09-15-2009, 21:30 | #1 (permalink) |
Junior Member Join Date: Jan 2005
Member: 109047 Status: Offline Thanks Meter: 0 | Cant unlock 6630 I am trying to unlock my 6630. Unlock stops here: (with Skip SP Read) Code: ....... RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... BB5 Unlock Failed -> Failed to Boot / Prepare Phone What can i do? This is my first box. I dont know much. Be nice please. Thanks! |
09-15-2009, 22:59 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | just do what is suggested in this thread http://forum.gsmhosting.com/vbb/showthread.php?t=819077 afterward go in the tab bb5/flash and thick where says "skip repower boot" remember to read te PM (tab common/info) before doing click on unlock BR Alex |
09-15-2009, 23:04 | #3 (permalink) | |
Member: 109047 Status: Offline Thanks Meter: 0 | Quote:
I have already deleted the loaders and i have made my self a pm-backup. I still cant unlock the phone.. It does not show any information about locks (Common/Read info). Shows some data but stops with "Failed to read info -> Failed to read extended info". Do i need to have a TMA-adapter? | |
09-15-2009, 23:14 | #4 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | May be not needed.. if the mobile when restarted switches on like it is under battery yes.. you need a tool like tma to correct the BSI value.. if the mobile instead stay off, when the software look for the mobile press power on on the mobile and wait for it being in local or test mode then click on retry. BR Alex |
09-15-2009, 23:17 | #5 (permalink) | |
Some text go by and the screen goes blank. I then get the message in my first post: Code: Preloader running OK, Running Custom Loader... BB5 Unlock Failed -> Failed to Boot / Prepare Phone | |
09-15-2009, 23:23 | #8 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | could be a cable problem.. go this way connect the cable without the TX2 adapter in the tab bb5/flash unthick were says "Use TX2" and retry. BR Alex |
09-16-2009, 00:08 | #10 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | yeah.. you can't never know It is a slow mobile and needs timeout timing longer (Normally to unlock the old mobiles I use a laptop P3 667 mhz) but if it doesn't give you any chance to interact is a quite weird.. Honest I can't give you any more suggestions apart trying using the TMA adapter and using a higher BSI value. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
09-16-2009, 00:11 | #11 (permalink) | |
03-02-2010, 14:19 | #13 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Noise City
Member: 889564 Status: Offline Thanks Meter: 336 | I've got the same problem with one 6630!!!I just can't figure it out...I tried all the tricks that you spoke about,but nothing...Exactly the same thing:the error messages and everything... |
Cant unlock Sony-Ericsson-J132 | rajhcl0 | Infinity-Box | 3 | 03-29-2010 18:28 |
6630 cant unlock?? | sphynxtrix | Nokia Base Band 5 ( BB-5 ) | 10 | 02-21-2008 06:31 |
6630 Cant unlock by Dejan software | sharaz191 | Nokia Base Band 5 ( BB-5 ) | 6 | 07-14-2007 00:42 |
Vodafone cant unlock own 6630 !!! | Hylko | Nokia Base Band 5 ( BB-5 ) | 7 | 01-14-2006 03:15 |
