Old 03-25-2010, 20:00   #1 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
6600s swcurity test failed
Imei net: 351954030255155
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 8000000000000000
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
phone in contact service
Old 03-25-2010, 20:05   #2 (permalink)
jonymahmud's Avatar
Member: 492800
Sonork: 100.1601366
Thanks Meter: 1,311
very simple bro... first sx4 ur phone then write full pm.
Old 03-25-2010, 20:07   #3 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
how to sx4??? sorry im newbie
Old 03-25-2010, 20:12   #4 (permalink)
R@jusat's Avatar
Member: 745721
Sonork: 100.1605292
Thanks Meter: 2,390
goto pm tab then conect sx4 then write pm 1.309
Old 03-25-2010, 20:15   #5 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
I have no sx4 card????
Old 03-25-2010, 20:18   #6 (permalink)
jonymahmud's Avatar
Member: 492800
Sonork: 100.1601366
Thanks Meter: 1,311
example :
Old 03-25-2010, 20:20   #7 (permalink)
shedeed's Avatar
Member: 527884
Sonork: 100.1583794
Thanks Meter: 850
U Donot Need Sx4 Card U Must Have Internet Coneections Just It
And Mx-key Will Connect To PM Server
Regards
Old 03-25-2010, 20:29   #8 (permalink)
Duytuanmobile's Avatar
Member: 886430
Thanks Meter: 109
you do jonymahmud guide is the right Mx-key pro
Old 03-25-2010, 21:02   #9 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
Thank you so much!!!
its is pm auth and not super sd auth right?
Old 03-25-2010, 21:19   #10 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
I Have tried this and it does not seem to work?.
Thank you for helping me.
Old 03-25-2010, 21:26   #11 (permalink)
Member: 199814
Thanks Meter: 1,960
Post screenshot what kind of issue you are facing? without explain no body can make u perfect in such thing..
Old 03-25-2010, 21:31   #12 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
It Says Security Test Failed.
And Phone is in contact service, =(
Which other information is needed.
Thanks
Old 03-25-2010, 22:15   #13 (permalink)
swatdan's Avatar
Member: 514081
Thanks Meter: 82
Write this PM in your phone
This is ONLY field 1 and 309 for your phone !!!
RapidShare: 1-CLICK Web hosting - Easy Filehosting
post result
Old 03-26-2010, 09:35   #14 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
so i only write those two fields? thank you sir appreciate all your help.
Old 03-26-2010, 15:36   #15 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 216
Bump////................ s
Success two security TEST failed but faile in one 5220 FAILE khokonhajigonj MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 02-09-2010 15:38
3110C security test fail after sd repair now tested ok GSMaxx MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-06-2010 11:19
N85 Phone start up failed sim lock test failed how to solve it?? alasdro Nokia Base Band 5 ( BB-5 ) 7 12-14-2009 18:29
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range kosta25 Cyclonebox 2 11-04-2009 13:40
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range azad4u Cyclonebox 7 07-08-2009 14:48
Page generated in 0.20822 seconds with 9 queries
