PHP Code:
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Trying to store Simlock...
Reading Configuration Key...
Hashing...
Reading SHA1-RSA Signature...
Reading SHA1-HMAC Signature...
Storing Simlock...
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
Reading Security Block...
Read Security Block Problem -> Failed to read PM 308, this is critical
Failed to Create RPL from phone -> Failed to read Security Block
RPL backup thread finished, continuing...
Backing up simlock...
MCU Version V ICPR82_11w16.3.11
MCU Date 29-03-12
Product RM-530 (Nokia E72)
Manufacturer (c) Nokia
IMEI 355239031909745
Mastercode 6447267160
Simlock backup OK, saved to RM-530_355239031909745_9142012_81632 PM.SLBackup.PM
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Processing rm530_091.004_prd.core.fpsx (CMT)...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104
CMT_EM_ASIC_ID: 00001040
CMT_EM_ASIC_ID: 00001030
CMT_PUBLIC_ID: 1D90020E12650344C98E23E6322CEEB4A4A22831
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695
CMT_BOOT_ROM_CRC: 3E273BF6
CMT_SECURE_ROM_CRC: 37BE26FA
CMT Ready!
rm530_091.004_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Searching for BootCode: DualLine 32Bit
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5
Flashbus Write baud set to 650Kbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E
Flashbus Write baud set to 5.0Mbits
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00020000-0x0003FFFF, ONENAND
EraseArea[0,CMT]: 0x00060000-0x004DFFFF, ONENAND
EraseArea[0,CMT]: 0x008E0000-0x0E77FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 1.203s
Writing all blocks...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS+PMML Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT LDSP Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 123.828s
Flashing Speed: 7240.62 kBit/S
Restarting MCU...
Processing rm530_091.004_prd.core.fpsx (APE)...
Processing rm530_091.004_41.01_APAC_QW2_prd.rofs2.fpsx (CMT)...
Booting CMT...
CMT Ready!
rm530_091.004_41.01_APAC_QW2_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Certificates OK
EraseArea[0,CMT]: 0x07CC0000-0x0CDBFFFF, ONENAND
Erase taken 0.422s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 66.172s
Flashing Speed: 7314.68 kBit/S
Restarting MCU...
Processing rm530_091.004_41.01_APAC_QW2_prd.rofs2.fpsx (APE)...
Processing rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx (CMT)...
Booting CMT...
CMT Ready!
rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Certificates OK
EraseArea[0,CMT]: 0x0CDC0000-0x0E77FFFF, ONENAND
Erase taken 0.156s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 9.782s
Flashing Speed: 7229.08 kBit/S
Restarting MCU...
Processing rm530_091.004_C00.01_DEFAULT_prd.rofs3.fpsx (APE)...
Processing rm530_091.004_U007.000_prd.uda.fpsx (CMT)...
Booting CMT...
CMT Ready!
rm530_091.004_U007.000_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Certificates OK
EraseArea[0,CMT]: 0x0E780000-0x1F13FFFF, ONENAND
Erase taken 1.406s
TurboCache Loaded!
All blocks written OK! Time taken 17.47s
Flashing Speed: 6730.31 kBit/S
Restarting MCU...
Processing rm530_091.004_U007.000_prd.uda.fpsx (APE)...
Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Certificates OK
EraseArea[0,CMT]: 0x004E0000-0x008DFFFF, ONENAND
Erase taken 0.47s
TurboCache Loaded!
Writing CMT SOS*ENO Certificate...
All blocks written OK! Time taken 3.78s
Flashing Speed: 7044.23 kBit/S
Restarting MCU...
Processing RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
MCU Date 29-03-12
IMEI Spare 3A55320913097904
IMEI SV 3355320913097964F1000000
PSN CFM136975
Product Code 0587035
Basic Product Code 0583552
PSD 0000000000000000
LPSN 0
WLAN MAC 347E39980FD6
RETU 40
TAHVO 00
AHNE 11
HW 0803
Failed to read info -> Failed to read extended info
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
