08-23-2013, 10:40 | #19 (permalink) |
Junior Member Join Date: Apr 2013 Location: SPAIN
Member: 1924507 Status: Offline Thanks Meter: 4 | i'm Facing Same Problem IPhone 5 Unknown Error 9 While Trying to do Restore With Itune i try in recovery Mode and error 9 i try in DFU Mode Error 9 I change USB Cable Error 9 I Update itune Error 9 i remove full itune and all apple software from PC install Again and after than error 9 i Change PC Error 9 i Try On Window xp & Window 7 and Window 8 Error 9 I open the Phone Remove Battery for 10-15 minutes and put again and try again in DFU Mode so Error 9 now is only 1 thing left change battery and i will soon try that and will tell here result if any1 have any good idea for solve this problem so tell plz |
The Following User Says Thank You to LBox Server For This Useful Post: |
10-21-2013, 10:53 | #29 (permalink) |
No Life Poster Join Date: Mar 2013 Location: NewYork Age: 32
Member: 1900437 Status: Offline Thanks Meter: 113 | I suggest you to make an appointment with the Apple store individuals. Because eventually if you'll fix it..... but still your device need a service. So better to go towards the store directly ! |
11-08-2013, 09:39 | #30 (permalink) |
Insane Poster Join Date: Jan 2013 Location: sylhet,bangladesh.......?
Member: 1872574 Status: Offline Sonork: 100.1625986 Thanks Meter: 28 | my problem solved error 9 just usb cabol problem and pc usb port change and others device close and battery full charg problem solved inshallah....................... |
