06-12-2009, 19:11 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Yes, is a little bug of the actual version.. Just thick where says "skip sp info", do the PM back.up and go on with the unlock.. will be ok.. BR Alex |
06-12-2009, 19:58 | #4 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Дніп&#
Member: 33296 Status: Offline Thanks Meter: 20 | MCU Version V 05wk47v61.1 MCU Date 09-07-08 Product RM-133 Manufacturer (c) Nokia. IMEI 359568019879686 Mastercode 7136273032 IMEI Spare 3A95650891786908 IMEI SV 3395650891786978F8000000 PSN SBH144666 Product Code 0529607 Module Code 0202855 Basic Product Code 0527006 PSD 0000002200000000 RETU 15 TAHVO 22 AHNE 30 HW 6000 RFIC 17211721 DSP scarfe_mc.05wk46v50p2 Failed to read info -> Failed to read SP info |
06-12-2009, 20:10 | #6 (permalink) |
Member: 33296 Status: Offline Thanks Meter: 20 | BB5 Unlock Started... MCU Version V 05wk47v61.1 MCU Date 09-07-08 Product RM-133 Manufacturer (c) Nokia. IMEI 359568019879686 Mastercode 7136273032 Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 4292E710480AFD2467E7E2195895F9327C7C40DC APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_ROM_ID: 1DFD66132C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 2360000CF34D0254B0AC54D04179A0E1CA89FF76 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22E800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 5E8D0D504A0902E261268C14FCD8A2C9093523BC APE Boot skipped on user request Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support... Restarting MCU... Booting RAP... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 4292E710480AFD2467E7E2195895F9327C7C40DC APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_ROM_ID: 1DFD66132C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 2360000CF34D0254B0AC54D04179A0E1CA89FF76 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... SP Accepted, doing reset to update block... MCU Version V 05wk47v61.1 MCU Date 09-07-08 Product RM-133 Manufacturer (c) Nokia. IMEI 359568019879686 Mastercode 7136273032 Warning: Failed to read SP Info, Assuming defaults Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 0000000000000000 Simlock Profile Simlock Key Cnt 0 Simlock FBUS Cnt 0 Unlock finished! and with yellow cable phone not work "local" "test" mode, with not yellow cable all ok and phone stil start-up failed and failed to read sp info |
06-12-2009, 20:13 | #7 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Sorry, i cant understand.. you made the job with or without the yellow cable? If you can read the info again (using skip sp info) and post here please BR Alex |
06-12-2009, 20:15 | #8 (permalink) |
Member: 33296 Status: Offline Thanks Meter: 20 | in ufs too: MCU SW : V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. APE Core: APE Var : V 4.0839.42.2.1-05 27-09-2008 RM-133 Prd.Code: 0529607 Bpr.Code: 0527006 Prod.Sn : SBH144666 HW Vers : 6000 APE HW : 1 APE Adsp: 256 EM VILMA: 15 EM BETTY: 22 RFIC Ver: 17211721 DSP Vers: scarfe_mc.05wk46v50p2 IMEI : 359568-01-987968-6 SL Serv : SIMLOCK SERVER VERSION 63 SL Conf : 000-00-00000000000 SL Prof : 0147196A00000000 SL Count: 00 00 SL Data Corrupted Provider: Not Found but in JAF_Nokia_BB5_and_BB5Plus_201_FREE_by_Zulea.exe: Searching for JAF box ... Searching for UFS box ... UFS box detected Box firmware version: 208 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. IMEI: 359568019879686 SP LOCK status: Config Key: 0000000000000000 Provider Key: 0000000000000000 Counters: 0/3, 0/10 Phone is Unlocked Read Phone Info OK |
06-12-2009, 20:29 | #12 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | You must use always the yellow cable when you work with BB5 phones. If you have troubles in getting the local mode try to get it just doing click on "check flashing bus" in the BB5/Flashing Window.. anyway put in the budget to buy a TMA adaptor or some tool similar BR Alex |
N85-1 Failed to read SP info [SOLVED - Thanks Alkhaleejmobile] | said4 | Cyclonebox | 7 | 03-11-2010 21:47 |
N71+reboot+failed to get sp info | blaw | Cyclonebox | 6 | 02-20-2010 17:20 |
E51 -> Failed to read SP info [SOLVED - Thanks PRIORITY] | ebry | Cyclonebox | 3 | 02-16-2010 13:27 |
2610b V 07.04a Failed to read SP info | ebry | Cyclonebox | 5 | 02-12-2010 11:40 |
n70 fail to read sp | ferdie1969 | Cyclonebox | 1 | 10-23-2009 02:54 |
