12-22-2006, 00:44 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 49
Member: 103152 Status: Offline Thanks Meter: 0 | CRUISER ver 10.10 NOT WORKING |
12-22-2006, 02:52 | #7 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: UK Age: 52
Member: 168911 Status: Offline Thanks Meter: 12 | Quote:
If so then launch the program, go into settings and then click the authentification tab. You should then be able to alter the devices in ther. You need to close and relaunch the program to see any changes. | |
12-22-2006, 07:38 | #9 (permalink) |
Freak Poster Join Date: Dec 2003 Location: INDIA Age: 42
Member: 45413 Status: Offline Thanks Meter: 3 | Hi Just do this. Go to programe files/crusier/Cyberflex Access e-gate Drivers/Uninstaller/ and open this exe. egateuninst.exe. it will uninstall ur programes then totally delete that crusier folder and restart again install ur 10.10exe it will work try and post ur result |
12-22-2006, 08:35 | #10 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 44
Member: 162029 Status: Offline Thanks Meter: 202 | if you're using moe than 1 dongle try to detach them all first attach cruiser dongle only and try to open soft. i always play around with the authentication part of the soft cause i have 3 smartcards at hand and only cruisers soft is a little tricky in scanning the right dongle. |
12-22-2006, 09:10 | #11 (permalink) | |
Registered User Join Date: Sep 2004 Location: INDIA Age: 48
Member: 83237 Status: Offline Sonork: 100.1577738 Thanks Meter: 61 | Quote:
01-25-2007, 13:13 | #12 (permalink) |
No Life Poster Join Date: Sep 2005 Location: UK, London Age: 35
Member: 177235 Status: Offline Sonork: 111568 Thanks Meter: 138 | HI, I hav recently upgraded to this latest version. And now i have also this exact problem, i have re-installed all drivers and tried a different reader but still the same. B.R |
01-25-2007, 13:26 | #13 (permalink) |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Select Cruiser e-gate Smartcard Reader from Cruiser.exe -> Settings -> Authentication -> e-gate Smartcard Reader: -> select Cruiser Dongle,click OK,close program and start again!! |
Cruiser team....after 9.74 ver. modify GDFS not work | karouk | Cruiser Suite | 0 | 02-06-2007 17:35 |
cruiser V 8.11 not working on cid49 | Jamal | Cruiser Suite | 7 | 02-02-2006 17:26 |
Cruiser 4in1 cable driver not working!!!!!! | kaino147 | SonyEricsson (USB-Smart) | 2 | 12-18-2005 17:46 |
4in1 uc-10 cable not work on Sharp 902? | Raklm | Cruiser Suite | 7 | 07-17-2005 20:14 |
update vers. 7.2 not working C2200 unlock | simlockman1 | Blazer | 5 | 06-08-2005 12:55 |
