04-11-2011, 11:06 | #109 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | seems that this software is unstable gpu keeps on crashing even with stock settings but works well on same settings using ighashgpu....anyone having same problem as mine??? |
04-11-2011, 11:08 | #111 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,119 | Quote:
try -n 160 instead of -n 800 Are you using 2 x 5970 ? Also it depends on what kind of CRASH you are experiencing... CRASH and Temperature is higher than 95 degrees means your Card is too hot and your Overclock settings are too much... CRASH and Temparature is blelow 80 degrees means that "maybe" your millivolts is too LOW... | |
04-11-2011, 11:11 | #112 (permalink) | |
Registered User Join Date: Jul 2006 Location: iphone ww codes Age: 42
Member: 305964 Status: Offline Thanks Meter: 71 | Quote:
okey tnx po....good update let see if is working propely hope that easily find code | |
04-11-2011, 11:12 | #114 (permalink) |
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | single 5970 boss i have to remove second gpu so i can determine the fault cause i have only 850w powersupply |
04-11-2011, 11:14 | #115 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,119 | @benguetcowboy1 Ok, that could cause a problem.... Since oclHashcatl-lite has 54% CPU Usage, so maybe your 850 watts was not enough for 2 x 5970... This is just my thoery. I am using 1,200 watts though. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
04-11-2011, 11:14 | #116 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 49
Member: 63120 Status: Offline Thanks Meter: 58 | ocl full manual from Atom here is full manual ......... so now all is clear... look this link : oclHashcat-lite SL3 cracking howto oclHashcat-lite SL3 cracking howto br skkeptik p.s. i use this soft for 10 days ago and no problems at all, feel free to ask me all abot it !!!! |
04-11-2011, 11:17 | #117 (permalink) | |
Remind atom about that PayPal donate button B.R. | |
04-11-2011, 11:28 | #120 (permalink) | |
No Life Poster Join Date: May 2009 Location: Srilanka
Member: 1026122 Status: Offline Sonork: 100.1640842 Thanks Meter: 184 | Quote:
Please check this card ..will it support. Amazon.com: Sapphire Radeon HD 6970 2 GB DDR5 DL-DVI-I/SL-DVI-D/HDMI/Dual Mini DP PCI-Express Graphics Card 100311SR: Electronics Thanks. | |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/ | ||||
Posted By | For | Type | Date | |
LBF computer configuration | This thread | Trackback: | 07-04-2011 20:15 |
