Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 09-24-2009, 15:46   #151 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
@ emmanueldraper
Which antivirus detects Cyclone installer as virus ?
Old 09-26-2009, 02:51   #152 (permalink)
josetuareg's Avatar
Member: 1107652
Thanks Meter: 11
friends au unlock a n80 with the cyclone provided this information.
help
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.07, (Sep 11 2009 03:35:10, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags
Box Serial Number: C0001606
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: Unknown
Initializing security card...
Card Serial Number: D0000934
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5,03v PASSED
MCU Voltage 3,31v PASSED
Core Voltage 1,76v PASSED
VBAT Voltage 0,87v PASSED
VBAT Voltage 5,02v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Internal Box VPP Enabled
VPP Voltage 5,01v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
MCU Version V 05wk33v42
MCU Date 07-05-07
Product RM-92
Manufacturer (c) Nokia.
IMEI 358361008587457
Mastercode 441217040
IMEI Spare 3A85630180854705
IMEI SV 3385630180854725F7000000
PSN SEJ578472
Product Code 0529378
Module Code 0202689
Basic Product Code 0522205
PSD 0000002200000000
WLAN MAC 0016BC872570
RETU 14
TAHVO 21
AHNE 30
HW 6002
RFIC 17191719
DSP miro_05wk32v42p1
Failed to read info -> Failed to read SP info
Old 09-26-2009, 03:00   #153 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
@ josetuareg
read this post
http://forum.gsmhosting.com/vbb/showthread.php?t=819077
Old 09-26-2009, 05:25   #154 (permalink)
multi_mobile's Avatar
Member: 502659
Thanks Meter: 101
Cyclone Server Send Command Error -> Code: 500, Calculation problem (Unknown)
Failed to Calculate DCT4 RPL -> Server transaction failed
Old 09-26-2009, 11:31   #155 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
@ multi_mobile
 Error -> Code: 500
Server down, try later...
Old 09-27-2009, 23:40   #156 (permalink)
Member: 289850
hi mr cyclone why many problem in BB5 sx4
Old 09-27-2009, 23:59   #157 (permalink)
blolyxx's Avatar
Member: 628359
Sonork: 100.1583762
Thanks Meter: 39
Support Area Launched, Engine Revision: 1.0.0.7918
Started authenthication procedure at 1:57:58 AM
Handling device: [Cyclone Team], [Cyclone Bootloader]
Box Service Tag: 174737D97D0283A64BA057301E51F581
Cyclone Server (1.0.0.485), Cyclone Box Team 2008, 2009 - Ready.
Ticket received, Veryfing it...
Authenthication error -> data error
why i'm don't enter the support
br
matein-3
Old 09-28-2009, 12:24   #158 (permalink)
Member: 635202
Thanks Meter: 10
I already try other solution and try again several times. Instal and reinstal soft driver
But it does not work ie when the box is run and I click on DCT4 ............ 4 LEDs eliminate the box lights up all at the same time ...
Old 09-29-2009, 12:05   #159 (permalink)
josetuareg's Avatar
Member: 1107652
Thanks Meter: 11
thank you friends again, cyclone installed
successfully
Tuareg:
PortuguêsInglês—Detectar idioma—AfrikaansAlbanêsAlemãoÁrabeBielorussoBúlgar oCatalãoChecoChinêsCoreanoCroataDinamarquêsEslovac oEslovenoEspanholEstónioFilipinoFinlandêsFrancêsGa legoGalêsGregoHebraicoHinduHolandêsHúngaroIndonési oInglêsIrlandêsIslandêsItalianoJaponêsLetãoLituano MacedónioMalaioMaltêsNorueguêsPersaPolacoPortuguês RomenoRussoSérvioSuaíliSuecoTailandêsTurcoUcranian oVietnamitaYiddish > InglêsPortuguês—AfrikaansAlbanêsAlemãoÁrabeBieloru ssoBúlgaroCatalãoChecoChinês (Simplificado)Chinês (Tradicional)CoreanoCroataDinamarquêsEslovacoEslov enoEspanholEstónioFilipinoFinlandêsFrancêsGalegoGa lêsGregoHebraicoHinduHolandêsHúngaroIndonésioInglê sIrlandêsIslandêsItalianoJaponêsLetãoLituanoMacedó nioMalaioMaltêsNorueguêsPersaPolacoPortuguêsRomeno RussoSérvioSuaíliSuecoTailandêsTurcoUcranianoVietn amitaYiddish trocar
Old 09-29-2009, 12:07   #160 (permalink)
josetuareg's Avatar
Member: 1107652
Thanks Meter: 11
successfully
Tuareg:
Old 09-29-2009, 23:14   #161 (permalink)
blolyxx's Avatar
Member: 628359
Sonork: 100.1583762
Thanks Meter: 39
After several attempts The result denied
Possible to know what is wrong
br
matein-3
Old 09-29-2009, 23:18   #162 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
when you see: "Cyclone Server Send Command Error -> Code: 500" server down, wait and try later...
Old 09-30-2009, 01:08   #163 (permalink)
blolyxx's Avatar
Member: 628359
Sonork: 100.1583762
Thanks Meter: 39
thank's mr. ptt
but i like when is down 500 user
Old 09-30-2009, 01:13   #164 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Error -> Code: 500 apears when server is down
Old 10-04-2009, 10:07   #165 (permalink)
aiyon_861's Avatar
Member: 586707
Thanks Meter: 129
any solution for this problem???? itry making a donwlod flash file
Welcome to U.S.A! Service hosted by ThePlanet. Enjoy speed. Cyclone Support Interface (c) 2009 Cyclone Box Team
Server Timestamp: 04.10.2009 03:56:17 CDT
Service Status: OK
Ticket Status: Ticket found
Ticket Box SN: C0000FF1
Task Name: GetListing
Parsing files...
Files parsed OK!
Server time taken: 8.8498380184174s
Downloading: rm217__07.30.mcusw
File download error -> Socket Error # 10054
Connection reset by peer.
MANUAL: FIRST StEPS WITH CYCLONE BOX Hell-GSM Cyclonebox 18 08-12-2012 17:51
Cyclone box not instaled CHERIFA Cyclonebox 15 07-02-2009 21:33
6263 Tmobile U.S.A need to flash please help! Team Cyclone box is my first time flash mymiela0419 Cyclonebox 3 05-21-2009 11:28
Welcome cyclone box india + world first vodafone india strom unlock ready chiragp Main Sales Section 0 03-31-2009 07:13
Page generated in 0.22972 seconds with 10 queries
