You need try, because it can take couple time till you will get connection. |
@kaisak me too having the same problem! tried atleast 15times but nothing! whts the error for? and i hve a lot of phones to unlock but cant fill credtis! pls do something to the server! Quote:
ATSCLLC |
Im ned upgrade box firmware server not conect Box Maintenance procedure started at 10:08:00 AM Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support Service Tag: A41E1E9376A93DC6BA9BE4A834DDF220 Connecting to Cyclone Server Box Maintenance Error -> Can't connect to Cyclone Server |
Box Maintenance procedure started at 11:15:58 AM Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support Service Tag: C9E5A15910B6A16EFC4F9FFDAA4611ED Connecting to Cyclone Server Box Maintenance Error -> Can't connect to Cyclone Server |
Server seems to be fine now Quote:
Box Maintenance procedure started at 1:02:08 PM Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support Service Tag: 144A53F0220C9B16B76B3DB5015CFCF1 Connecting to Cyclone Server Box Maintenance Error -> Can't connect to Cyclone Server |
To cyclone supporter, How can i fix this problem about updating my box, I always got an error even after update. Can any one help me to fix this problem This is the Screen shot. http://img109.imageshack.us/img109/6...cantupdate.jpg I always got that error even after update my box. THNX. |
BR |
fails to load the software on your computer, save the backup and start doing their job but either ppm msw or fails, the computer shuts down and disconnects the program |
aqui el log Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D6D07E588DC4E06DEE7012A3C0ECC4E35D3CE263 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Skipping erase on user request Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Block Write Failed -> Failed to write data data (2) Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm174__06.03.mcusw |
