Old 04-05-2013, 10:30   #1 (permalink)
Member: 266278
Thanks Meter: 12
nokia x7 rm-707 downgraded by mistake
Hi everybody
sounds very bad when doing a mistake n getting ready for execution by the client ha?!
I have downgraded a working x7 by mistake from 111.040 to 111.030, n when i noticed it was late, the phone couldn't enter to test or local mode n phone just showed nokia on screen n went off after about 15 seconds. u might know how I felt that moment: "s*h*i*t*"!!
by the way I flashed again with correct version n phone doesn't still power up after nokia but it goes to test n local mode.
here is the log after pressing the "bus check":
MXKEY [USB Smart Card Reader 0], SN: C######
Using device: USB ROM
Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 14400119C5D60344E3532AD28CFD0C8535F0EB25
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0060 - 0000 0032 [Samsung LH28F800BG] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: BF541CF
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: A777258432D3E9101D6160DBAC2702FCC602E752
Selected firmware certificate matched.
Original Imei: 356###########
Original Product code: 059J0D7
Bluetooth ID: 48DCFB26B42D
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x1D8 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Waiting for device boot up ...
Device connected: nmwcdc\Nokia X7-00 USB Phonet, PORT_ID: F6C012B
Open device failed: FFFFFFFF (4) The system cannot open the file
Warning: Phone did not reboot to normal mode.
Phone type: RM-707 (Nokia X7-00)
SW version: V 79_sr1_12w18.5 27-07-12 RM-707 (c) Nokia
ApeCoreSw: 111.040.1511
Imei plain: 356###########
Battery voltage: 3959 mV, current: 97 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356###########
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
as u might see the log says that the security blocks n NPC n everything seems to be fine, but the phone is still on nokia logo.
will be very appreciated if the masters could advise me to do something befor the client hang me up n execute!!
n if u didn't have any suggestion, still blessings good wishes n good byes are welcomed! ))
Old 04-05-2013, 10:36   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
CMLA keys are corrupted.
Your device will not start on Belle (111.x) firmware.
Your option:
- backup RPL, erase, downgrade to Anna (25.x) firmware, restore RPL.
Procedure like in here
http://forum.gsmhosting.com/vbb/f550...an-do-1443542/
The Following User Says Thank You to gbluez For This Useful Post:
Old 04-05-2013, 10:49   #3 (permalink)
Member: 266278
Thanks Meter: 12
Your option:
thanks, lets do it!
I will inform u after that.
Best regards
Old 04-05-2013, 16:59   #4 (permalink)
Member: 266278
Thanks Meter: 12
dear gbluez
thanks for ur nice guide, phone is now alive, just the problem remaining is super dongel
pls take a look:
MXKEY [USB Smart Card Reader 0], SN: C08072B8
Original Imei: 35625704834473
[0] PA_SIMLOC30
Device connected: nmwcdc\Nokia X7-00 USB Phonet, PORT_ID: 348EA62D
Verifying communication to device OK.
SW version: V 92_11w37 14-09-11 RM-707 (c) Nokia
ApeCoreSw: 025.007
Imei plain: 35625704834473-9
Battery voltage: 4032 mV, current: 103 mA
Language Pack:
- not available.
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
Imei net: 356257048344739
Counter: 0/3, 0/10
after going for super dongle repair shows this:
SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.5
Using device: USB Phonet
Connection status: EHCI:HUB:HUB:USB 2.00 (High-speed)
Driver: nmwcdc, ver: 7.1.32.75
ApeCoreSw: 025.007
ERROR: Missing SD BLOCK or PM corrupted !
To Repair SUPERDONGLE please use "Repair SD" !
and after going for "Repair SD":
ApeCoreSw: 025.007
Interface not supported for current operation or not supported phone !
and must say uu that the phone doesn't enter to local mode or test mode
what now?
Old 04-05-2013, 18:14   #5 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
please insert your smart card into HTI box. Do not use external smartcard.
Operation will be done in standalone mode.
MXKEY Serial: [MxKey HTI FLASHER INTERFACE] - C08072B8
Old 04-05-2013, 18:30   #6 (permalink)
Member: 266278
Thanks Meter: 12
Thanks dear gbluez, the phone works now, everything is fine n I'm going to test it for the next 24 hrs.
sorry the post #4 was silly! my hti interface was disconnected and after connecting everything went true n super dongle repaired at last...
I have just 2 questines:
1, can i upgrade the phone to belle now or not?
2, what does CMLA exactly, n where can i find a refrance to study some about that?
Old 04-05-2013, 18:40   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Hi,
1. sorry, we can't do it on this version. Next update maybe.
2. Belle need this key to start the phone righ click, save: CMLA
Old 04-05-2013, 19:00   #8 (permalink)
Member: 266278
Thanks Meter: 12
Thanks for quick replies, nice guides n great support
u know? u saved my life!!
thanks for everything, u r the best....
Page generated in 0.23946 seconds with 8 queries
