Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-11-2011, 11:02   #106 (permalink)
Registered User
maryajne's Avatar
Member: 305964
Thanks Meter: 71
Originally Posted by Advance-Box View Post
Check were you extracted it...
You should find "35824103311661.bat"
tnx bro PJ ,, this is what ive waiting i will only this file got it....muahhh
Old 04-11-2011, 11:03   #107 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
how i can fix this ?
Old 04-11-2011, 11:05   #108 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,119
Update your ATI Drivers and you will have no more problems...
B.R.
Old 04-11-2011, 11:06   #109 (permalink)
benguetcowboy1's Avatar
Member: 51716
Sonork: 100.1594676
Thanks Meter: 217
seems that this software is unstable gpu keeps on crashing even with stock settings but works well on same settings using ighashgpu....anyone having same problem as mine???
Old 04-11-2011, 11:07   #110 (permalink)
Member: 651945
Do not forget to EDIT that batch fiel correctly before using it...
If PC HANG, FREEZE or REBOOT... Then you only need to type
oclHashcat-lite32 --restore
And it will resume..
B.R.
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 04-11-2011, 11:08   #111 (permalink)
Member: 651945
try -n 160 instead of -n 800
Are you using 2 x 5970 ?
Also it depends on what kind of CRASH you are experiencing...
CRASH and Temperature is higher than 95 degrees means your Card is too hot and your Overclock settings are too much...
CRASH and Temparature is blelow 80 degrees means that "maybe" your millivolts is too LOW...
Old 04-11-2011, 11:11   #112 (permalink)
Registered User
maryajne's Avatar
Member: 305964
Thanks Meter: 71
B.R.
okey tnx po....good update let see if is working propely hope that easily find code
Old 04-11-2011, 11:12   #113 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
B.R.
i have latest drivers.
Old 04-11-2011, 11:12   #114 (permalink)
Member: 51716
Sonork: 100.1594676
Thanks Meter: 217
single 5970 boss i have to remove second gpu so i can determine the fault cause i have only 850w powersupply
Old 04-11-2011, 11:14   #115 (permalink)
Member: 651945
@benguetcowboy1
Ok, that could cause a problem.... Since oclHashcatl-lite has 54% CPU Usage, so
maybe your 850 watts was not enough for 2 x 5970... This is just my thoery.
I am using 1,200 watts though.
B.R.
Old 04-11-2011, 11:14   #116 (permalink)
Member: 63120
Thanks Meter: 58
ocl full manual from Atom
here is full manual ......... so now all is clear...
look this link :
oclHashcat-lite SL3 cracking howto
br skkeptik
p.s. i use this soft for 10 days ago and no problems at all, feel free to ask me all abot it !!!!
Old 04-11-2011, 11:17   #117 (permalink)
Member: 651945
look this link :
br skkeptik
Remind atom about that PayPal donate button
B.R.
Old 04-11-2011, 11:27   #118 (permalink)
Member: 15521
Thanks Meter: 57
I have the same problem.
Old 04-11-2011, 11:27   #119 (permalink)
Cheater -Don't Deal with him-
Member: 686535
Sonork: 1592667
Thanks Meter: 108
thanks boss new error again error: Clgetplatformids() -1001
remove installed driver and install 11.3 and amd app 2.4
br
chokl@t
Old 04-11-2011, 11:28   #120 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 184
@sky_finder
Buy 2GB card so you can save some money...
4GB is useless for our BF Purposes
Thanks sir..For helping..
Please check this card ..will it support.
Amazon.com: Sapphire Radeon HD 6970 2 GB DDR5 DL-DVI-I/SL-DVI-D/HDMI/Dual Mini DP PCI-Express Graphics Card 100311SR: Electronics
Thanks.
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/
Posted By For Type Date
LBF computer configuration This thread Trackback: 07-04-2011 20:15
Page generated in 0.24566 seconds with 9 queries
