![]() | #1 (permalink) |
Junior Member ![]() Join Date: Nov 2011 Location: Poland, Rzeszow
Member: 1686794 Status: Offline Sonork: 100.1625585 Thanks Meter: 0 | New Cyclone Key fbus problem help. Please help me, why my Cyclone Key can't read/make backup, rpl cert etc via fbus? It doesent matter what cables I use,GPG UFC PRO or normal fbus 8pin don't work. Same phone same set of cables with other boxes works fine. Some logs from fully working Nokia E51 : Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.12, (Dec 2 2012 13:17:31, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Key Flasher Interface (c) 2012 KarwosLabs Box Serial Number: A0000055 HW Revision: E, Suitable for: Production, Case: Key Casing, MCU Manufacture Time: Unknown Box is activated Started box selftests procedure All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 236.436MB Avaiable Virtual Memory: 1.888GB Avaiable Pagefile: 1.442GB Initializing FBUS... All initialized - Ready to work MCU Version V 200.71.814.1 MCU Date 17-10-08 Product RM-244 (Nokia E51) Manufacturer (c) Nokia IMEI 356795028720758 Mastercode 3541771147 IMEI Spare 3A65970582277005 IMEI SV 3365970582277035F5000000 PPM 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256 PSN SAQ227148 Product Code 0559242 Basic Product Code 0545341 PSD 0000000000000000 LPSN 0 WLAN MAC 0022FD133E10 APE SW 220.34.37 APE Variant 220.34.37220.34.37_v240.04 APE Test rm244EN78100.41.813v034 APE HW 256 APE ADSP 256 RETU 15 TAHVO 22 AHNE 11 HW 0803i, 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256 PCI i, 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256Ą0(220.34.37, 20-10-2008, RM-244, (c)Nokia , UEM 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256Ą0(220.34.37, 20-10-2008, RM-244, (c)Nokia , UPP 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256Ą0(220.34.37, 20-10-2008, RM-244, (c)Nokia , RFIC 17141715 DSP SI07w15PB_08w10 LCD 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256 BT 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256 ADSP Sw 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256 ADSP DevID 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256Ą0(220.34.37, 20-10-2008, RM-244, (c)Nokia , ADSP RevID 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256Ą0(220.34.37, 20-10-2008, RM-244, (c)Nokia , AEM 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256Ą0(220.34.37, 20-10-2008, RM-244, (c)Nokia , Flip MCUSW 220.34.37j 220.34.37220.34.37_v240.04krm244EN78100.41.813v034n256o256Ą0(220.34.37, 20-10-2008, RM-244, (c)Nokia , Simlock Server SIMLOCK SERVER Simlock Key 2600100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 26001F Auto Selecting Flash Files on User Request... Product Code: 0559242 This is Valid BB5 Product No variant found with given Product Code, selecting first one Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 16300115BE710052F03A0B44610B65DFA036B1DC CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Prepare phone failed with message -> Failed to get CMT Configuration Failed to Read All Certificates -> Failed to Boot / Prepare Phone RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... WMDRM Store not supported Reading Security Block... Security block OK and saved to "RM-244_356795028720758_2013-04-19_132859.SecurityBlock.PM" WARNING: "16300115BE710052F03A0B44610B65DFA036B1DC.A0000055" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 16300115BE710052F03A0B44610B65DFA036B1DC CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Prepare phone failed with message -> Failed to get CMT Configuration Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone) Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 16300115BE710052F03A0B44610B65DFA036B1DC CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Prepare phone failed with message -> Failed to get CMT Configuration Failed to Create RPL from phone -> Failed to Boot / Prepare Phone Started Phone Security Analysis... MCU Version V 200.71.814.1 MCU Date 17-10-08 Product RM-244 (Nokia E51) Manufacturer (c) Nokia IMEI 356795028720758 Mastercode 3541771147 Reading Security Block... Security block OK and saved to "RM-244_356795028720758_2013-04-19_133018.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block WARNING: "16300115BE710052F03A0B44610B65DFA036B1DC.A0000055" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 16300115BE710052F03A0B44610B65DFA036B1DC CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Prepare phone failed with message -> Failed to get CMT Configuration Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone) Analyze Security Error -> Failed to obtain Phone Unique Data Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 16300115BE710052F03A0B44610B65DFA036B1DC CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Prepare phone failed with message -> Failed to get CMT Configuration Failed to Read All Certificates -> Failed to Boot / Prepare Phone |
![]() | #2 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2009 Location: kashmir Age: 35
Member: 1134507 Status: Offline Sonork: 100.1607956 Thanks Meter: 201 | Dear Berthal Please post your screen shot after that im able to help uuuuuu Br Jawad Munir Last edited by ptt; 04-29-2013 at 22:36. Reason: Remove the NOT NEEDED QUOTED PART |
![]() | #4 (permalink) |
Member: 1134507 Status: Offline Sonork: 100.1607956 Thanks Meter: 201 | Dear which cable u have use try to change usb pro or cable i think its usb port problem no full power have your usb try use behid of pc usb port and if problem same then post me condition of key i think u drop down your key from height BR JAwad Munir ![]() |
![]() | #5 (permalink) |
Member: 1686794 Status: Offline Sonork: 100.1625585 Thanks Meter: 0 | Ok, ill change USB, btw i'm useing laptop. Cable i change but still same problem, it doesent matter what i use gpg ufc pro or fbus from jaf 8pin still same problem as above. No sorry mate but i don't drop down Cyclone from height, maby reseller, its brand new key maby 7 days in my hands but now i take it out from package. Ill change USB and cables etc and post result later. |
![]() | #8 (permalink) |
Member: 1686794 Status: Offline Sonork: 100.1625585 Thanks Meter: 0 | Yes it's going to Local Mode, Check Flashing Bus : Code: Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 18D0000342D40344D1031870748BDF58BBA72BE6 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Internal Box VPP Enabled External CMT Phone VPP Enabled, Source: Box Internal 5V PAPUBKEYS Hash for CMT: 85F252E351E225CAFC4DFBC8041EABD2823E3500 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Failed to read info -> Phone not detected Failed to read info -> Phone not detected |
![]() | #10 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2013
Member: 1877063 Status: Offline Thanks Meter: 18 | Quote:
I think you need to make your own Thread next time Sir, Peace,,, just an opinion. Sir | |
