naseer_mansehra | 12-13-2011 09:48 | N97 mini rm-555 scccessfullyt flash with usb cable Code:
N97 MINI RM-555 SCCCESSFULLYT FLASH WITH USB CABLE
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Nokia/Blackberry Application v01.82, (Nov 12 2011 09:45:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0002EE8
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32
Initializing security card...
Card Serial Number: DF000085
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.14v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 5.11v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
External Box VPP Enabled
VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Credits Left: 100
Avaiable Physical Memory: 1.63GB
Avaiable Virtual Memory: 1.493GB
Avaiable Pagefile: 2.1021GB
Initializing FBUS...
All initialized - Ready to work
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Found 3 products, Filtering BB5 Products - wait...
3 Products left after filtering. Ready.
Retrieving Variants for Product RM-555 - wait...
57 Variants Retrieved
Booting CMT...
[Nokia USB Flashing Generic]: Port opened OK!
Failed to Boot CMT -> Failed to get First Boot Block
Prepare phone failed with message -> Failed to Boot CMT
Sending User Abort Signal...
Phone not detected at USB -> User Abort
Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Proceeding with Recovery Mode...
Booting CMT...
BB5 USB Boot Rom not Detected -> User Abort
Failed to Boot CMT -> No compatible USB devices detected
Recovery Mode Failed, storing Certificates Only
Booting CMT...
Failed to Create RPL from phone -> Failed to Boot / Prepare Phone
RPL backup thread finished, continuing...
Backing up simlock...
Simlock backup problem -> Phone not detected
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Processing RM-555_12.0.110_prd.core.C00 (CMT)...
Booting CMT...
Processing Flash Image Failed -> Failed to Boot CMT
Failed to Process all Image files -> Failed to process RM-555_12.0.110_prd.core.C00
Booting CMT...
Old ROM Detected
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 0900020FEF84005269E0C7DE71BE188550AE26E1
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
RM-555_12.0.110_prd.core.C00, Type: Flash Image, Algo: XSR 1.6, BB5
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.24.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported
RAPIDOv11_XSR17_alg.fg, Type: Algorithm, Rev: 512.11.24.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Box TX2 Data Pin set to: Service Pin 3
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: C49131EB98702B6A39D7F285B1FF2D9BE1D6F863
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND
EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND
EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND
EraseArea[0,CMT]: 0x00D60000-0x0D39FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 1.141s
Writing all blocks...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Block Write Failed -> Failed to write CMT FUR data header and payload at 0x58C4CB
Processing Flash Image Failed -> Failed to write all blocks
Booting CMT...
Booting CMT...
Old ROM Detected
CMT Ready!
TurboCache Loaded!
Failed to add FUR Client -> FUR-USB_CTRL Handshake Not Accepted
Processing Flash Image Failed -> Failed to Initialize FUR Protocol
Booting CMT...
Old ROM Detected
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
Erase taken 1.157s
TurboCache Loaded!
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 100.172s
Flashing Speed: 8872.53 kBit/S
Processing RM-555_12.0.110_prd.core.C00 (APE)...
Processing RM-555_12.0.110_prd.rofs2.V41 (CMT)...
RM-555_12.0.110_prd.rofs2.V41, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x094A0000-0x0C49FFFF, ONENAND
Erase taken 0.266s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 25.78s
Flashing Speed: 9137.22 kBit/S
Processing RM-555_12.0.110_prd.rofs2.V41 (APE)...
Processing RM-555_12.0.110_C01_prd.rofs3.fpsx (CMT)...
RM-555_12.0.110_C01_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x0C4A0000-0x0D39FFFF, ONENAND
Erase taken 0.94s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 0.141s
Flashing Speed: 584.51 kBit/S
Processing RM-555_12.0.110_C01_prd.rofs3.fpsx (APE)...
Processing RM555_12.0.110_uda_14_001.uda.fpsx (CMT)...
RM555_12.0.110_uda_14_001.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x0D3A0000-0x1EF7FFFF, ONENAND
Erase taken 1.484s
TurboCache Loaded!
All blocks written OK! Time taken 23.813s
Flashing Speed: 8124.91 kBit/S
Processing RM555_12.0.110_uda_14_001.uda.fpsx (APE)...
Processing rm555ENOA09w24v0.050.fpsx (CMT)...
rm555ENOA09w24v0.050.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND
Erase taken 0.32s
TurboCache Loaded!
Writing CMT SOS*ENO Certificate...
All blocks written OK! Time taken 2.609s
Flashing Speed: 8706.15 kBit/S
Processing rm555ENOA09w24v0.050.fpsx (APE)...
Restarting MCU...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
[Nokia N97 mini USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version V ICPR72_09w44.18
MCU Date 28-05-10
Product RM-555 (Nokia N97 mini)
Manufacturer (c) Nokia
IMEI 358315035991579
Mastercode 6751474055
IMEI Spare 3A85130553995107
IMEI SV 3385130553995107F8000000
CNT RM555_014_000_M013,
PSN C8C222769
Product Code 0591997
Basic Product Code 0588945
PSD 0000000000000000
LPSN 0
WLAN MAC C8979F2DA315
APE SW v 12.0.110
APE Variant v 12.0.11012.0.110.41.0112.0.110.C01.01
APE Test rm555ENOA09w24v0.050
APE HW 256
APE ADSP 256
RETU 16
TAHVO 22
AHNE 11
HW 5422
RFIC |Vapaus_5.1 | Aura_?.?
DSP gadget_ICPR72_09w43_p1
Simlock Server SIMLOCK SERVER
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished! |
