Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 05-04-2013, 06:17   #2926 (permalink)
MUKESH RAJ's Avatar
Member: 1084080
Thanks Meter: 7,986
Nokia 1616 Phone Lock Done With Cyclone Box
http://img41.imageshack.us/img41/218...ockcuclone.png
Br-MUKESH RAJ
Last edited by ptt; 05-23-2013 at 22:47. Reason: REMOVE [IMG] -- YOU CAN POST TXT LOG OF THE OPERATION AS ALL OTHERS DO
The Following User Says Thank You to MUKESH RAJ For This Useful Post:
Old 05-13-2013, 07:53   #2927 (permalink)
digitalgsm_cora's Avatar
Member: 727888
Thanks Meter: 219
2730 flash successfuly!
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.11, (Nov 10 2012 00:51:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0006C26
HW Revision: B, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2009, wk23 / wk19
Initializing security card...
Card Serial Number: D00B0166
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage    5.05v    PASSED
MCU Voltage    3.29v    PASSED
Core Voltage    1.78v    PASSED
VBAT Voltage    0.01v    PASSED
VBAT Voltage    5.00v    PASSED
Box VPP disabled
VPP Voltage    0.02v    PASSED
Internal Box VPP Enabled
VPP Voltage    4.95v    PASSED
Box VPP disabled
VPP Voltage    0.04v    PASSED
External Box VPP Enabled
VPP Voltage    0.04v    FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 89
Avaiable Physical Memory: 1.1023GB
Avaiable Virtual Memory: 1.890GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
Booting CMT...
CMT_SYSTEM_ASIC_ID:    000000010000022600010006030C192101023000
CMT_EM_ASIC_ID:        00000296
CMT_EM_ASIC_ID:        00000B22
CMT_PUBLIC_ID:        23200218130D8C56739B7B2CFFF1C746E090E2FE
CMT_ASIC_MODE_ID:    00
CMT_ROOT_KEY_HASH:    9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_BOOT_ROM_CRC:    273F6D55
CMT_SECURE_ROM_CRC:    DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
RPL Creation started...
Processing CMT Part...
Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only
Booting CMT...
CMT Ready!
Box VPP disabled
APE Subsystem Not Found
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
CMT PARTNERC Not Found
Restarting MCU...
RPL Saved OK
Booting CMT...
CMT Ready!
Box VPP disabled
CMT NPC Ok
CMT HWC Ok
CMT CCC Ok
CMT R&D Ok
CMT PAPUBKEYS Ok
CMT KEYS Ok
Restarting MCU...
Read all certificates finished
Starting PM read in range 0-512...
Failed to read PM -> Phone not detected
Booting CMT...
CMT Ready!
Box VPP disabled
Restarting MCU...
Booting CMT...
CMT Ready!
Box VPP disabled
Restarting MCU...
Failed to read info -> Phone not detected
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Processing C:\Documents and Settings\All Users\Application Data\Nokia\Packages\Products\...
Found 57 products, Filtering BB5 Products - wait...
36 Products left after filtering. Ready.
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing rm578__10.45.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm578__10.45.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Sending Certificates...
Certificates OK
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0155FFFF, NOR
EraseArea[0,CMT]: 0x01560000-0x0175FFFF, NOR
Waiting 320s for erasure finish...
Erase taken 101.344s
Writing all blocks...
Initializing TurboCache...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 54.438s
Flashing Speed: 3336.26 kBit/S
Restarting MCU...
Processing rm578__10.45.mcusw (APE)...
Processing rm578__10.45.ppm_ee (CMT)...
Booting CMT...
CMT Ready!
rm578__10.45.ppm_ee, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01760000-0x01FFFFFF, NOR
Erase taken 26.125s
TurboCache Loaded!
All blocks written OK! Time taken 12.0s
Flashing Speed: 3686.24 kBit/S
Restarting MCU...
Processing rm578__10.45.ppm_ee (APE)...
Processing rm578__10.45.image_ee_black (CMT)...
Booting CMT...
CMT Ready!
rm578__10.45.image_ee_black, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x02000000-0x0245FFFF, NOR
EraseArea[0,CMT]: 0x02460000-0x03FBFFFF, NOR
Erase taken 168.94s
TurboCache Loaded!
All blocks written OK! Time taken 30.516s
Flashing Speed: 3749.80 kBit/S
Restarting MCU...
Processing rm578__10.45.image_ee_black (APE)...
All images processed OK! Processing post flash tasks...
Post flash tasks finished!
Flashing successfully finished!
Last edited by Mr.3.; 05-13-2013 at 11:31. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 05-16-2013, 22:06   #2928 (permalink)
anrmobile's Avatar
Member: 1680232
Sonork: 100.1611221
Thanks Meter: 214
MCU Version	V 06.88
MCU Date	06-07-09
Product		RM-515 (Nokia 2320 Classic)
Manufacturer	(c) Nokia
IMEI		011974003846832
Mastercode	714650654
IMEI Spare	0A11790430488603
IMEI SV		0311790430488643F0000000
PPM		V 06.88, 06-07-09, RM-515, (c) Nokia            , NCR
CNT		Content: ncr_attus_06thJul09, V 06.88, 06-07-09, RM-515, (c) Nokia            ,
PSN		DNO063233
Product Code	0579480
Module Code	0204047
Basic Product Code	0571673
PSD		0000001800000000
LPSN		0
HW		1500
UEM		4386
UPP		3168
RFIC		0500
DSP		unnithan23061610
LCD		SUEZ
Asic		11
HW Signature	6B7BE205F4A33DD3
Simlock Server	SIMLOCK SERVER
Simlock Key	3101700000000000
Simlock Profile	800000000003000B
Simlock Aux	000B5555
Simlock IMEI	00550119740038468300
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310150
Simlock [2,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310170
Simlock [3,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 311180
Simlock [4,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310410
Simlock [5,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310980
Auto Selecting Flash Files on User Request...
Product Code: 0579480
No flash paths set! Go to Settings -> Paths and set them!
No Flash Datapackage installed for this Phone!
MCU Version	V 06.88
MCU Date	06-07-09
Setting Local Mode...
Local mode Set
Asic		11
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Autodetecting SP Type...
Autodetection Finished
Proceeding with RSA Unlock...
Asking card to sign HW Signature...
Signed OK (17003E6238EE61A050A2851E130C149FE563AE26)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Last edited by ptt; 05-20-2013 at 22:16. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 05-18-2013, 15:44   #2929 (permalink)
speed infotech's Avatar
Member: 449060
Sonork: 100.1670591
Thanks Meter: 260
nokia 114 flesh done
Booting X-Gold via USB...
If PC Can't detect any new device, probably your phone is erased. Do following if needed:
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
[Nokia USB Flashing Generic]: Port opened OK!
X-Gold: Ready, MCU ID Block: 1FB300020303010100FF
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Quantum_Bootloader_10.49_M1S1
[EBL] : Ready
Setting Baudrate to 6500000bps...
Baudrate Accepted (6500000bps)
Flash Chip 0x00898982, Intel, Size: 64MBytes
Processing "rm827__03.04.mcusw_ebl_psi.fls"...
Sending Certificate...
Certificate Accepted
Erasing 0x40000000-0x4001FFFF...
Flashing at 0x40000000...
Flashed 131072 bytes OK
Erasing 0x40040000-0x4005FFFF...
Flashing at 0x40040000...
Erasing 0x40060000-0x4015FFFF...
Flashing at 0x40060000...
Flashed 1048576 bytes OK
Erasing 0x40280000-0x41BBFFFF...
Flashing at 0x40280000...
Flashed 25952256 bytes OK
Erasing 0x43E20000-0x43E5FFFF...
Processing rm827__03.04.ppm_mh1 (XGold2)...
Checking rm827__03.04.ppm_mh1...
Flash file sorted Okay.
1 file(s) embedded into image.
Processing "package_mh1.ppm_ebl_psi.fls"...
Erasing 0x41BC0000-0x421BFFFF...
Flashing at 0x41BC0000...
Flashed 3269028 bytes OK
Processing rm827__03.04.image_mh1_059N0N5 (XGold2)...
Checking rm827__03.04.image_mh1_059N0N5...
Processing "package_mh1_059N0N5.image.fls"...
Erasing 0x421C0000-0x43E1FFFF...
Flashing at 0x421C0000...
Flashed 15597568 bytes OK
Erasing 0x43E60000-0x43F3FFFF...
Setting Factory Defaults...
[Nokia C2-00 USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version V 03.04
MCU Date 20-04-12
Product  RM-704 (Nokia C2-00)
IMEI  355203055901723
Mastercode 163432451
IMEI Spare 3A55020355097102
IMEI SV  3355020355097102F2000000
PPM  V 03.04, 20-04-12, RM-827, (c) Nokia            , MH1
CNT  Content: mh1_059N0N5, V 03.04, 20-04-12, RM-827, (c) Nokia
PSN  8873A05BI
Product Code 059R0J0
Module Code 0205463
Basic Product Code 059Q9D6
PSD  0000000000000000
LPSN  0
HW  2200
RFIC  68
LCD  TPO
BT  19b5-22012
Asic  11
HW Signature 285698DE01E03970
Simlock Key 0010100000000000
Simlock Profile 800000000004000B
Simlock Aux 000B0000
Simlock IMEI 00003552030559017200
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Read info thread finished, continuing...
pinout usb
Last edited by ptt; 05-20-2013 at 22:18. Reason: MOVE TO THE RIGHT PLACE & ADD [CODE] [/CODE] TAG TO THE LOG
The Following User Says Thank You to speed infotech For This Useful Post:
Old 05-22-2013, 18:34   #2930 (permalink)
dampealdany's Avatar
Member: 1308889
Sonork: 100.1608156
Thanks Meter: 266
successfully unlocked nokia 1208 super fast
MCU Version    V 5.06
MCU Date    01-12-08
Product        RH-106 (Nokia RH-106)
Manufacturer    (c) NMP
IMEI        011512001853507
Mastercode    457715567
IMEI Spare    0A11150210585300
IMEI SV        0311150210585340F8000000
PPM        V 5.06, 01-12-08, RH-106, (c) NMP, UB
PSN        RAL299053
Product Code    0562438
Module Code    0203485
Basic Product Code    0560603
HW        9005
UEM        1328
UPP        2292
RFIC        0700
DSP        P06w45.v45
LCD        SDI:NAXv89, S6B33BD
ADSP Sw        p*V 5.06\n01-12-08\nRH-106\n(c) NMP\nub_lta
Asic        11
HW Signature    406E6416E205F12C
Simlock Key    7321010000000000
Simlock Profile    8000000000010002
Simlock IMEI    00000115120018535000
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Simlock [1,1]    State: CLOSED    Type: 7FFF6F07FFFFFFFF @ FC00    Data: 732101
Product Code: 0562438
MCU Version    V 5.06
MCU Date    01-12-08
Local mode Set
Asic        11
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Signed OK (6D227F303D912B0DB070E4303AD37EE5F3981A2B)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Last edited by ptt; 05-23-2013 at 22:39. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 05-23-2013, 02:06   #2931 (permalink)
Member: 1308889
Sonork: 100.1608156
Thanks Meter: 266
successfully unlocked nokia 2680s
MCU Version    V 05.28
MCU Date    05-11-08
Product        RM-393 (Nokia RM-393)
IMEI        011740003027735
Mastercode    6763422740
IMEI Spare    0A11470030207703
IMEI SV        0311470030207723F4000000
PPM        V 05.28, 05-11-08, RM-392, (c) Nokia , UB
CNT        Content: comcel_co_grey, V 05.28, 04-02-09, RM-393, (c) Nokia ,
PSN        RFD149918
Product Code    0581503
Module Code    0203727
Basic Product Code    0556745
LPSN        0
HW        4002
UEM        4386
UPP        3162
RFIC        0500
DSP        ICPR72_08w32_UPP
LCD        SEIKO
BT        2222-143C
Asic        11
HW Signature    8705B90D50271D31
Simlock IMEI    00550117400030277300
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Product Code: 0581503
MCU Version    V 05.28
MCU Date    05-11-08
Local mode Set
Asic        11
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Signed OK (1A0C8E4C8FD8F4296ECC1DD77DE979CAE10ED61F)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Last edited by ptt; 05-23-2013 at 22:42. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 05-23-2013, 05:39   #2932 (permalink)
Member: 167260
Thanks Meter: 49
Asha 205 Flashing Done
1st step: need pinout
2nd step: need usb male
http://i225.photobucket.com/albums/d...62rm863rm8.png
3rd step: open Cyclonebox
4th step: add firmware
5th step: click write all flash image
http://i225.photobucket.com/albums/d...trouys/205.jpg
http://i225.photobucket.com/albums/d...rouys/2051.jpg
http://i225.photobucket.com/albums/d...rouys/2052.jpg
bOOOOOmmmm!!
Last edited by ptt; 05-23-2013 at 22:45. Reason: REMOVE [IMG] -- YOU CAN POST TXT LOG OF THE OPERATION AS ALL OTHERS DO
The Following User Says Thank You to kurt_kn For This Useful Post:
Old 05-24-2013, 05:36   #2933 (permalink)
Member: 1308889
Sonork: 100.1608156
Thanks Meter: 266
successfully unlocked nokia 2630
MCU Version    V 03.82
MCU Date    17-07-07
Product        RM-299 (Nokia 2630B (Americas) CABLE 2630)
IMEI        011585004201981
Mastercode    2772115622
IMEI Spare    0A11850540029108
IMEI SV        0311850540029108F7000000
PPM        V 03.82, 17-07-07, RM-298, (c) Nokia, AG
CNT        Content: ag, V 03.82, 17-07-07, RM-298, (c) Nokia,
PSN        RCU786279
Product Code    0554661
Module Code    0203305
Basic Product Code    0544207
LPSN        0
HW        5002
UEM        1328
UPP        3162
RFIC        0500
DSP        GDSP_P06w45.v32
LCD        SUEZ
BT        2222-v77
Asic        11
HW Signature    856237D9D051711F
Simlock Profile    800000000001000B
Simlock IMEI    00550115850042019800
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Product Code: 0554661
MCU Version    V 03.82
MCU Date    17-07-07
Local mode Set
Asic        11
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Signed OK (59E1542C2BC3B179D3E726637036599D9E2AF76D)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Last edited by ptt; 05-24-2013 at 22:34. Reason: ADD [CODE] [/CODE] TAG TO THE LOG --> USE [CODE] [/CODE] TAG WHEN POST THE LOGS !!!!
Old 05-24-2013, 05:44   #2934 (permalink)
Member: 1308889
Sonork: 100.1608156
Thanks Meter: 266
successfully flashed nokia 2630
MCU Version	V 04.20
MCU Date	03-08-07
IMEI		011585004993827
Mastercode	43174673
IMEI Spare	0A11850540998302
IMEI SV		0311850540998302F9000000
PPM		V 04.20, 03-08-07, RM-298, (c) Nokia, UB
CNT		Content: COMCEL COL v1, 27-09-07, RM-299, (c) Nokia,
PSN		RMD801042
Module Code	0203305
LPSN		0
HW		5002
UEM		1328
UPP		3162
RFIC		0500
DSP		GDSP_P06w45.v32
LCD		SUEZ
BT		2222-v101
Asic		11
HW Signature	16C794E84730C959
Simlock IMEI	00550115850049938200
Simlock Key Cnt	0
Simlock FBUS Cnt	0
MCU Version	V 04.20
MCU Date	03-08-07
Mastercode	43174673
PSN		RMD801042
Module Code	0203305
LPSN		0
HW		5002
UEM		1328
UPP		3162
RFIC		0500
DSP		GDSP_P06w45.v32
LCD		SUEZ
BT		2222-v101
Asic		11
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Processing pre-flash tasks...
Pre-flash tasks finished
Booting UPP...
UPP ID: 3162 [HW_UNKNOWN]
rm298__05.61.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Flashbus Write baud set to 100Kbits
u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4
Box VPP disabled
Internal Phone VPP Selected
PLL Factor: 3
FlashChip[0]: 0x0020881C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009221
FlashChip[1]: 0x0020881C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009221
Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514
Flashbus Read baud set to 51Kbits
u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020881C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0,04V
MSID-Crypted: 841BA46F982E17FA210D4D7DA2
MSID-Plain: 2C40BAE900521ABAA8000000
FAID-Crypted: 02238AAC1C5BCE08A18609B5
Flashbus Write baud set to 6.50Mbits
2 Region(s) to erase
Erasing NOR Region [0x01000000-0x0101FFFF]
Erasing NOR Region [0x01020000-0x01C3FFFF]
Erase taken 57.50s
Writing 343 blocks...
All blocks written OK! Time taken 434.962s
Terminating flash session
Box VPP disabled
Booting UPP...
rm298__05.61.image_ub_comco_v1, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 849FD3B06E34A0C5FD436E8E6D
MSID-Plain: D26EBAF100521ABAAA000610
FAID-Crypted: 41287612FF319E63BC6C4102
Erasing NOR Region [0x02000000-0x02DBFFFF]
Erasing NOR Region [0x02DC0000-0x02F9FFFF]
Erase taken 71.121s
File Sector Size: 128kB, Flash Chip Sector Size: 128kB
CNT Convertion not needed
Writing 264 blocks...
All blocks written OK! Time taken 152.319s
Extracting Content Package...
CP Extract Failed -> CP Server not exists
WARNING: Failed to extract CP
Box VPP disabled
Booting UPP...
rm298__05.61.ppm_ub, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 8446B6BC77D5FE7055F4B90805
MSID-Plain: 3E4EBAE900521ABAA9000000
FAID-Crypted: 1A5C0E83B78357F44E8C01EA
1 Region(s) to erase
Erasing NOR Region [0x01C40000-0x01FFFFFF]
Erase taken 16.864s
Writing 86 blocks...
All blocks written OK! Time taken 105.972s
Box VPP disabled
Processing post-flash tasks...
Factory defaults OK
Post-flash tasks finished...
Flash successfully finished!
Last edited by ptt; 05-24-2013 at 22:35. Reason: ADD [CODE] [/CODE] TAG TO THE LOG --> USE [CODE] [/CODE] TAG WHEN POST THE LOGS !!!!
Old 05-25-2013, 02:52   #2935 (permalink)
Member: 1813079
Sonork: tholibul ilmi
Thanks Meter: 19
Smile e63 repair SP LOCK damaged DONE...
i am confused but WOW my phone e63 done
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.1.923
Initializing box...
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B00015D0
Time: 2012, wk01 / 2011, wk27
Box is activated
MCU Voltage    3.28v    PASSED
Core Voltage    1.79v    PASSED
VBAT Voltage    0.48v    PASSED
VBAT Voltage    4.97v    PASSED
Box VPP disabled
VPP Voltage    5.01v    PASSED
Box VPP disabled
XGold/Blackberry Service Running, Counter: 88
Avaiable Physical Memory: 131.516MB
Avaiable Virtual Memory: 1.841GB
Avaiable Pagefile: 1.560GB
Retrieving Variants for Product RM-437 - wait...
Product Directory
Backing up RPL...
Storing Product Code...
Storing PSN...
Storing HWID...
Simlock Store not supported, not a PA_SL2 Phone
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
Reading Security Block...
AM.SecurityBlock.PM"
"0A8000154DB00052590689088514B363E6B3ED53.B00015D0" Exists, That is good...
Storing Additional Data...
Checking Superdongle Key...
Encrypting Superdongle Key...
Storing Superdongle Key...
Checking CMLA Key...
Not Found (SL3 phone?)
Booting CMT...
CMT_SYSTEM_ASIC_ID:    000000010000022600010006400C192101051103
CMT_PUBLIC_ID:        0A8000154DB00052590689088514B363E6B3ED53
CMT_ROOT_KEY_HASH:    C70CB07324056BC66A824347F40DB2D5
CMT_SECURE_ROM_CRC:    3E691FF8
CMT Ready!
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0x0020004000000031, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND
Requested Algorithm: XSR 1.5 (CMT)
FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.12.8.0, Algo: XSR 1.5
TurboCache Loaded!
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
PAPUBKEYS Hash for CMT: D9C25399C696B8549EDCDB1497A950B3A20DDFB6
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Processing rm437_510.21.010_prd.c00 (CMT)...
Booting CMT...
CMT Ready!
rm437_510.21.010_prd.c00, Type: Flash Image, Algo: BB5, XSR 1.5
Flashbus Write baud set to 650Kbits
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00040000-0x007FFFFF, ONENAND
EraseArea[0,CMT]: 0x00A00000-0x0759FFFF, ONENAND
EraseArea[0,CMT]: 0x0F1C0000-0x0F8BFFFF, ONENAND
Erase Partition (CMT)
Erase taken 0.681s
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS*CORE Certificate...
Writing CMT SOS+ROFS Certificate...
All blocks written OK! Time taken 81.748s
Flashing Speed: 6508.78 kBit/S
Restarting MCU...
Processing rm437_510.21.010_prd.c00 (APE)...
Processing rm437_510.21.010_prd.v26 (CMT)...
Booting CMT...
CMT Ready!
rm437_510.21.010_prd.v26, Type: Flash Image, Algo: BB5, XSR 1.5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x05420000-0x0759FFFF, ONENAND
Erase taken 0.260s
TurboCache Loaded!
Writing CMT SOS+ROFX Certificate...
All blocks written OK! Time taken 44.524s
Flashing Speed: 5626.10 kBit/S
Restarting MCU...
Processing rm437_510.21.010_prd.v26 (APE)...
Processing rm437_510.21.010.27U (CMT)...
Booting CMT...
CMT Ready!
rm437_510.21.010.27U, Type: Flash Image, Algo: BB5, XSR 1.5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Erase taken 1.61s
TurboCache Loaded!
All blocks written OK! Time taken 27.269s
Flashing Speed: 6468.70 kBit/S
Restarting MCU...
Processing rm437_510.21.010.27U (APE)...
Processing RM437_ENO_008.07.45_100.71.952.a018.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM437_ENO_008.07.45_100.71.952.a018.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Erase Certificate: SOS*ENO (CMT)
Erase taken 0.50s
TurboCache Loaded!
Writing CMT SOS*ENO Certificate...
All blocks written OK! Time taken 2.223s
Flashing Speed: 5799.27 kBit/S
Restarting MCU...
Processing RM437_ENO_008.07.45_100.71.952.a018.fpsx (APE)...
Factory defaults OK
Reading info...
MCU Version    V ICPR71_09w47.11
MCU Date    14-02-11
Product        RM-437 (Nokia E63)
IMEI        355376046592981
Mastercode    15130626
IMEI Spare    3A55730664959208
IMEI SV        3355730664959218F7000000
PSN        SVM890361
Product Code    0568890
Basic Product Code    0561985
LPSN        0
WLAN MAC    782EEF1A9DFA
APE SW        510.21.010
APE Variant    510.21.010510.21.010_v26
APE Test        v0.a018
APE HW        256
APE ADSP    256
RETU        16
TAHVO        22
AHNE        11
PCI        i510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
UEM        510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
UPP        510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
RFIC        17141716
ADSP DevID        510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
ADSP RevID        510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
AEM        510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
Flip MCUSW        510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
Failed to read info -> Failed to read SP info
MCU Date    14-02-11
Mastercode    15130626
PPM        510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
PSN        SVM890361
LPSN        0
APE SW        510.21.010
APE Test        v0.a018
APE HW        256
APE ADSP    256
RETU        16
TAHVO        22
AHNE        11
HW        0801i510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
LCD        510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
BT        510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
ADSP Sw        510.21.010j 510.21.010510.21.010_v26kv0.a018n256o256
BB5 Unlock Started...
MCU Date    14-02-11
Mastercode    15130626
Warning: Failed to read SP Info, Assuming defaults
Simlock Key    0000000000000000
Simlock Profile
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: RPL Calculation
Asking box to calculate RPL...
Received RPL from Box OK!
Writing Simlock...
BB5 Unlock Failed -> Simlock NOT ACCEPTED ! Maybe is SL3 phone?
Skipping RPL decryption...
Parsing decrypted RPL...
Processing FBUS Part...
Writing Product Code...
Writing PSN...
Writing HWID...
Writing Simlock...
Handling as SL3 Simlock Data
Handling as SIMLOCK1 Format
15 Digits NCK Found
Simlock ACCEPTED OK !
Writing Superdongle key...
Superdongle Key ACCEPTED OK !
Writing CMLA key...
CMLA Key ACCEPTED OK !
Writing WMDRM PD Data...
WMDRM PD Data ACCEPTED OK !
Processing FLASHBUS Part...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Write RPL Finished!
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
MCU Date    14-02-11
Mastercode    15130626
PSN        M2Q432337
Product Code    059B8R1
LPSN        0
APE SW        510.21.010
APE Test        v0.a018
APE HW        256
APE ADSP    256
RETU        16
TAHVO        22
AHNE        11
RFIC        17141716
Simlock Key    2440700000000000
Simlock Profile    0000000000000000
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Failed to Write RPL File -> No RPL File Provided b
Last edited by ptt; 05-30-2013 at 22:29. Reason: ADD [CODE] [/CODE] TAG TO THE LOG --> USE [CODE] [/CODE] TAG WHEN POST THE LOGS !!!!
Old 05-29-2013, 01:22   #2936 (permalink)
Member: 1308889
Sonork: 100.1608156
Thanks Meter: 266
successfully unlocked nokia 5800
[Nokia 5800 XpressMusic USB Phonet]: Port opened OK!
MCU Version	V ICPR72_09w06.2
MCU Date	03-03-09
Product		RM-356 (Nokia 5800 XpressMusic)
IMEI		357988033769220
Mastercode	155367175
Simlock Key	2140700000000000
Simlock Profile	8000000000000000
Simlock Key Cnt	1
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: MCC-MNC	Data: 21407F
Simlock [2,1]	State: CLOSED	Type: MCC-MNC	Data: 21402F
Security block OK and saved to "RM-356_357988033769220_28052013_064922 p.m..SecurityBlock.PM"
"1C00011414EA8A5216D900F5B47C7125C90256BF.C000785D" Exists, That is good...
Selected Unlock Method: NCK Calculation (new method)
#pw+564305792266087+1#
#pw+113036452901830+2#
#pw+193728816673130+3#
#pw+596449510720926+4#
#pw+330043834583236+5#
#pw+767222629937069+6#
#pw+860802207688480+7#
Sending NCK Codes..
NCK[1] - ACCEPTED
NCK[2] - Too fast between tries (bruteforce protection)
NCK[3] - Too fast between tries (bruteforce protection)
NCK[4] - Too fast between tries (bruteforce protection)
NCK[5] - Too fast between tries (bruteforce protection)
NCK[6] - Too fast between tries (bruteforce protection)
NCK[7] - Too fast between tries (bruteforce protection)
MCU Date	03-03-09
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: OPENED	Type: MCC-MNC	Data: 21407F
Simlock [2,1]	State: OPENED	Type: MCC-MNC	Data: 21402F
Simlock NCK	#pw+564305792266087+1#
Unlock finished! Time taken 4.415s
Old 06-03-2013, 09:00   #2937 (permalink)
Member: 943633
Thanks Meter: 10
Nokia 206 flashing done
Initializing box...
Box Serial Number: kkkkkkkk
HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk48
Card Serial Number: D00A01FA
Card is activated
Box is activated
USB Voltage 5.04v PASSED
MCU Voltage 3.30v PASSED
Core Voltage 1.77v PASSED
VBAT Voltage 5.02v PASSED
Box VPP disabled
Box VPP disabled
Box VPP disabled
XGold/Blackberry Service Running, Counter: 99
Avaiable Physical Memory: 1023.540MB
Avaiable Virtual Memory: 1.849GB
Avaiable Pagefile: 1.1018GB
Processing rm872__03.59.mcusw (XGold2)...
Checking rm872__03.59.mcusw...
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected.
Failed to process Image File -> BootROM not detected!
Failed to Process all Image files -> Failed to process Image File
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Quantum_Bootloader_10.53_M1S1
[EBL] : Ready
Processing "rm872__03.59.mcusw_ebl_psi.fls"...
Erasing 0x40280000-0x41A7FFFF...
Flashed 25165824 bytes OK
Processing rm872__03.59.ppm_mh1 (XGold2)...
Checking rm872__03.59.ppm_mh1...
Erasing 0x41A80000-0x420FFFFF...
Flashing at 0x41A80000...
Flashed 5236732 bytes OK
Processing rm872__03.59.image_mh1_059Q245 (XGold2)...
Checking rm872__03.59.image_mh1_059Q245...
Processing "package_mh1_059Q245.image.fls"...
Erasing 0x42100000-0x43E1FFFF...
Flashing at 0x42100000...
Flashed 16646144 bytes OK
[Nokia USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version V 03.59
MCU Date 24-12-12
Product RM-872 (Nokia RM-872)
IMEI 355902059704369
Mastercode 746043021
IMEI Spare 3A55090295073406
IMEI SV 3355090295073406F6000000
PPM V 03.59, 24-12-12, RM-872, (c) Nokia , MH1
CNT Content: mh1_059Q245, V 03.59, 24-12-12, RM-872, (c) Nokia
PSN 8F23B4DBI
Product Code 059R9X1
Module Code 0205283
Basic Product Code 059P5C3
LPSN 0
HW 2300
RFIC 68
LCD TPO
BT 19b5-22012
Asic 11
HW Signature E19C2231B76A9C6B
Simlock IMEI 00003559020597043600
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Last edited by ptt; 06-03-2013 at 22:39. Reason: ADD [CODE] [/CODE] TAG TO THE LOG =====> USE [CODE] [/CODE] TAG WHEN POST THE LOGS !!!! <=====
Old 06-05-2013, 13:56   #2938 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 309
NOKIA 700 FLASHED WITH USB OK
Backing up RPL...
Sending User Abort Signal...
Phone not detected at USB -> User Abort
Booting CMT...
Old ROM Detected
CMT_SYSTEM_ASIC_ID:	000000030000022600010007400C192103032108
CMT_EM_ASIC_ID:		00000C35
CMT_EM_ASIC_ID:		00000C30
CMT_PUBLIC_ID:		98090004FFFB7C409524AEE5334671D17C2048B5
CMT_ROOT_KEY_HASH:	3AB5DB70B45D23F1ADEEBB5734160706
CMT_BOOT_ROM_CRC:	2CAC45E2
CMT_SECURE_ROM_CRC:	3BC33C8B
CMT Ready!
RAPUv21_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5
Waiting for USB Boot ROM Answer...
ROM Ret: 0xFFFD125D
ROM CMT dwAddr: 0x10004FF0
ROM CMT dwLength: 0x00627837
Seems ROM Initialized OK!
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC006000000032, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0060 (Samsung), Size: 1024MBytes, VPP: Not Supported
RAPUv21_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6
TurboCache Loaded!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Waiting for FUR Client become avaiable...
FUR Avaiable!
CMT FUR Ready!
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
PAPUBKEYS Hash for CMT: BD43E84B21F8AC7B9C66EA939355891E2A08044A
Storing NPC...
Storing CCC...
Storing HWC...
Storing PARTNERC...
Restarting MCU...
RPL Saved OK
Processing RM-670_112.010.1404_79u_prd.core.fpsx (CMT)...
Booting CMT...
Old ROM Detected
CMT Ready!
RM-670_112.010.1404_79u_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
ROM Ret: 0xFFFD125D
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND
EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND
EraseArea[0,CMT]: 0x010C0000-0x170FFFFF, ONENAND
EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND
Erase taken 2.360s
TurboCache Loaded!
Writing CMT SOS+PMML Certificate...
Writing CMT SOS+DECOMP Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT SOS+IVE3A Certificate...
Writing CMT LDSP Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
All blocks written OK! Time taken 22.843s
Flashing Speed: 47273.71 kBit/S
Processing RM-670_112.010.1404_79u_prd.core.fpsx (APE)...
Processing RM-670_112.010.1404_01.01_Euro_1_79u_prd.rofs2.fpsx (CMT)...
RM-670_112.010.1404_01.01_Euro_1_79u_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x0D1C0000-0x135BFFFF, ONENAND
Erase taken 0.391s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 8.578s
Flashing Speed: 55441.76 kBit/S
Processing RM-670_112.010.1404_01.01_Euro_1_79u_prd.rofs2.fpsx (APE)...
Processing RM-670_112.010.1404_246.04_default_79u.2012.11_prd.rofs3.fpsx (CMT)...
RM-670_112.010.1404_246.04_default_79u.2012.11_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x01678000-0x0169FFFF, ONENAND
EraseArea[0,CMT]: 0x135C0000-0x170FFFFF, ONENAND
Erase taken 0.281s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
Writing CMT SOS+IVE3B Certificate...
All blocks written OK! Time taken 0.547s
Flashing Speed: 5153.05 kBit/S
Processing RM-670_112.010.1404_246.04_default_79u.2012.11_prd.rofs3.fpsx (APE)...
Processing RM-670_112.010.1404_246.04_default_79u.2012.11.uda.fpsx (CMT)...
RM-670_112.010.1404_246.04_default_79u.2012.11.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
EraseArea[0,CMT]: 0x17100000-0x2E0FFFFF, ONENAND
Erase taken 1.390s
TurboCache Loaded!
All blocks written OK! Time taken 26.0s
Flashing Speed: 50882.10 kBit/S
Processing RM-670_112.010.1404_246.04_default_79u.2012.11.uda.fpsx (APE)...
Restarting MCU...
[Nokia 700 USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version	V 79u_sr2_12w09_4
MCU Date	29-03-12
Product		RM-670 (Nokia 700)
IMEI		357023045093391
Mastercode	5547254170
IMEI Spare	3A75200354903309
IMEI SV		3375200354903319F8000000
PSN		CXE943166
Product Code	059L110
Module Code	0204685
Basic Product Code	059C3Z9
LPSN		0
WLAN MAC	6CE9071342A1
APE SW		112.010.1404
APE Variant	112.010.1404112.010.1404.01.01112.010.1404.246.04
APE Test		RM670_11w30_05_ENO_037
APE HW		256
APE ADSP	256
APE BT		HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.
RETU		35
TAHVO		00
AHNE		21
HW		1003
RFIC		|Alli_4.b.1
DSP		79u_sr2_12w09
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Last edited by ptt; 06-05-2013 at 22:20. Reason: ADD [CODE] [/CODE] TAG TO THE LOG =====> USE [CODE] [/CODE] TAG WHEN POST THE LOGS !!!! <=====
Old 06-07-2013, 17:09   #2939 (permalink)
anrmobile's Avatar
Member: 1680232
Sonork: 100.1611221
Thanks Meter: 214
1661-2b
MCU Version	V 03.70
MCU Date	04-14-09
Product		RH-121 (Nokia 1661)
IMEI		012447009537175
Mastercode	162727111
IMEI Spare	0A21440790351707
IMEI SV		0321440790351727F5000000
PPM		V 03.70, 04-14-09, RH-121, (c) Nokia, UB
PSN		68C8656AI
Product Code	0580796
Module Code	0204020
Basic Product Code	0586754
HW		1509
UEM		1328
UPP		2293
RFIC		0700
DSP		ICPR81_09w10_UPP
LCD		SDI:BOHAIv92, NT39121
ADSP Sw		p*V 03.70\n04-14-09\nRH-121\n(c) NMP\nub_na
Asic		11
HW Signature	DCF62F367A8CE916
Simlock Key	3102000000000000
Simlock IMEI	00000124470095371700
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Simlock [1,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310160
Simlock [2,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310200
Simlock [3,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310210
Simlock [4,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310220
Simlock [5,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310230
Simlock [6,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310240
Simlock [7,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310250
Simlock [8,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310260
Simlock [9,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310270
Simlock [10,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310310
Simlock [11,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310580
Simlock [12,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310660
Simlock [13,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310800
Simlock [14,1]	State: CLOSED	Type: 7FFF6F07FFFFFFFF @ FC00	Data: 310490
Product Code: 0580796
MCU Version	V 03.70
MCU Date	04-14-09
Local mode Set
Asic		11
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Signed OK (E0A8284E39B40C944F1A30A36EEC60F5CFDB6928)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Last edited by ptt; 06-11-2013 at 21:47. Reason: ====> ADD [CODE] [/CODE] TAG TO THE LOG =====> USE [CODE] [/CODE] TAG WHEN POST THE LOGS !!!! <====
Old 06-08-2013, 06:51   #2940 (permalink)
Member: 74814
Thanks Meter: 30
5220 contact service solved with just one click.
hi,
i'm trying to repair 5220 contact service here is log:
before:
MCU Version	V 07.23
MCU Date	17-07-09
Product		RM-411 (Nokia 5220 XpressMusic)
IMEI		35684002xxxxxxx
Mastercode	7643222747
IMEI Spare	3A65480012951204
IMEI SV		3365480012951244F0000000
PPM		V 07.23, 17-07-09, RM-411, (c) Nokia            , T
CNT		Content: t_blue, V 07.23, 17-07-09, RM-411, (c) Nokia            ,
PSN		DQH009783
Product Code	0564124
Module Code	0203661
Basic Product Code	0554881
LPSN		0
RETU		15
TAHVO		22
AHNE		30
HW		1000
RFIC		064c0601
DSP		ICPR72_09w17
LCD		SHARP
BT		2222-143C
after with just one click:
MCU Version	V 07.23
MCU Date	17-07-09
Simlock Profile
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Security block OK and saved to "RM-411_35684002xxxxxxx_682013_13927 PM.SecurityBlock.PM"
"1D10020239CC5850A91615A2490EB8031404BE49.C000196C" Exists, That is good...
Writing Simlock...
MCU Version	V 07.23
MCU Date	17-07-09
Simlock Profile	8000000000000006
Simlock Key Cnt	0
Simlock FBUS Cnt	0
Unlock finished! Time taken 3.713s
still reliable and able box thanks
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. hitibiti Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2837 07-05-2020 10:10
Put in this thread all successfull story of Dct4 Imei???? with Mxkey mobilecitycbk MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 06-17-2009 21:28
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box FullFLASHgSMPH Cyclonebox 2 04-13-2009 14:00
Page generated in 0.52887 seconds with 10 queries
