02-14-2010, 08:00 | #721 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | 2630 unlock ok Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.07, (Sep 11 2009 03:35:10, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags Box Serial Number: C0000037 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D000028C Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.93v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.83v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.81v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Terminating flash session Boot operation took 5.516s Check Flashing Bus finished Failed to Unlock DCT4 -> Phone not detected Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V Terminating flash session Boot operation took 5.500s Check Flashing Bus finished Flash Imei RPL Backup OK MCU Version V 06.82 MCU Date 26-09-08 Product RM-298 Manufacturer (c) Nokia IMEI 351967037995136 Mastercode 4071432660 Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-298_V 06.82.unlock_img Writing patch file... Booting UPP... UPP ID: 3162 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V MSID-Crypted: 842277F14E250AD28EFC4460E6 MSID-Plain: 2C40BAE900887A2DA9000000 FAID-Crypted: 994504332FABF79B14FC4C68 Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01080000-0x0109FFFF] Erase taken 2.312s Writing 10 blocks... All blocks written OK! Time taken 1.656s Terminating flash session Box VPP disabled Asic 11 HW Signature 99E5761A1CE2A947 Simlock Server SIMLOCK SERVER Simlock Key 2341000000000000 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00553519670379951300 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23410F Asking card to sign HW Signature... Signed OK (426B3578B29FC8463DFD78F23A91DDF31EBA6689) Simlock Security - NOT TAMPERED Saving Simlock to "RM-298_351967037995136_2132010_100804 AM.Unlock.PM" Writing SP... New SP Accepted OK! Phone unlocked OK! Last edited by ptt; 02-14-2010 at 14:35. Reason: add code tag |
02-14-2010, 16:12 | #722 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | 2680 s unlock done thanx cyclone team Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.07, (Sep 11 2009 03:35:10, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags Box Serial Number: C0000037 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D000028C Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.16v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.82v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.05v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Flash Imei RPL Backup OK Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V Terminating flash session Boot operation took 6.938s Check Flashing Bus finished Flash Imei RPL Backup OK MCU Version V 05.28 MCU Date 05-11-08 Product RM-392 Manufacturer (c) Nokia IMEI 358244033404908 Mastercode 624222363 Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-392_V 05.28.unlock_img Writing patch file... Booting UPP... UPP ID: 3162 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 841BE96C277F0145783AEE652B MSID-Plain: 2C40BAE9004C7C52AA000000 FAID-Crypted: 7A49F8C9EB08AAFF67E43BEA Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01080000-0x0109FFFF] Erase taken 2.359s Writing 6 blocks... All blocks written OK! Time taken 1.532s Terminating flash session Box VPP disabled Asic 11 HW Signature 86EAF05680BD4D8E Simlock Server SIMLOCK SERVER Simlock Key 2140300000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553582440334049000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21403F Asking card to sign HW Signature... Signed OK (354460255E64A95816FC6479B695506A4E63EB9B) Simlock Security - NOT TAMPERED Saving Simlock to "RM-392_358244033404908_2142010_72551 PM.Unlock.PM" Writing SP... New SP Accepted OK! Phone unlocked OK! @ naveedbutt : you are using an old software version and your Box FW is old too Last edited by ptt; 02-14-2010 at 16:15. Reason: add code tag |
02-14-2010, 21:07 | #723 (permalink) |
No Life Poster Join Date: May 2005 Location: Denmark Age: 42
Member: 146369 Status: Offline Thanks Meter: 119 | Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: C00001D9 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D1000315 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5,15v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,81v PASSED VBAT Voltage 0,78v PASSED VBAT Voltage 4,80v PASSED Box VPP disabled VPP Voltage 0,00v PASSED Internal Box VPP Enabled VPP Voltage 4,90v PASSED Box VPP disabled VPP Voltage 0,00v PASSED External Box VPP Enabled VPP Voltage 0,09v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: FALSE Initializing FBUS... All initialized - Ready to work Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0D900104859B4650327732B6EE9D30E0FC16ABF8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88 Testing TX2 Line... TX2 Line OK! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0D900104859B4650327732B6EE9D30E0FC16ABF8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88 Testing TX2 Line... TX2 Line OK! APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Ok CMT HWC Ok CMT CCC Ok CMT R&D Ok CMT VARIANT Not Found CMT PAPUBKEYS Ok CMT KEYS Ok Restarting MCU... Read all certificates finished RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-265_358667013009950_14-02-2010_210031.SecurityBlock.PM" WARNING: "0D900104859B4650327732B6EE9D30E0FC16ABF8.C00001D9" Not Exists, Will read it... Reading CYC file from phone... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0D900104859B4650327732B6EE9D30E0FC16ABF8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "0D900104859B4650327732B6EE9D30E0FC16ABF8.C00001D9" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0D900104859B4650327732B6EE9D30E0FC16ABF8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88 Testing TX2 Line... TX2 Line OK! APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found Restarting MCU... RPL Saved OK BB5 Unlock Started... MCU Version V 06.61 MCU Date 26-03-08 Product RM-265 Manufacturer (c) Nokia IMEI 358667013009950 Mastercode 6225132360 Simlock Server SIMLOCK SERVER Simlock Key 2382000000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 2 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23820F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23830F Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FE00 Data: 2380130FFFFFFFFF Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FE00 Data: 2380139FFFFFFFFF Simlock [5,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FE00 Data: 2380211FFFFFFFFF Simlock [6,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FE00 Data: 2380212FFFFFFFFF Simlock [7,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FE00 Data: 2380214FFFFFFFFF Simlock [8,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FE00 Data: 2380220FFFFFFFFF Simlock [9,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FE00 Data: 2380221FFFFFFFFF Simlock [10,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FE00 Data: 2382010FFFFFFFFF Simlock [11,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FE00 Data: 2382030FFFFFFFFF Simlock [12,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FE00 Data: 2382094FFFFFFFFF Reading Security Block... Security block OK and saved to "RM-265_358667013009950_14-02-2010_210132.SecurityBlock.PM" "0D900104859B4650327732B6EE9D30E0FC16ABF8.C00001D9" Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... Simlock ACCEPTED OK ! MCU Version V 06.61 MCU Date 26-03-08 Product RM-265 Manufacturer (c) Nokia IMEI 358667013009950 Mastercode 6225132360 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Time taken 4.609s wbr Last edited by ptt; 02-14-2010 at 21:30. Reason: add code tag |
The Following User Says Thank You to Crazy_ratata For This Useful Post: |
02-15-2010, 03:14 | #724 (permalink) |
No Life Poster Join Date: Jan 2009 Location: ~Lemuria~
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Code: 5200 Unlock Done! Initializing FBUS... All initialized - Ready to work MCU Version V 03.70 MCU Date 22-09-06 Product RM-181 Manufacturer (c) Nokia. IMEI 3xxxxxxxxxxxxxxxxxxxxxxxx Mastercode 7525752773 IMEI Spare 3A65340911074301 IMEI SV 3365340911074301F1000000 PPM V 03.70, 22-09-06, RM-174, (c) Nokia. , L CNT Content: l, V 03.70, 22-09-06, RM-174, (c) Nokia. , PSN OD0373332 Product Code 0546382 Module Code 0203054 Basic Product Code 0530543 PSD 0000000000000000 RETU 32 TAHVO 53 AHNE 11 HW 3501 RFIC 17211721 DSP pb06w14v21 BT 06cc-P8.0 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 7300100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 73001F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 73010F BB5 Unlock Started... MCU Version V 03.70 MCU Date 22-09-06 Product RM-181 Manufacturer (c) Nokia. IMEI 3xxxxxxxxxxxxxxxxxxx Mastercode 7525752773 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 7300100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 73001F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 73010F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 1BF000012A640058F7279CE15F6A68266C7778A2 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: PM Security Block Calculation Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 1BF000012A640058F7279CE15F6A68266C7778A2 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... SP Accepted, doing reset to update block... MCU Version V 03.70 MCU Date 22-09-06 Product RM-181 Manufacturer (c) Nokia. IMEI 3xxxxxxxxxxxxxxxxxxxxxxxx Mastercode 7525752773 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! |
The Following User Says Thank You to 69eyes For This Useful Post: |
02-15-2010, 05:58 | #725 (permalink) |
No Life Poster Join Date: Apr 2007 Location: WITH BEST NOKIA TOOLS
Member: 492800 Status: Offline Sonork: 100.1601366 Thanks Meter: 1,311 | successfully unlock 7100s successfully unlock 7100s Code: Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: ######## HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk14 Initializing security card... Card Serial Number: ####### Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.02v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.78v PASSED VBAT Voltage 1.37v PASSED VBAT Voltage 5.03v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 06.31 MCU Date 24-03-09 Product RM-438 Manufacturer (c) Nokia IMEI 356060039981547 MCU Version V 06.31 Mastercode 6252362633 MCU Date 24-03-09 Selecting unlock method... Product RM-438 Manufacturer (c) Nokia IMEI 356060039981547 Mastercode 6252362633 Selecting unlock method... Using Super DCT4 Activation Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-438_V 06.31.sunlock_img Writing patch file... Using Super DCT4 Activation Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-438_V 06.31.sunlock_img Writing patch file... Failed to Unlock DCT4 -> Cannot create file "C:\Program Files\Cyclone Box\UnlockData\shadow". The process cannot access the file because it is being used by another process Booting UPP... UPP ID: 3168 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00898981 @ 0x01000000, Intel, SectorSize: 128kB, Ext: 00009221 FlashChip[1]: 0x00898981 @ 0x02000000, Intel, SectorSize: 128kB, Ext: 00009221 Signature: AD7EB61B23100340C605E40120A20000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898981 (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 840FC1BF48D80640095BECD66F MSID-Plain: 2C40BAE9009FD4E5A8000000 FAID-Crypted: 4C4C9E844CCDEDE8062BC3DF Flashbus Write baud set to 6.50Mbits 4 Region(s) to erase Erasing NOR Region [0x01220000-0x0123FFFF] Erasing NOR Region [0x01440000-0x0145FFFF] Erasing NOR Region [0x014C0000-0x014DFFFF] Erasing NOR Region [0x01C00000-0x01C1FFFF] Erase taken 3.109s Writing 32 blocks... Sending Super DCT4 Emulator... Emulator sent OK! All blocks written OK! Time taken 35.781s Terminating flash session Box VPP disabled Asic 11 HW Signature D3F2D562ADA740B4 Simlock Server SIMLOCK SERVER Simlock Key 2341000000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553560600399815400 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23410F Asking card to sign HW Signature... Signed OK (098D5331992D63CD246E456488056B9A75C833BA) Simlock Security - UNKNOWN Writing SP... New SP Accepted OK! Phone unlocked OK! |
The Following User Says Thank You to jonymahmud For This Useful Post: |
02-15-2010, 11:26 | #726 (permalink) |
Freak Poster Join Date: Nov 2009 Location: across in the archipelago
Member: 1170687 Status: Offline Thanks Meter: 30 | 6300 unlock Code: RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Simlock Store not supported, not a PA_SL2 Phone Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-217_353508024344587_2152010_62210 PM.SecurityBlock.PM" WARNING: "13000216D3F66F565A438006767EA56217C40097.C0002575" Not Exists, Will read it... Reading CYC file from phone... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 13000216D3F66F565A438006767EA56217C40097 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "13000216D3F66F565A438006767EA56217C40097.C0002575" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 13000216D3F66F565A438006767EA56217C40097 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Testing TX2 Line... TX2 Line OK! APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... Storing VARIANT... Restarting MCU... RPL Saved OK BB5 Unlock Started... MCU Version V 05.50 MCU Date 14-08-07 Product RM-217 Manufacturer (c) Nokia. IMEI 353508024344587 Mastercode 5773666053 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 5150200000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 51502F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 51502F Reading Security Block... Security block OK and saved to "RM-217_353508024344587_2152010_62315 PM.SecurityBlock.PM" "13000216D3F66F565A438006767EA56217C40097.C0002575" Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) #pw+304160838171905+1# #pw+556371535033758+2# #pw+524547028709481+3# #pw+943857401358106+4# #pw+356223346034680+5# #pw+885313005765176+6# #pw+509729520324007+7# Sending NCK Code (Level 7).. NCK Accepted! Phone unlocked OK! MCU Version V 05.50 MCU Date 14-08-07 Product RM-217 Manufacturer (c) Nokia. IMEI 353508024344587 Mastercode 5773666053 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 5150200000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 51502F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 51502F Unlock finished! Time taken 2.359s:D:D:D Last edited by ptt; 02-15-2010 at 22:48. Reason: add code tag |
The Following User Says Thank You to Mintsea For This Useful Post: |
02-16-2010, 05:23 | #727 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | 2680s unlock done with cyclone box Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.07, (Sep 11 2009 03:35:10, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags Box Serial Number: C0000037 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D000028C Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.15v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.83v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.06v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Terminating flash session Boot operation took 7.609s Check Flashing Bus finished Failed to backup Flash Imei RPL -> Phone not detected Failed to Unlock DCT4 -> Phone not detected Booting UPP... UPP ID: 3162 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V Terminating flash session Boot operation took 6.531s Check Flashing Bus finished MCU Version V 05.28 MCU Date 05-11-08 Product RM-392 Manufacturer (c) Nokia IMEI 358309030315678 Mastercode 2260615722 Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RM-392_V 05.28.unlock_img Writing patch file... Booting UPP... UPP ID: 3162 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x0020883C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009321 FlashChip[1]: 0x0020883C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009321 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020883C (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 8474591A7B480FC747450945DA MSID-Plain: 2C40BAE90040B70AAA000000 FAID-Crypted: 02704A1ECC0108117D72F4AF Flashbus Write baud set to 6.50Mbits 2 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01080000-0x0109FFFF] Erase taken 2.297s Writing 6 blocks... All blocks written OK! Time taken 1.547s Terminating flash session Box VPP disabled Asic 11 HW Signature CDA317C90A8233E2 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 800000000003000B Simlock Aux 000B5555 Simlock IMEI 00553583090303156700 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Asking card to sign HW Signature... Signed OK (AA1534C5D27664FC44945C6B8C61B5F5612E3601) Simlock Security - NOT TAMPERED Saving Simlock to "RM-392_358309030315678_2152010_41307 PM.Unlock.PM" Writing SP... New SP Accepted OK! Phone unlocked OK! Last edited by ptt; 02-16-2010 at 21:59. Reason: add code tag |
02-17-2010, 01:59 | #728 (permalink) |
Insane Poster Join Date: Aug 2008 Location: the same about Facundo Cabral
Member: 839359 Status: Offline Thanks Meter: 13 | Good Work Cyclone...!!! N78 RM-342 From Telcel México Code: BB5 Unlock Started... MCU Version V ICPR71_08w20 MCU Date 20-05-08 Product RM-342 Manufacturer (c) Nokia IMEI 35417402053xxxx Mastercode 213054366 Simlock Server SIMLOCK SERVER Simlock Key 3340201549764300 Simlock Profile 1000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: 3F007F206F07FFFF @ FC00 Data: 334020 Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 334020 Reading Security Block... Security block OK and saved to "RM-342_35417402053xxxx_16022010_065313 p.m..SecurityBlock.PM" "231001193ABE00580ABC7E89E816D2A909FA0215.C0003945" Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... Simlock ACCEPTED OK ! MCU Version V ICPR71_08w20 MCU Date 20-05-08 Product RM-342 Manufacturer (c) Nokia IMEI 35417402053xxxx Mastercode 213054366 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Time taken 4.851s Last edited by ptt; 02-17-2010 at 02:37. Reason: add code tag |
The Following User Says Thank You to charous For This Useful Post: |
02-17-2010, 06:04 | #729 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Island Garden City Of Samal,Ph
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | 7310c unlOCked done by cyclone Code: Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1980010D8BD15850155D8D239246CBB3DD80AFE4 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 1C4FF759B84A261249E1BBE6F8B6CED06F54373D Testing TX2 Line... TX2 Line OK! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-379_354151023635553_2172010_125220 PM.SecurityBlock.PM" WARNING: "1980010D8BD15850155D8D239246CBB3DD80AFE4.C00001B9" Not Exists, Will read it... Reading CYC file from phone... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1980010D8BD15850155D8D239246CBB3DD80AFE4 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "1980010D8BD15850155D8D239246CBB3DD80AFE4.C00001B9" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1980010D8BD15850155D8D239246CBB3DD80AFE4 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 1C4FF759B84A261249E1BBE6F8B6CED06F54373D Testing TX2 Line... TX2 Line OK! APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found Restarting MCU... RPL Saved OK BB5 Unlock Started... MCU Version V 08.20 MCU Date 12-06-08 Product RM-379 Manufacturer (c) Nokia IMEI 354151023635553 Mastercode 776634665 Simlock Server SIMLOCK SERVER Simlock Key 2720200000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 27202F Reading Security Block... Security block OK and saved to "RM-379_354151023635553_2172010_125431 PM.SecurityBlock.PM" "1980010D8BD15850155D8D239246CBB3DD80AFE4.C00001B9" Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) #pw+854894646297990+1# #pw+995360514994585+2# #pw+701091245481551+3# #pw+001348434985793+4# #pw+733853120272372+5# #pw+726028257450576+6# #pw+700126250854200+7# Sending NCK Code (Level 7).. NCK Accepted! Phone unlocked OK! MCU Version V 08.20 MCU Date 12-06-08 Product RM-379 Manufacturer (c) Nokia IMEI 354151023635553 Mastercode 776634665 Simlock Server SIMLOCK SERVER Simlock Key 2720200000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 27202F Simlock NCK #pw+700126250854200+7# Unlock finished! Time taken 3.922s |
02-17-2010, 14:55 | #730 (permalink) |
No Life Poster Join Date: Dec 2007 Location: morocco
Member: 653952 Status: Offline Thanks Meter: 763 | successfully unlock 5800 rm356 Code: BB5 Unlock Started... MCU VersionV ICPR72_09w20.12 MCU Date 10-09-09 ProductRM-356 Manufacturer (c) Nokia IMEI 356039033877232 Mastercode 713453130 Simlock ServerSIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1]State: CLOSEDType: MCC-MNCData: 21407F Simlock [2,1]State: CLOSEDType: MCC-MNCData: 21402F Reading Security Block... Security block OK and saved to "RM-356_356039033877232_17-02-2010_131806.SecurityBlock.PM" WARNING: "1EC000073A7C00520B3C1EBCBA4E34BA742A8192.C0000DB0" Not Exists, Will read it... Reading CYC file from phone... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1EC000073A7C00520B3C1EBCBA4E34BA742A8192 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH:CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "1EC000073A7C00520B3C1EBCBA4E34BA742A8192.C0000DB0" Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... Simlock ACCEPTED OK ! MCU VersionV ICPR72_09w20.12 MCU Date 10-09-09 ProductRM-356 Manufacturer (c) Nokia IMEI 356039033877232 Mastercode 713453130 Simlock ServerSIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [1,2]State: OPENEDType: GIDData: FFFF Simlock [1,3]State: OPENEDType: GIDData: FFFF Simlock [1,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [1,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [2,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [2,2]State: OPENEDType: GIDData: FFFF Simlock [2,3]State: OPENEDType: GIDData: FFFF Simlock [2,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [2,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [3,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [3,2]State: OPENEDType: GIDData: FFFF Simlock [3,3]State: OPENEDType: GIDData: FFFF Simlock [3,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [3,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [4,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [4,2]State: OPENEDType: GIDData: FFFF Simlock [4,3]State: OPENEDType: GIDData: FFFF Simlock [4,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [4,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [5,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [5,2]State: OPENEDType: GIDData: FFFF Simlock [5,3]State: OPENEDType: GIDData: FFFF Simlock [5,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [5,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [6,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [6,2]State: OPENEDType: GIDData: FFFF Simlock [6,3]State: OPENEDType: GIDData: FFFF Simlock [6,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [6,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [7,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [7,2]State: OPENEDType: GIDData: FFFF Simlock [7,3]State: OPENEDType: GIDData: FFFF Simlock [7,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [7,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Unlock finished! Time taken 19.437s Last edited by ptt; 02-17-2010 at 21:52. Reason: add code tag |
02-17-2010, 17:55 | #731 (permalink) |
Member: 942693 Status: Offline Sonork: 1592619 Thanks Meter: 2,204 | Code: 1680 Unlock Done! All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 06.82 MCU Date 26-09-08 Product RM-395 Manufacturer (c) Nokia IMEI 0xxxxxxxxxxxxxxxxxxxxx Mastercode 1015124135 IMEI Spare 0A11890660836206 IMEI SV 0311890660836246F5000000 PPM V 06.82, 26-09-08, RM-394, (c) Nokia, UB CNT Content: UB_GY_CLARO_CHILE, V 06.82, 26-09-08, RM-394, (c) Nokia, , PSN RCX677636 Product Code 0569016 Module Code 0203778 Basic Product Code 0556747 PSD 0000001800000000 LPSN 0 HW 5501 UEM 1328 UPP 12642 RFIC 0500 DSP ICPR62_08w27_U LCD SUEZ Asic 11 HW Signature 9EF94D8D6D550AB4 Simlock Server SIMLOCK SERVER Simlock Key 7300300036615151 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00550119860063826600 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 73003F MCU Version V 06.82 MCU Date 26-09-08 Product RM-395 Manufacturer (c) Nokia IMEI 01xxxxxxxxxxxxxxxxxxxxxxx Mastercode 1015124135 Selecting unlock method... Using Super DCT4 Activation Search in: C:\Archivos de programa\Cyclone Box\UnlockData\ Searching for: RM-395_V 06.82.sunlock_img Writing patch file... Booting UPP... UPP ID: 3162 [HW_UNKNOWN] shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00898981 @ 0x01000000, Intel, SectorSize: 128kB, Ext: 00009221 FlashChip[1]: 0x00898981 @ 0x02000000, Intel, SectorSize: 128kB, Ext: 00009221 Signature: AD7EB61B00FF10400000000000000000 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00898981 (256Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V MSID-Crypted: 84131FDD9A404E7BD20290E513 MSID-Plain: 2C40BAE9005CAE78AA000000 FAID-Crypted: A6BF9F92F60963DCFDF255A5 Flashbus Write baud set to 6.50Mbits 4 Region(s) to erase Erasing NOR Region [0x013C0000-0x013DFFFF] Erasing NOR Region [0x01440000-0x0145FFFF] Erasing NOR Region [0x016A0000-0x016BFFFF] Erasing NOR Region [0x01C20000-0x01C3FFFF] Erase taken 2.125s Writing 32 blocks... Sending Super DCT4 Emulator... Emulator sent OK! All blocks written OK! Time taken 34.984s Terminating flash session Box VPP disabled Asic 11 HW Signature 9EF94D8D6D550AB4 Simlock Server SIMLOCK SERVER Simlock Key 7300300036615151 Simlock Profile 800000000001000B Simlock Aux 000B5555 Simlock IMEI 00550119860063826600 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 73003F Asking card to sign HW Signature... Signed OK (1710EDFB4ED82908E23336A65D08C918F412EEFC) Simlock Security - UNKNOWN Writing SP... New SP Accepted OK! Phone unlocked OK! Thanks Cyclone Team! |
02-18-2010, 03:56 | #732 (permalink) |
Registered User Join Date: Mar 2006 Location: Pilipinas
Member: 249276 Status: Offline Thanks Meter: 209 | WD2 NHL-10 6600 nokia only done WD2 NHL-10 6600 nokia only done Flash the phone MCU PPM after flash contact the retailer do the format user area... Settings: use VPP BOX INT 5V Code: Initializing FBUS... All initialized - Ready to work Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 1081 [HW_UPP_WD2_v3_1] NHL105530.C1, Type: Flash Image, Algo: WD2 BT2, WD2 ALGORITHM, WD2 CBUS BT Flashbus Write baud set to 100Kbits w3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2 Box VPP disabled Internal Box VPP Enabled PLL Factor: 4 FlashChip[0]: 0x002088C0 @ 0x00000000, ST, SectorSize: 64kB, Ext: 00000121 FlashChip[1]: 0x002088C0 @ 0x02000000, ST, SectorSize: 64kB, Ext: 00000121 FlashChip[2]: 0x002088C0 @ 0x04000000, ST, SectorSize: 64kB, Ext: 00000121 FlashChip[3]: 0x002088C0 @ 0x06000000, ST, SectorSize: 64kB, Ext: 00000121 Signature: C60000EA750100EA780100EA7B0100EA Flashbus Write baud set to 333Kbits Flashbus Read baud set to 51Kbits w3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x002088C0 (64Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM Nominal VPP Voltage: 9V, Detected: 4.92V MSID-Crypted: 84DE09AC8772571B4D98D59EF6 Using MSID-FAID Cache, Not wasting card FAID-Crypted: D726B0D6415CB7AC7AC1AB1B Searching for CBUS Loader: WD2 CBUS BT w3_cbusb.fia, Type: Algorithm, Rev: 7.4.76.0, Algo: WD2 CBUS BT CBUS Loader Spawned OK! Flashbus Write baud set to 1.80Mbits 5 Region(s) to erase Erasing NOR Region [0x00000000-0x0000FFFF] Erasing NOR Region [0x00010000-0x007FFFFF] Erasing NOR Region [0x04000000-0x046FFFFF] Erasing NOR Region [0x06000000-0x066FFFFF] Erasing NOR Region [0x047C0000-0x047EFFFF] Erase taken 160.47s Writing 3671 blocks... CBUS BT Image Length: 187796 bytes Sending CBUS BT Image Length... CBUS BT Image Length Accepted Registering BT... BT Flashing Completed All blocks written OK! Time taken 190.563s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 1081 [HW_UPP_WD2_v3_1] NHL105530.93, Type: Flash Image, Algo: WD2 BT2, WD2 ALGORITHM Flashbus Write baud set to 100Kbits w3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2 Box VPP disabled Internal Box VPP Enabled PLL Factor: 4 FlashChip[0]: 0x002088C0 @ 0x00000000, ST, SectorSize: 64kB, Ext: 00000121 FlashChip[1]: 0x002088C0 @ 0x02000000, ST, SectorSize: 64kB, Ext: 00000121 FlashChip[2]: 0x002088C0 @ 0x04000000, ST, SectorSize: 64kB, Ext: 00000121 FlashChip[3]: 0x002088C0 @ 0x06000000, ST, SectorSize: 64kB, Ext: 00000121 Signature: C60000EA750100EA780100EA7B0100EA Flashbus Write baud set to 333Kbits Flashbus Read baud set to 51Kbits w3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x002088C0 (64Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM Nominal VPP Voltage: 9V, Detected: 4.92V MSID-Crypted: 841293D98877E63E5618084417 MSID-Plain: 3E4EBAF70015C4DBA8000000 FAID-Crypted: EBAB5F0CA3CC9E4A4549FC87 Flashbus Write baud set to 1.80Mbits 2 Region(s) to erase Erasing NOR Region [0x00000000-0x0000FFFF] Erasing NOR Region [0x02000000-0x021CFFFF] Erase taken 13.203s Writing 234 blocks... All blocks written OK! Time taken 14.547s Terminating flash session Box VPP disabled Processing post-flash tasks... Post-flash tasks finished... Flash successfully finished! Formatting WD2 User Area - timeout is 120 seconds WD2 User Area Formatted OK MisterG |
02-18-2010, 09:58 | #733 (permalink) |
Member: 653952 Status: Offline Thanks Meter: 763 | successfully unlock n95rm159 Code: BB5 Unlock Started... MCU VersionV 06wk41v50.2 MCU Date 28-01-08 ProductRM-159 Manufacturer (c) Nokia IMEI 358064010130247 Mastercode 7455227013 Simlock ServerSIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1]State: CLOSEDType: MCC-MNCData: 21401F Simlock [2,1]State: CLOSEDType: MCC-MNCData: 21401F Reading Security Block... Security block OK and saved to "RM-159_358064010130247_17-02-2010_133729.SecurityBlock.PM" "139000132ABE00581997F61E22E64F6930FCFF22.C0000DB0" Exists, That is good... Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... Simlock ACCEPTED OK ! MCU VersionV 06wk41v50.2 MCU Date 28-01-08 ProductRM-159 Manufacturer (c) Nokia IMEI 358064010130247 Mastercode 7455227013 Simlock ServerSIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [1,2]State: OPENEDType: GIDData: FFFF Simlock [1,3]State: OPENEDType: GIDData: FFFF Simlock [1,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [1,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [2,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [2,2]State: OPENEDType: GIDData: FFFF Simlock [2,3]State: OPENEDType: GIDData: FFFF Simlock [2,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [2,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [3,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [3,2]State: OPENEDType: GIDData: FFFF Simlock [3,3]State: OPENEDType: GIDData: FFFF Simlock [3,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [3,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [4,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [4,2]State: OPENEDType: GIDData: FFFF Simlock [4,3]State: OPENEDType: GIDData: FFFF Simlock [4,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [4,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [5,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [5,2]State: OPENEDType: GIDData: FFFF Simlock [5,3]State: OPENEDType: GIDData: FFFF Simlock [5,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [5,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [6,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [6,2]State: OPENEDType: GIDData: FFFF Simlock [6,3]State: OPENEDType: GIDData: FFFF Simlock [6,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [6,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [7,1]State: OPENEDType: MCC-MNCData: FFFFFF Simlock [7,2]State: OPENEDType: GIDData: FFFF Simlock [7,3]State: OPENEDType: GIDData: FFFF Simlock [7,4]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Simlock [7,5]State: OPENEDType: IMSIData: FFFFFFFFFFFFFFFF Unlock finished! Time taken 1 Last edited by ptt; 02-18-2010 at 11:22. Reason: add code tag |
02-18-2010, 20:58 | #734 (permalink) |
Member: 653952 Status: Offline Thanks Meter: 763 | successful unlocking 6230 rh12 via usb Code: Initializing FBUS... All initialized - Ready to work [BB5 NMWCD]: Found 1 active devices [Nokia 6230 USB Generic]: Opening Connection [Nokia 6230 USB Generic]: Port opened OK! MCU Version V 04.44 MCU Date 21-09-04 Product RH-12 Manufacturer GSM P1.1, (c) NMP. IMEI 355666009582056 Mastercode 75567153 IMEI Spare 3A55660690850205 IMEI SV 3355660690850205F7000000 PDC 4E54544A50123456 PPM V 04.44, 21-09-04, RH12_28_-, GSM P1.1, C CNT V 04.44\n21-09-04\nRH12_28_-\nGSM P1.1\n(c) NMP. PSN KKJ024246 Product Code 0522170 Basic Product Code 0519939 PSD 0000001700000000 HW 0729 UEM 400 UPP 4178 RFIC p10ff11ff0205 DSP pA0429_MATRIX LCD SEIKO BT 0382 ADSP Sw pADSP_MR3_v6 Asic 6 HW Signature 4BE785F66BDE4159 Simlock Server SIMLOCKLIB VERSION 2.29 - Fix task : support for more TDS-6 boxes Simlock Key 2140700000000000 Simlock Profile 0000000000000006 Simlock Aux 00065555 Simlock IMEI 00553556660095820500 Simlock Key Cnt 4 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21402F Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF [BB5 NMWCD]: Found 1 active devices [Nokia 6230 USB Generic]: Opening Connection [Nokia 6230 USB Generic]: Port opened OK! MCU Version V 04.44 MCU Date 21-09-04 Product RH-12 Manufacturer GSM P1.1, (c) NMP. IMEI 355666009582056 Mastercode 75567153 Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RH-12_V 04.44.unlock_img Unlock data not found, Trying to calculate Unlock Codes... #pw+498217216615364+1# #pw+193964017102314+2# #pw+928292344625741+3# #pw+708990622652147+4# #pw+097893616571747+5# #pw+026153045444201+6# #pw+793300213136352+7# Last edited by ptt; 02-18-2010 at 21:03. Reason: add code tag |
02-19-2010, 01:45 | #735 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Portugal
Member: 339046 Status: Offline Thanks Meter: 3 | Code: BB5 Unlock Started... MCU Version V 05.63 MCU Date 12-01-09 Product RM-411 Manufacturer (c) Nokia IMEI *************** Mastercode ********** Simlock Server SIMLOCK SERVER Simlock Key 2680300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 26803F Reading Security Block... Security block OK and saved to "RM-411_355717021997366_18-02-2010_225623.SecurityBlock.PM" WARNING: "13300110FE1603546AD1C0B783DCB32CDF3DBCD3.C0002146" Not Exists, Will read it... Reading CYC file from phone... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 13300110FE1603546AD1C0B783DCB32CDF3DBCD3 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "13300110FE1603546AD1C0B783DCB32CDF3DBCD3.C0002146" Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (new method) #pw+***************+1# #pw+***************+2# #pw+***************+3# #pw+***************+4# #pw+***************+5# #pw+***************+6# #pw+***************+7# Sending NCK Code (Level 7).. NCK Accepted! Phone unlocked OK! MCU Version V 05.63 MCU Date 12-01-09 Product RM-411 Manufacturer (c) Nokia IMEI *************** Mastercode ********** Simlock Server SIMLOCK SERVER Simlock Key 2680300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 26803F Simlock NCK #pw+***************+7# Unlock finished! Time taken 15.438s Portugal Last edited by ptt; 02-19-2010 at 01:47. Reason: add code tag |
POST HERE all Successfull Report with Micro-Box, HTC cable, etc.. | hitibiti | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 2837 | 07-05-2020 10:10 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
Put in this thread all successfull UNLOCK AND NOT with Cyclone-box | FullFLASHgSMPH | Cyclonebox | 2 | 04-13-2009 14:00 |
