Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 09-17-2014, 11:12   #1 (permalink)
Member: 226264
Thanks Meter: 3
probleme cyclone box cuonter
hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0005897
HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk44
Initializing security card...
Card Serial Number: D008032E
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5,12v PASSED
MCU Voltage 3,29v PASSED
Core Voltage 1,79v PASSED
VBAT Voltage 0,01v PASSED
VBAT Voltage 5,09v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Internal Box VPP Enabled
VPP Voltage 5,06v PASSED
Box VPP disabled
VPP Voltage 0,02v PASSED
External Box VPP Enabled
VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 0
Lumia No TP is ACTIVATED!
Avaiable Physical Memory: 1.972GB
Avaiable Virtual Memory: 1.888GB
Avaiable Pagefile: 3.819GB
Initializing FBUS...
All initialized - Ready to work
Failed to Read X-Gold LOG2COD File -> XGold Service Counter is 0. UPGRADE YOUR BOX TO CONTINUE USING SERVICE.
i have uprade box correctly and same problme
Old 09-17-2014, 18:33   #2 (permalink)
mubarak2344's Avatar
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 581
uninstall cyclone,
then again install setup and drivers, then make box wizard
try and post results
Old 09-25-2014, 17:17   #3 (permalink)
Member: 873196
Sonork: 4400
hello I have the same problem blackberry counter to zero probe desintalando and installing the software and branding wizard box below to log
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C000135A
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk14
Card Serial Number: D30001B9
Card Firmware Revision: 0109
Card is activated
Box is activated
USB Voltage 4,73v PASSED
VBAT Voltage 0,00v PASSED
VBAT Voltage 4,73v PASSED
Box VPP disabled
VPP Voltage 4,66v PASSED
Box VPP disabled
Box VPP disabled
Lumia No TP is NOT ACTIVATED! (1)
Avaiable Physical Memory: 744.288MB
Avaiable Virtual Memory: 1.860GB
Avaiable Pagefile: 1011.856MB
Old 09-26-2014, 11:35   #4 (permalink)
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 581
uninstall cyclone and delete cyclone folder in c:/program files.......
install latest version,,,,,, install driver............
then open cyclone.exe and make box wizard......
Page generated in 0.11093 seconds with 8 queries
