04-23-2011, 22:26 | #589 (permalink) |
No Life Poster Join Date: Jun 2001 Location: x
Member: 4989 Status: Offline Thanks Meter: 13 | Yes, you can add more lines to a bat or cmd file, but...if power goes off and you restart same bat it will restart from begining. Also if you start a bat file and from time to time you look at what % is calculation and you press accidentaly "q" it will begin next calculation and rewrite the restore file. Of course these are not big problems as long as you remember where to restart from. |
The Following User Says Thank You to mr_x4you For This Useful Post: |
04-24-2011, 05:52 | #591 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: THAILAND-CHINA-INDIA-CANADA
Member: 230831 Status: Offline Sonork: 100.98820 Thanks Meter: 278 | Quote:
13g+ hash ( r u using 8 gpu 5970 ? in linux | |
04-24-2011, 17:21 | #594 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | it is done.. it took 10 hours 30 mints... percent 20.39 and latest one..it is n97 new hash again... starting now... Last edited by LoveLess; 04-24-2011 at 17:27. |
04-24-2011, 17:37 | #595 (permalink) |
No Life Poster Join Date: Jun 2003 Location: somewhere Age: 40
Member: 31028 Status: Offline Thanks Meter: 56 | hi i'm starting to bruteforce, mounted a pc with just one 6990 to test it, got between 2000 and 2300 hashes with standard config yet, but i have one gpu on 64 degrees and the gpu on 90 degrees, is 90 too much??? what can i do ? regards |
04-24-2011, 17:50 | #596 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
it is abit more..r u using default fan.? or manual.? try to use manual fan to 100%.. or 90 85.. | |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/ | ||||
Posted By | For | Type | Date | |
LBF computer configuration | This thread | Trackback: | 07-04-2011 20:15 |
