Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 09-22-2012, 17:03   #1 (permalink)
SPUnlock_SK's Avatar
Member: 13922
Thanks Meter: 334
Lumia 800 can't unlock - [SOLUTION INSIDE ATF 9.12]
I have hard times with one lumia 800 (rm-801)
I tried to flash 2different FW's from NAVIFIRM but with still same result
my wirres are realy short
any idea?
here is log:
Interface Reset OK!
Reading Platform Information...
Selecting Active Handle...
Select Handle OK!
Sending Ping...
Ping Reply OK!
Storage Device Information
Manufacturer ID: 11
Application ID : 0100
Product Name : 016G4B
Product Rev : 00
Product SN : 0F4A237F
Protection Information
Write Protect A: OFF
Write Protect B: OFF
Dumping AMSS FAT16 Region
Please wait for 2-4 Mintues...
ERROR: Dump Aborted, Too much CRC Failures!
Total Elapsed Time 00:00:06
Old 09-22-2012, 17:13   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@SPUnlock_SK
This means TP Connection or TP Wires are NOT STABLE. So try to make your wires
shorter (maximum 5 inches for the 0.10mm gauge coated copper wire).
Also check this post:
http://forum.gsmhosting.com/vbb/f609...819-a-1540417/
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 09-22-2012, 23:28   #3 (permalink)
Member: 68842
Thanks Meter: 9
hi
i have 2 inches cable from atf box to tp,i have flashed phone with version firmware that you specified,changing 3 diff. laptops but always stupid crc error
Old 09-23-2012, 00:58   #4 (permalink)
Member: 651945
Are you using ATF Chrome or Nitro/Lightning?
Old 09-23-2012, 11:06   #5 (permalink)
Member: 68842
Thanks Meter: 9
i think box is atf chrome ,older variant with modified pcb
Old 09-23-2012, 17:51   #6 (permalink)
VIK
Member: 2145
Thanks Meter: 36
Hello
First of all want to say thanks to X-Shadow and all ATF team for so Great research =)
Concerning unlocking pb.
There is no problem with old PC , PC OS, bad soldering, wrong tp or fw inside lumia.
Probably i'm wrong , but i think that problems appear only with this Toshiba eMMC chip.
Manufacturer ID: 11
Product Rev : 00
You can find more info about this pb here
http://forum.gsmhosting.com/vbb/f609...ml#post8769409
http://forum.gsmhosting.com/vbb/f609...5/#post8769319
http://forum.gsmhosting.com/vbb/f609...oblem-1537145/
http://forum.gsmhosting.com/vbb/f609...nlock-1540442/
One of mentioned links contain solution for unlock in way to combine atf tp with other product, at least as temporarily solution for unlockers.
Also I have played with Lumia with HYNIX chip on board (Manufacturer ID: 90 Application ID : 014A) and all went fine. Boot repair and unlocking too.
But I want to warn users do not use Boot repair with MBR rewrite ticked if it is not necessary for eMMC
Manufacturer ID: 11
Product Rev : 00
Cause at end with high probability you will have dead phone in hands.
Maybe I'm wrong ( and it would be good if so ), but by my opinion MBR areas contain different data for HYNIX and Toshiba chips.
RGDS
VIK
The Following 3 Users Say Thank You to VIK For This Useful Post:
Old 09-23-2012, 18:33   #7 (permalink)
Member: 651945
Originally Posted by VIK View Post
Hello
Manufacturer ID: 11
Product Rev : 00
Manufacturer ID: 11
Product Rev : 00
RGDS
VIK
WOW... You really hit the bull's eye with your post!
TOSHIBA eMMC Chips is BLOCKED by ATF BOX because I assumed
that TOSHIBA eMMC is only for 610 and 610C phones. Everytime ATF
BOX "sees" a TOSHIBA Manufacturer ID: 11, it will disable proper eMMC
dump so that end users will NOT BE TEMPTED to try and unlock 610
phones.
You will NOT have "dead" phones in hand though, because only eMMC
READ is disabled. eMMC Write is working like it is for the rest of the
Manufacturer IDs.
I REALLY appreciate your post and admire the fact that you helped me
solve this problem among other end users.
I will put up a "quick software update" to bypass ATF BOX rejection of this
eMMC.
BEST REGARDS!
X-Shadow
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 09-24-2012, 07:54   #8 (permalink)
Member: 651945
@SPUnlock_SK
@VIK
The Problem is already solved by ATF Software 9.12.
For More Information, please check this post:
http://forum.gsmhosting.com/vbb/8781750-post239.html
B.R.
Old 09-24-2012, 11:18   #9 (permalink)
Member: 68842
Thanks Meter: 9
yes lumia 800 unlocked but prozes time is about 30min on i7
thanks atf team
Old 09-24-2012, 15:43   #10 (permalink)
gsmpointhrp's Avatar
Member: 416286
Sonork: 100.1622339
Thanks Meter: 759
Lumia Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
Select Handle OK!
Sending Ping...
Ping Reply OK!
ERROR: Connection Refused 0x06
Check your Test Point Soldering!
I am facing this problem on lumia 800 and its TOSHIBA Flash Chip and check again and again connections are ok and phone get dead during unlock process please help me what to do now .... while a unlock lumia 800 successfully
Old 09-24-2012, 16:07   #11 (permalink)
Member: 416286
Sonork: 100.1622339
Thanks Meter: 759
Before it was giving error like this
09:18:59 : ================================================== ====
09:18:59 : Lumia Test Point Connection Module
09:18:59 :
09:18:59 : 1. DO NOT USE THE PHONE"S BATTERY
09:18:59 : 2. Connect the Soldered TP Connections to ATF Box
09:18:59 : 3. Disconnect the USB Cable and Wait until the
09:18:59 : the ATF Software will tell you to Connect the USB.
09:18:59 :
09:19:04 :
09:19:04 : Interface Reset OK!
09:19:04 : Reading Platform Information...
09:19:04 : Selecting Active Handle...
09:19:04 : Select Handle OK!
09:19:04 : Sending Ping...
09:19:04 : Ping Reply OK!
09:19:04 :
09:19:04 :
09:19:04 : Storage Device Information
09:19:04 : Manufacturer ID: 03
09:19:04 : Application ID : FFFF
09:19:04 : Product Name : ÿÿÿÿÿÿ
09:19:04 : Product Rev : FF
09:19:04 : Product SN : FFFFFFFF
09:19:04 :
09:19:04 : Protection Information
09:19:04 : Write Protect A: OFF
09:19:04 : Write Protect B: OFF
09:19:04 :
09:19:05 :
09:19:05 : Dumping AMSS FAT16 Region
09:19:05 : Please wait for 2-4 Mintues...
Old 09-28-2012, 14:05   #12 (permalink)
Member: 13922
Thanks Meter: 334
with new update I was facing some differnet connection problems
09:17:48 : ================================================== ====
09:17:48 : Lumia Test Point Connection Module
09:17:48 :
09:17:48 : 1. DO NOT USE THE PHONE"S BATTERY
09:17:48 : 2. Connect the Soldered TP Connections to ATF Box
09:17:48 : 3. Disconnect the USB Cable and Wait until the
09:17:48 : the ATF Software will tell you to Connect the USB.
09:17:48 :
09:18:12 :
09:18:12 : ERROR: Phone WAS NOT Detected!
09:18:12 : Check the BLUE WIRE Connection
09:18:12 : Check the GREEN WIRE Connection
ERROR: Phone WAS NOT Detected! 0x01
even all TP's are solder OK
I checked 2times, with 2different cables
now after few tried my Lumia 800 with toshiba eMMC can't power on
how can I make it alive?
Old 09-28-2012, 14:18   #13 (permalink)
Member: 651945
Your problem is related to your soldering.
Other people who I sent PM about the 9.12
TOSHIBA fix already confirmed that their phones
were already unlocked by 9.12. You should also
expect the same fate for you phone.
Check properly the GREEN and BLUE TP resistors.
Make sure you soldered in the correct side.
If phone does not power ON, then try to remove
you TP connections first... Then :
1. Press power button for 12 seconds
2. Release power button for 3 seconds
3. Press power button for 2 seconds or
until you feel a short 200 ms vibration
Old 09-28-2012, 17:21   #14 (permalink)
Member: 1263622
Thanks Meter: 149
Atf box flash failed lumia 800 than..................
You can ONLY flash your device with Nokia Care Suite.
tested..........solution
Old 09-29-2012, 10:58   #15 (permalink)
Cheater -Don't Deal with him-
khawar's Avatar
Member: 51218
Thanks Meter: 77
Sir,
The problem is the resistor at blue tp, If it is broken or desold the set with Toshiba chip ,will not connect,and also ll not turn on.
Today i faced same problem,and after properly soldring this resistor the set unlocked and working.
If this resistor is broken in lumia with chip other than Toshiba,the set is unlocked and also working fine.
Wr KHAWAR
Page generated in 0.29844 seconds with 8 queries
