03-10-2013, 01:59 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Lille Age: 46
Member: 17451 Status: Offline Thanks Meter: 31 | 5130c contact service [ Solved ] Ive backup RPL and Security Block restored but same problem ... whats happend how to solve this pb... ??? |
The Following User Says Thank You to kasketm For This Useful Post: |
03-10-2013, 02:05 | #2 (permalink) |
Member: 17451 Status: Offline Thanks Meter: 31 | Read info Code: MCU Version V 06.65 MCU Date 01-04-09 Product RM-495 (Nokia 5130 XpressMusic) Manufacturer (c) Nokia IMEI 12345610654321? IMEI Spare 1A32541660452301 IMEI SV 1332541660452331F2000000 PPM V 06.65, 01-04-09, RM-495, (c) Nokia , AE CNT Content: ae_fr_red, V 06.65, 01-04-09, RM-495, (c) Nokia , PSN HML912217 Product Code 0580572 Module Code 0204024 Basic Product Code 0567773 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 1003 RFIC 06540601 DSP ICPR72_09w03 LCD SEIKO BT 2222-143C Failed to read info -> Failed to read SP info Analyze security + SD repair + write PM Code: Started Phone Security Analysis... MCU Version V 06.65 MCU Date 01-04-09 Product RM-495 (Nokia 5130 XpressMusic) Manufacturer (c) Nokia IMEI 12345610654321? Reading Security Block... Security block OK and saved to "RM-495_12345610654321_10032013_020250.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) Additionaly, Checking HWC/CCC Certs... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1DD0010F158C4950EEDB9CA0C26686B5B71965E9 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits HWC Looks OK! CCC Looks OK! Restarting MCU... -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "1DD0010F158C4950EEDB9CA0C26686B5B71965E9.C000192C" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Analyze finished! SX4 Authorization / SD Repair Procedure Started.... "1DD0010F158C4950EEDB9CA0C26686B5B71965E9.C000192C" Exists, That is good... MCU Version V 06.65 MCU Date 01-04-09 Product RM-495 (Nokia 5130 XpressMusic) Manufacturer (c) Nokia IMEI 12345610654321? Reading Security Block... Security block OK and saved to "RM-495_12345610654321_10032013_020323.SecurityBlock.PM" SX4 Status: Authorized [120,0] Written, Length: 88 bytes, Status: OK [120,1] Written, Length: 160 bytes, Status: OK [120,2] Written, Length: 130 bytes, Status: OK [120,3] Written, Length: 112 bytes, Status: OK [308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19 Write PM Finished, Record written OK: 4, Record written NOT OK: 1 |
03-10-2013, 02:13 | #3 (permalink) |
Member: 17451 Status: Offline Thanks Meter: 31 | SelfTest Code: Selftests to proceed: 29 Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEP_X_LOOP_TEST Passed ST_UEM_CBUS_IF_TEST Failed ST_KEYBOARD_STUCK_TEST Passed ST_CAMERA_IF_TEST Passed ST_BACKUP_BATT_TEST Passed ST_LCD_TEST Passed ST_LPRF_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_CURRENT_CONS_TEST Passed ST_RADIO_TEST Passed ST_BACKLIGHT_TEST Passed ST_SIM_LOCK_TEST Failed ST_SECURITY_TEST Passed ST_BT_WAKEUP_TEST Passed ST_HOOKINT_TEST Passed ST_TAHVOINT_TEST Passed ST_BTEMP_TEST Passed ST_IIC_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_SLEEPCLK_FREQ_TEST Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST |
The Following 2 Users Say Thank You to kasketm For This Useful Post: |
03-15-2013, 05:57 | #5 (permalink) |
Insane Poster Join Date: Jan 2011 Location: fastrpl Age: 46
Member: 1486435 Status: Offline Thanks Meter: 25 | you need factory BB5 RPL for repair corrupted imei if have not correct backup. contact me for BB5 RPL file. |
The Following User Says Thank You to fastrpl For This Useful Post: |
