03-26-2010, 19:05 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | bro, writ this rpl 4shared.com - online file sharing and storage - download 6600s_without_NPC_DATA__made_by_MxKey.rpl then mxkey>serves>imei&securty>imei rebuild>repair sd go to pm >click super sd auth writ pm 1 and 309 and wait 30 second full factory |
The Following User Says Thank You to alasmmar For This Useful Post: |
03-26-2010, 20:11 | #8 (permalink) |
Member: 231153 Status: Offline Thanks Meter: 313 | ur welcom no just repair sd (you will get rpl to repair sim & sd) then super sd auth and writ pm poste here result |
03-26-2010, 20:14 | #9 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Thanks you! all simlock and data settings are now intact phone just keeps restarting now. i have yet to write full pm. also do i write full original pm? or where do i find a good work pm from? Thank you sir!. |
03-26-2010, 20:41 | #10 (permalink) |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | i attempted to do what you said, however imei went to 00000000000 . then once i restored imei it wont write fields 1 and 309?? how to fix this and security test failed again. thanks. |
Success two security TEST failed but faile in one 5220 FAILE | khokonhajigonj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-09-2010 15:38 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
N85 Phone start up failed sim lock test failed how to solve it?? | alasdro | Nokia Base Band 5 ( BB-5 ) | 7 | 12-14-2009 18:29 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range | kosta25 | Cyclonebox | 2 | 11-04-2009 13:40 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range | azad4u | Cyclonebox | 7 | 07-08-2009 14:48 |
