![]() | #31 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | tick "SX4 Bypass" and write PM! It no need server anymore. It will take some time to attach SX4 card, till we have problems with card reader drivers for MS Windoze server 2008, we've ordered new card reader already. |
The Following User Says Thank You to karwos For This Useful Post: |
![]() | #33 (permalink) |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | It is possible. as i posted b4. Tick "SX4 BYPASS" then click "WRITE PM" and write this PM: http://rapidshare.com/files/216333775/n95.pm Your phone should be ok (i assume that your phone is N95 rm-159, not N95 8gb) |
![]() | #34 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Feb 2007
Member: 454648 Status: Offline Thanks Meter: 18 | Is RM - 160 Presents this error: ![]() SX4 Status: Authorized Disconnected from Cyclone Server Bypassing SX4... Booting RAP... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 6233D445300EC442D7A4C5081C149BF94CC132CA APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0A1001128F6B005222E484EFAA6BA0947B7D24AB CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_ROM_ID: A8C1D6713E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.35.0, Algo: XSR 1.5 Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89 Failed to Write PM -> Invalid NPC Found! Magic is BAD! |
![]() | #36 (permalink) |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | In BB5 Security Tab there is *WRITE CERTIFICATE*. Find certificate: 0A1001128F6B005222E484EFAA6BA0947B7D24AB.Sx4Bypass .CMT.NPC.crt and write it |
![]() | #37 (permalink) |
Member: 454648 Status: Offline Thanks Meter: 18 | And where is this "certified"? 0A1001128F6B005222E484EFAA6BA0947B7D24AB.Sx4Bypass .CMT.NPC.crt Where did you bag? Why not let me the steps we have already lost much time with this and does not solve anything. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
The Following User Says Thank You to fagamon For This Useful Post: |
![]() | #38 (permalink) |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Ok, i will clear your situation: 1- your phone is in SX4 bypass mode. You can write any PM you want, use Write PM for this. 2- After writing full PM your IMEI will be 12345678xxxxx, so you need restore it. Normally, SX4 bypass doing it automatically, BUT, if something goes wrong (TX2 - for example), then you need do it again, manually. Simply, CLICK "WRITE CERTIFICATES". It should point to "StoredFiles", where NPC backup is saved automatically. So, find here a file called 0A1001128F6B005222E484EFAA6BA0947B7D24AB.Something .CMT.NPC.crt, select it, so it will be written. Your phone should be OKAY. Anyway, if you will still have problems with finishing that phone, buzz me when are you online, I will connect to your teamspeak as previous, and solve problem. Best regards |
![]() | #43 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,055 | How did you solve this? I've a N95 8gb rm-320 in the same situation... Failed to Write PM -> Invalid NPC Found! Magic is BAD! Try to write Sx4Bypass backup using Write Cert the same using sx4 auth.. BR Alex |
Nokia 6600 "Phone start-up failed. Contact the Retailer" | GMX@cool | WD2 & APE (Symbian Phones) | 73 | 04-24-2013 12:00 |
Nokia 6670 "Phone start-up failed. Contact the Retailer" | nathanlei888 | Twisterflasher | 10 | 04-26-2011 13:13 |
n95 8g after unlock "phone start-up failed contact the retailer" help | khalid0909 | Universalbox | 10 | 05-15-2009 11:38 |
"Phone start-up failed. Contact the retailer" | CHT2000 | Griffin | 5 | 11-05-2007 16:11 |
3650 "phone start-up failed, contact the retailer" with griffin, how??? | watch man | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 03-04-2003 18:59 |
