04-11-2011, 11:34 | #123 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Yes, but this is slower than 6990... you need 2 x 6970 = 1 x 6990 B.R. | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
04-11-2011, 11:51 | #127 (permalink) |
Freak Poster Join Date: Sep 2005 Location: poland Age: 43
Member: 179431 Status: Offline Sonork: 100.1601222 Thanks Meter: 12 | https://picasaweb.google.com/1142224...76539432264930 this is normal?? oclHashcat-lite32 A90CC70AC11620E391BC1C779635790FC17D25CE:003526840 466182900 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --hex-salt --hex-charset --output-format=1 |
04-11-2011, 11:53 | #128 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @maryajne Nicely done bro Make sure temp does not reach 90 degrees or above... Nice Speed as well! B.R. |
04-11-2011, 11:56 | #129 (permalink) | |
Use this: oclHashcat-lite32 A90CC70AC11620E391BC1C779635790FC17D25CE:003526840466182900 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=35268404661829_COD.txt OR SIMPLY DOWNLOAD YOUR SPECIAL BATCH FILE BELOW: Download this Bro: http://174.120.45.27/tmp/35268404661829.rar Then extract it to the folder where you have oclHashcat-lite32... Then double click 35268404661829.bat B.R. | |
04-11-2011, 12:06 | #132 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 372207 Status: Offline Thanks Meter: 60 | Please Help! 1. How to split 1 Job to 2 PC?? like this:? PC_1: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:01003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --hex-salt --hex-charset --output-format=1 PC_2: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:02003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --hex-salt --hex-charset --output-format=1 2. How get NCK from COD file ? Thanks, Br, Alex |
04-11-2011, 12:06 | #133 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @maryajne Yes... You just need to add another line to that batch file I gave you. example: Command Line 1 Command Line 2 Command Line 3 Command Line 4 pause Save Batch file and run it.. It will run Command 1, 2, 3, 4 one after the other... B.R. |
04-11-2011, 12:16 | #135 (permalink) | |
This is preparation for 6xxx cards only (6990, 6970 etc...) 5xxx cards can still work with lower than 11.3 ... I am also using lower than 11.3 for my 2 x 5970 ... For less confusion, it is best to tell everyone to update the ATI drivers and use 11.3 Catalyst. B.R. | |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/ | ||||
Posted By | For | Type | Date | |
LBF computer configuration | This thread | Trackback: | 07-04-2011 20:15 |
