03-25-2010, 20:00 | #1 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | 6600s swcurity test failed Code: Imei net: 351954030255155 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF phone in contact service |
03-25-2010, 22:15 | #13 (permalink) |
Freak Poster Join Date: May 2007 Location: aiurea`n tramvai !
Member: 514081 Status: Offline Thanks Meter: 82 | Write this PM in your phone This is ONLY field 1 and 309 for your phone !!! RapidShare: 1-CLICK Web hosting - Easy Filehosting post result |
Success two security TEST failed but faile in one 5220 FAILE | khokonhajigonj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-09-2010 15:38 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
N85 Phone start up failed sim lock test failed how to solve it?? | alasdro | Nokia Base Band 5 ( BB-5 ) | 7 | 12-14-2009 18:29 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.17v is out of valid range | kosta25 | Cyclonebox | 2 | 11-04-2009 13:40 |
Box Selftests Failed -> VBAT Supply Voltage test failed, 4.08v is out of valid range | azad4u | Cyclonebox | 7 | 07-08-2009 14:48 |
