Old 02-28-2012, 16:40   #1 (permalink)
Member: 356169
Thanks Meter: 34
i need hellp
today i bought softweae HTI yellow when i softwear this error appear during file loading.and appear this massage
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\RPL\35895401566810_BA CK.rpl).
Processing MCU file: rh99_06.000
[DCT4,DCT4 ALGORITHM] size: 2.26 MB
Supported Ids: 2292
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
Error sending bootloader !
flashing terminated !
Old 02-28-2012, 16:47   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. already 1 thread with this & again. check usb to box cable, if ok then may be bugs can fix in next update, but searching here & there dont open your box for hardware as your box must ok. i will confirm you & post again.
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 02-29-2012, 11:57   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C06029FF
Using device: HTI, FW ver: 00.50, SN: 01001E28
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
 SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...OK
UEM ID: 00F148FDA3BDA66
ASIC type: 11
UEM Imei: 35419803387532
Flash Imei: 35419803387532
MasterCode: 6453014315
RPL saved to "C:\mobileEx\3.5\data\backup\35419803387532_1330454445_BACK.rpl"
Phone type: RH-122
SW version: V 03.10 11-02-09 RH-122 (c) Nokia
Imei plain: 35419803387532-3
Product code: 0575925
Cellular system: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: MD
Language Pack:
English,Filipino,Vietnamase
Master code: 1765353362
Imei net: 35419803387532
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
there is no such bug. check FBUS cable, check USB cable for HTI, check HTI chip damaged or not, some info about HTI boot error
The Following User Says Thank You to gbluez For This Useful Post:
Old 02-29-2012, 12:09   #4 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
thanks sir, i was not confirmed & its confirmed now for no bugs.
Old 02-29-2012, 13:17   #5 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
@ ZuberChaudhary & Gbluez
very cleaver example. the man is getting error in nokia 1200 & u are replying for nokia 1661..
if u have not understood the matter, then have a look at the forum. we can see the problem of ERROR SENDING BOOTLOADER in few models like 1200,1208,1650,1110. not all DCT4.
more info can be found here: http://forum.gsmhosting.com/vbb/f550...rules-1405049/
plz have a time to rectify the problem then answer.
regards.....
Old 02-29-2012, 17:32   #6 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
regards.....
bro. dont give rubbish answer & see this image of nokia 1110, just now capture for you. from here confirm before answer. actually its a cable problems not mxkey v3.5 rev1.7
Old 02-29-2012, 18:02   #7 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
i replied u after checking all possible errors from my side. u know i have 3 mx boxes.1green & 2 orange boxes. all of them are getting same problem in dct 4 models. for your king info i also changed cable & i am using gpg original A to B cable and my all other boxes are working fine in that cable...
do u have more option??? let me know your pc configuration 1st.
Old 02-29-2012, 18:48   #8 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. my pc is win xp sp3 with 1gb ram. not so special kind of pc its old acer laptop working with all software fine & bro. 1 thing i will tell you the most important is installing & updating in right way following product expert's procedure will never face problems or error.
Old 02-29-2012, 18:59   #9 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
ok. lets see what we get solution from product section..
still waiting for them.......
Old 02-29-2012, 19:10   #10 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
what solution bro. when there is no problem. i gave you the screen shot of rh-99 ok buscheck, for that phone which you are getting error. means something wrong with cable, HTI update or mxkey installation.
Old 02-29-2012, 19:35   #11 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
why are u over reacting bro? u mean i am lying? look here.
http://forum.gsmhosting.com/vbb/f550...wered-1398994/
http://forum.gsmhosting.com/vbb/f550...roblem-988603/
http://forum.gsmhosting.com/vbb/f550...wered-1401176/
http://forum.gsmhosting.com/vbb/f550...wered-1433585/
Old 02-29-2012, 19:43   #12 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. no no no i am not telling that you lying. i know you are not lying but read my last line, its a actual solution from my point of view. i am just trying to help you bro.
Old 03-01-2012, 00:21   #13 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
IGNORE phone types.
UPP ID 3040, 2292, 2293, 3162, 3166, 3168 use the same approach. one bug, all bugs.
rabi, all your link are malfunctioned boxes. as i said, there is no bugs.
use other tools if you insist.
Old 03-01-2012, 09:05   #14 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
Supported Ids: 2292
can u do buscheck? try other fbus cable yet? try easy cable too or clean the phone's pin...
a lot of possibilties here bro
@rabi
malfunctioned boxes mean the boxes are damaged (whose fault is it?), not the bugs in software. am i right or wrong? peace bro...
br
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.26189 seconds with 10 queries
