03-26-2010, 14:32 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Life Of Paradise
Member: 140477 Status: Offline Sonork: 100.1658502 Thanks Meter: 426 | 3110c dead during flashing I FACING PROBLEM FROM LAST 2 DAYS Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2B400213DD317E56F60E41A326F1DC17FA7DF1C5 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 6A21 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Storing certificate ...OK Erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.907 s CMT NOR area [000006C0-0001FFFF] erased in 0.296 s CMT NOR area [00020000-0007FFFF] erased in 0.266 s CMT NOR area [00080000-000DFFFF] erased in 0.266 s CMT NOR area [00100000-001FFFFF] erased in 0.406 s CMT NOR area [00200000-0031FFFF] erased in 0.359 s CMT NOR area [00320000-0105FFFF] erased in 0.312 s CMT NOR area [01060000-01067FFF] erased in 0.328 s CMT NOR area [01068000-0107FFFF] erased in 0.266 s Flash programming ... Error while programming [00] at 0x00020000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 39.140 s RX Buffer: B372 SAMEPROBLEM WITH 7210C http://forum.gsmhosting.com/vbb/f550...-flash-960509/ http://forum.gsmhosting.com/vbb/f550...-960509/PLEASE CHECK MXKEY DEAD MY 4 HANDSET |
03-26-2010, 14:43 | #2 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 361094 Status: Offline Sonork: 100.1597521 Thanks Meter: 172 | Quote:
03-26-2010, 14:52 | #3 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india. kerala.
Member: 1245320 Status: Offline Sonork: 100.1612126 Thanks Meter: 140 | First u ckek ur cable...mxkey hwk dont accept bad cable in this two mobiles..3110c.7210c...u must use 7pin gpg or dits cable....now condition u must use cyclone or mt box................iam fasing this model complaint more time... |
04-09-2010, 08:05 | #6 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | This is not a cable fault mxkey does not support some intel processor phones this is a bug on mxkey,try to change your flashing device. Flash with other tool. Br. Vijendra Saini. |
04-10-2010, 21:14 | #8 (permalink) |
Freak Poster Join Date: Sep 2008 Location: delhi
Member: 857876 Status: Offline Sonork: cellexpert-33 Thanks Meter: 63 | This is 1000000000000000% tested solution (dead after flash) and press thank after test i have tested many handset. 1: flash by mx-key with take option skip erase and without safe mode. 2: take full rpl backup after flash then reset npc 3: full erase with 8,16,32 mb erase file 4: flash phone with leatest ver (07.21) 5: restore rpl backup ur set will 100000% ok. if u face simlock or contact service type of problum write sd authorized pm update simlock etc. caution 1: if not flash ur handset with skip erase option u can also use hw_cfg but shuld musthave rpl backup. ist time w8 yr thanks..................................... |
04-10-2010, 21:17 | #9 (permalink) |
Member: 857876 Status: Offline Sonork: cellexpert-33 Thanks Meter: 63 | This is 1000000000000000% tested solution (dead after flash) and press thank after test i have tested many handset. 1: flash by mx-key with take option skip erase and without safe mode. 2: take full rpl backup after flash then reset npc 3: full erase with 8,16,32 mb erase file 4: flash phone with leatest ver (07.21) 5: restore rpl backup ur set will 100000% ok. if u face simlock or contact service type of problum write sd authorized pm update simlock etc. caution 1: if not flash ur handset with skip erase option u can also use hw_cfg but shuld musthave rpl backup. east or west mx-key is the best. ist time w8 yr thanks..................................... |
3110c killed during flashing . | mukeshdurg | Nokia Base Band 5 ( BB-5 ) | 23 | 02-24-2009 13:37 |
Panasonic GD87 dead during flashing????? | .::Zafar Communication::. | Panasonic | 9 | 06-18-2005 00:13 |
Panasonic X70 Dead During Flashing | axilleask | Panasonic | 18 | 10-22-2004 19:30 |
A300 dead - during flashing suddenly stoped | gladeo | VLSI, Conexant, Skyworks and Old Models | 1 | 04-04-2003 00:34 |
Help!!! Mars is dead during flashing... | Roman | Mitsubishi | 1 | 11-27-2001 20:20 |
