
BR .
Old 08-01-2009, 17:59   #5 (permalink)
vmin81's Avatar
Member: 304251
Thanks Meter: 789
i have same problem i apply steps but still same message received
Box Maintenance Error -> No connection was established, or box is not in needed mode
Old 08-01-2009, 18:47   #6 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
if the window on the bottom left corner says main mode, just unplug the box and plug it again and it will go in bootloader mode.
Alex
The Following 6 Users Say Thank You to moulnisky For This Useful Post:
Old 08-17-2009, 17:57   #7 (permalink)
Member: 267789
Thanks Meter: 5
same problem
I have the same problem I went to the Control Panel uninstall all drivers and re-installed still the same problem
The Following User Says Thank You to facoly For This Useful Post:
Old 08-17-2009, 18:09   #8 (permalink)
Member: 575900
Thanks Meter: 3,177
Have You Install The 2nd Driver, Like I Told You Before Hand
Old 08-18-2009, 10:42   #9 (permalink)
Member: 305311
Thanks Meter: 227
same here is not working
Old 08-19-2009, 10:46   #10 (permalink)
Member: 267789
Thanks Meter: 5
not how to install the 2nd driver
Old 08-19-2009, 11:50   #11 (permalink)
Member: 575900
Thanks Meter: 3,177
So Pls Read This Again.
http://forum.gsmhosting.com/vbb/show...46&postcount=1
Old 08-19-2009, 12:20   #12 (permalink)
Member: 878925
Sonork: ;-)
Thanks Meter: 786
when we use new usb-port we need to install all the driver again .
also it's better to use alwes the same port .
Old 08-19-2009, 12:21   #13 (permalink)
Member: 267789
Thanks Meter: 5
there is another way to install the 2nd because found new hardware cyclone box not displayed on my pc
Old 08-19-2009, 12:52   #14 (permalink)
Member: 878925
Sonork: ;-)
Thanks Meter: 786
Yes :
Go to Device manager
Loading...
if the usb driver show like thes
Loading...
Loading...
Now you need to update driver Make thes steps :
Loading...
2
Loading...
3
Loading...
4
5
Loading...
6
Loading...
Now is ok , and redy to work .
now restart the software , and enjoy .
The Following 4 Users Say Thank You to digiphone For This Useful Post:
Old 08-19-2009, 16:28   #15 (permalink)
Member: 267789
Thanks Meter: 5
cyclone box is not present in device manager
The Following 2 Users Say Thank You to facoly For This Useful Post:
problem with my cyclone box.box is not in needed mode samih127 Cyclonebox 18 06-12-2010 06:05
Box is not in needed mode [SOLVED] renren Cyclonebox 2 01-19-2010 22:38
::solve:: box is not in needed mode mr khalid Cyclonebox 6 09-15-2009 08:36
Cyclone team (not connected) box is not in needed mode tims Cyclonebox 17 06-29-2009 03:54
Box is not in needed mode. masterunlock Cyclonebox 5 03-24-2009 16:44
Page generated in 0.25498 seconds with 10 queries
