03-11-2010, 21:15 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | N85-1 Failed to read SP info [SOLVED - Thanks Alkhaleejmobile] please help to resolve this prob Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: C0001AC9 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D200035A Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,06v PASSED MCU Voltage 3,27v PASSED Core Voltage 1,76v PASSED VBAT Voltage 0,51v PASSED VBAT Voltage 5,02v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 5,04v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V ICPR72_09w18.1 MCU Date 19-05-09 Product RM-333 Manufacturer (c) Nokia IMEI 355708020983242 Mastercode 121636646 IMEI Spare 3A55070802892304 IMEI SV 3355070802892304F7000000 CNT v 001_004, 15-10-08, Orange_FR, RM333 PSN SBK765408 Product Code 0560534 Basic Product Code 0555813 PSD 0000000000000000 LPSN 0 WLAN MAC 0022FCD25B44 APE SW 30.019 APE Variant 30.01930.019.001.130.019.53.1 APE Test eno_version APE HW 256 APE ADSP 256 RETU 15 TAHVO 22 AHNE 11 HW 1100 RFIC |Vapaus_4.0 | ??? DSP wmps.ICPR72_09w17_p1 Failed to read info -> Failed to read SP info |
03-11-2010, 21:34 | #5 (permalink) |
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | thans for help Code: Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: C0001AC9 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D200035A Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,99v PASSED MCU Voltage 3,27v PASSED Core Voltage 1,76v PASSED VBAT Voltage 0,71v PASSED VBAT Voltage 5,03v PASSED Box VPP disabled VPP Voltage 0,00v PASSED Internal Box VPP Enabled VPP Voltage 5,01v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Started Phone Security Analysis... MCU Version V ICPR72_09w18.1 MCU Date 19-05-09 Product RM-333 Manufacturer (c) Nokia IMEI 355708020983242 Mastercode 121636646 Reading Security Block... Security block OK and saved to "RM-333_355708020983242_11032010_233252.SecurityBlock.PM" Step 1 : Testing SIMLOCK -- SECURITY PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. If security problem still exists - check CCC and HWC Certificates. -- SECURITY PROBLEM -- Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block WARNING: "10C0000EC16B00524B8BE1F85300AFDDB26FD7CA.C0001AC9" Not Exists, Will read it... Reading CYC file from phone... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 10C0000EC16B00524B8BE1F85300AFDDB26FD7CA CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "10C0000EC16B00524B8BE1F85300AFDDB26FD7CA.C0001AC9" Checking SUPERDONGLE... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking MCU&DSP TIMESTAMPS... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! |
03-11-2010, 21:45 | #7 (permalink) |
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | problem solved my prob solve just unlock it using RPL method thanks and sorry for my trouble # Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: C0001AC9 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D200035A Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,99v PASSED MCU Voltage 3,27v PASSED Core Voltage 1,76v PASSED VBAT Voltage 0,71v PASSED VBAT Voltage 5,03v PASSED Box VPP disabled VPP Voltage 0,00v PASSED Internal Box VPP Enabled VPP Voltage 5,01v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Started Phone Security Analysis... MCU Version V ICPR72_09w18.1 MCU Date 19-05-09 Product RM-333 Manufacturer (c) Nokia IMEI 355708020983242 Mastercode 121636646 Reading Security Block... Security block OK and saved to "RM-333_355708020983242_11032010_233252.SecurityBlock. PM" Step 1 : Testing SIMLOCK -- SECURITY PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. If security problem still exists - check CCC and HWC Certificates. -- SECURITY PROBLEM -- Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block WARNING: "10C0000EC16B00524B8BE1F85300AFDDB26FD7CA.C0001AC9 " Not Exists, Will read it... Reading CYC file from phone... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 10C0000EC16B00524B8BE1F85300AFDDB26FD7CA CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "10C0000EC16B00524B8BE1F85300AFDDB26FD7CA.C0001AC9 " Checking SUPERDONGLE... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking MCU&DSP TIMESTAMPS... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! BB5 Unlock Started... MCU Version V ICPR72_09w18.1 MCU Date 19-05-09 Product RM-333 Manufacturer (c) Nokia IMEI 355708020983242 Mastercode 121636646 Warning: Failed to read SP Info, Assuming defaults Simlock Server SIMLOCK SERVER Simlock Key 0000000000000000 Simlock Profile Simlock Key Cnt 0 Simlock FBUS Cnt 0 Reading Security Block... Security block OK and saved to "RM-333_355708020983242_11032010_233608.SecurityBlock. PM" "10C0000EC16B00524B8BE1F85300AFDDB26FD7CA.C0001AC9 " Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... Simlock ACCEPTED OK ! MCU Version V ICPR72_09w18.1 MCU Date 19-05-09 Product RM-333 Manufacturer (c) Nokia IMEI 355708020983242 Mastercode 121636646 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Time taken 3.938s # |
N71+reboot+failed to get sp info | blaw | Cyclonebox | 6 | 02-20-2010 17:20 |
E51 -> Failed to read SP info [SOLVED - Thanks PRIORITY] | ebry | Cyclonebox | 3 | 02-16-2010 13:27 |
2610b V 07.04a Failed to read SP info | ebry | Cyclonebox | 5 | 02-12-2010 11:40 |
n70 fail to read sp | ferdie1969 | Cyclonebox | 1 | 10-23-2009 02:54 |
N73 start-p failed. Failed to read SP info | dimitron | Cyclonebox | 14 | 06-13-2009 05:13 |
